    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.6k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Did you get an error message?
      What happened exactly?
        glro
        sketchup stopped suddenly, and that was it
        bugsplat
        i tried to remove some newly installed extensions, and this way i found out that "Layers panel" was involved
        I can't write more since i don't understand what's happening; your plugin might be perfect; i just know that if i remove it, i don't have the problem
        • tt_suT Offline
          tt_su
          Did you submit that BugSplat? Did you enter any info in the Description or Name field we can use to look it up by?
            glro
            No
            but if you think it might help, i shall
            • tt_suT Offline
              tt_su
              We might be able to get some clues to what cause the crash.
              Please always submit BugSplats - even if you do not fill in any info. It helps our statistic when we look for highest source of crashes. But it do helps if you enter some info the first time you experience a crash, and some contact info so we can reach out if we need more info. Then if you experience the crash again just keep submitting, but then there is less need for you to fill out details.
                Layer One
                I love it, great plugin.
                Is there any way to sort the layers, perhaps alphabetically.
                  jiminy-billy-bob
                  No, not for now, but it's on my todo list.
                    alexpnz
                    Hello !
                    Huge thanks for a great plugin !
                    I SUMake 2014 on Mac OS X 10.8.5 there is a problem:
                    1. Toolbar Layers Panel disappears after you restart the program, it is necessary to re-run. If you add buttons to the toolbar after restart, SU they also disappear from the panel.
                    2. On the panel Layers Panel toggle visibility is not clicking on the "eye" and slightly to the left of the separator (assuming off-panel renders) and Layer switching States of the active set is not pressing on the circle and also slightly to the left of the separator.
                    3. The Panel Layer States every time you open appears in the same place (it does not remember its position).
                    4. the Panel Layers Panel if it is to disable and enable the button from the toolbar Layers Panel every time you open becomes shorter height)) cool.
                    Sorry for machine translation)
                      ckho1985
                      running OS X 10.8.5, sketchup 14.
                      I updated the layer panel 1.2.1 from 1.2.0. but then the tool does not work anymore.
                      It is clearly intalled. The icon is there. the Layer Status browser works, when clicking the icon. But the Layer Panel does not open when clicking the icon. The browser window of the Layer Panel sort of flashes once which clicking the icon. (open and closes in a 0.1 second)
                      dont know what to do.
                      Great tool! frustrated that cannot us it now…. arrrrghhh
                        jiminy-billy-bob
                        Can you open the Ruby Console, and tell me if there is any error message there when trying to open Layers Panel?
                        In the meantime, you can download older versions here: http://thomashauchecorne.com/layers/versions/
                        (Please try the above first, so I can fix it for future versions)
                          ckho1985
                          Do I need to type anything in the ruby console?
                          there is no error message. Everything else (debug, option, status) works fine.
                          just when I click layer panel the window is not showing up (it flashed up then its gone)
                          I tried to uninstall 1.2.1 and reinstall 1.2.0. same thing happens.
                          maybe is the sketchup itself has a problem?
                            jiminy-billy-bob
                            This is weird. To uninstall, you completetly deleted the file jbb_layers_panel.rb and the folder jbb_layers_panel in C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins ?
                            If so, I really don't understand where it can come from. Try an even older version.
                            • ccaponigroC Offline
                              ccaponigro
                              Working in 2015 set up a bunch of groups etc. closed the drawing and come back later and all groups are gone and every time open Layer Panel it says it need to be fixed. I am also using Skalp and 2D tools I mention this because both do some background layer functions.
                              Thoughts?
                              cfcaia.com
                                jiminy-billy-bob
                                Does the same thing happen when disabling all the other plugins?
                                  dkapotov
                                  Hello. I had a trouble with moving layers in the list. Sometimes when I try to move layer up/down and drop it on the half of the way this layer freeze in the list. As example layer Foundation on the picture.
                                    jiminy-billy-bob
                                    What happens if you close the dialog and reopen it?
                                      dkapotov
                                      If I close and open dialog trouble fix.
                                        siim11s
                                        @alexpnz said:
                                        1. On the panel Layers Panel toggle visibility is not clicking on the "eye" and slightly to the left of the separator (assuming off-panel renders) and Layer switching States of the active set is not pressing on the circle and also slightly to the left of the separator.
                                        Same problem. Seems the icon is not clickable.
                                        Also +1 on the sort layers alphabetically feature request.
                                        Thanks for a great plugin!
                                        //S.
                                        • F Offline
                                          Fri25
                                          Bug in the program
                                          Sometimes the layer order gets totally confused and can not be restored.
                                          This happens when elements contained various layers are imported and these are not available or disabled in the current layer directory.
                                          The whole work of the layer structure is destroyed. The purpose of the program is obsolete!
                                          My system: Sketchup 2015 Windows 7
                                            siim11s
                                            @fri25 said:
                                            Bug in the program
                                            The whole work of the layer structure is destroyed...
                                            I ran into the same problem yesterday. Layer groups disappeared from both source and destination model after import and the layer order was changed.
                                            Fortunately I had kept my layer-naming convention and could manually reorder and regroup layers. Strangely, after I had fixed the layers in the source model, the destination model was automatically updated.
                                            OSX 10.10
                                            SU v15.0.9349
                                            //S.
                                            • 11
                                            • 12
                                            • 33
                                            • 34
                                            • 10 / 34
