    Npr fly around videos
    30 Posts 9 Posters 3.2k Views 9 Watching
    • pmolsonP
      pmolson
      Hi Daniel, Thanks for the comment.
      good eye on the 2d trees. I was experimenting with those trees on that model because the client chose to use a little color on that model instead of our usual grey style.
      I need to find some npr 2d trees.
      These models get very heavy and become almost unworkable if I use all the 3d trees I would want. Even when I isolate groups of 3d trees & bushes not in a particular view and turn them off, the regen time in each scene can be time consuming. The combination of the wiggly line style I use with shadows and 3d trees & bushes becomes a bit of an animal.
      I just upgraded my computer and it handles it better, but I still have to be selective about 3d tree & bush use.
      The reason for the trees disappearing is simply time & money. It was time to be done so we went with a couple glamour shots and then went makeupless...so to speak.
      p
      • DanielD
        Daniel
        I feel your pain - I've been there before, trying to fill a model with enough entourage without overtaxing the system.
        Have you looked on 3D Warehouse? Some guy in our office recently did a model with 2D trees he pulled from that site. And have you tried at any styles that include an NPR tree backdrop?
        My avatar is an anachronism.
        • pmolsonP
          pmolson
          Daniel
          I have tried the back drop idea, but it always feels...wrong I guess. It can work great for still shots though. The style i use was created specifically for this client and they are happy, so I would be wise to not fix what is not broke.
          I have looked around a bit for npr tres, but I need to try harder. Maybe this very minute!
          p
          • bazB
            baz
            @pmolson said:
            I have looked around a bit for npr tres, but I need to try harder. Maybe this very minute!p
            Have a look at 'TomsDesk" http://www.tomsdesk.moonfruit.com
            I used them extensively in my example
            • pbacotP
              I was just using Tom's shrubs today! Unfortunately he never came up with the "new" shrub bundle he shows a teaser for. I think he dropped making new products a long time ago. Those rees are heavy on the program if you use too many, but well-made, including layers so you can position without all the leaves turned on. They are good looking in SU output.
              • bazB
                baz
                Yeah, haven't seen him round the forum for a while either...
                • AdamBA
                  AdamB
                  @pmolson said:
                  Thanks Baz You may be using a lot more initial sketchup scenes. My settings are very similar to yours, but I only end up with about 1800 - 2000 images. I start out usually with about 12 - 20 scenes.
                  Looking at your videos, they look to me to be 10fps - they're certainly not 30fps.
                  Check your settings not just on exporting from SU but your video codec is set to 30fps also.
                  Adam
                  • pmolsonP
                    pmolson
                    Thanks for the Toms desk info.
                    adam, I will look at the codec...here it is
                    mp4-h264 1920X1080p 30
                    frame rate 29.97
                    I mess with the duration of the images in my video editor to get the movies to be the desired length of time. I wonder if that is where I am stumbling..?
                    • AdamBA
                      AdamB
                      Yep, I'm sure the final h.264 is 30Hz - but if you essentially have each frame repeated 3 times, you've got 10Hz. πŸ˜„
                      So check carefully each encoding stage in your workflow, to make sure its always 29.97/30Hz.
                      • pmolsonP
                        pmolson
                        Ok Adam & others, bear with me for a minute as I am somewhat challenged when it comes to this stuff.
                        If I want a video that plays at 30 fps and I want that video to be 2 minutes long...
                        120 seconds x 30 frames per second = 3600 images with a duration of .033 each (1 second divided by 30)
                        so, if that is correct, when I set up sketchup to generate an image set I need it to generate 3600 images along my chosen scene path
                        Lets say I have 20 scenes and the animation settings are set to 30fps
                        My scene transition settings are set at 2 seconds (just because that is what it was set at)
                        I know from past experience that this set up generates 1142 images.
                        I think the math says that 20/1142=.0175 so if I take that .0175x3600 = 63 scenes to generate 3600 images.
                        I am way above my pay grade here...am I on the right track? 63 scenes will be a huge time consuming process...
                        does changing the scene transition time change the image output per scene?
                        Must let the cpu between my ears rest now. please help if you can.
                        thanks
                        p
                        • jo-keJ
                          jo-ke
                          Do you know these trees (only 2D face me):
                          404 Not Found
                          (sketchucation.com)
                          http://www.zz7.de
                          • pmolsonP
                            pmolson
                            Thanks Jo-ke, I have them now.
                            • AdamBA
                              AdamB
                              Correct
                              20 x 2 = 40 seconds animation @ 30 fps = 1200 images
                              OK, better to say 120 seconds / 20 scenes = 6 seconds per scene transition.
                              So set the transition time to 6.0 seconds and for 20 scenes it will be 120 seconds long. Job done.
                              Yes because video is output at 30 frames per second. More seconds, means more frames.
                              • pmolsonP
                                pmolson
                                Thank you thank you thank you I will try those settings as soon as this weekend. I will rerun the process on one that I have already made so that I can do a comparison
                                • bazB
                                  baz
                                  πŸ‘
                                  • pmolsonP
                                    pmolson
                                    on a somewhat related topic,
                                    I have a new computer that does not make it through the process of generating an image set using the animation tool in su.
                                    It is a dell alienware 17x, 32gb ram,partial solid state drive, partial sata drive, windows 7 pro,
                                    su 2014 & 2015 I am forced to create all my image sets on my old computer which is semi retired.
                                    Any thoughts?
                                    • pmolsonP
                                      pmolson
                                      So, I have utilized all the good advice received in this thread and I think I actually now have the ability to make these movies true 30fps. It took a little fussing with my video editing software, but I am pleased with the smoothness of the video.
                                      Thanks to all of you for your help.
                                      30fps npr movie
                                      • C
                                        cadmunkey
                                        Looks great Paul, nice model.
                                        • 2 / 2
