    Scale for rendered exterior elevations
    Scheduled Pinned Locked Moved Post Processing
    6 Posts 5 Posters 11.8k Views 5 Watching
    • pbacotP Offline
      I have been considering using rendered elevations for a project, but the task of reproducing the proper scale on the output(multiple elevations and multiple exports) may make it unfeasible. How is the zoom setting for parallel projection determined. I wonder if a setup can be repeated that will always produce the same relative scale for width of window? That way scaling the image would be the same proecess each time.
        Can't you set up scene-tabs for each elevation [orthogonal views], then use Layout.
        You can set the scale of each viewport to whatever you desire...
        • pbacotP Offline
          I mean I am exporting parallel projection renders in jpg (Twilight). I usually use LO and get the standard SU output in scale OK.
          Certainly I can experiment with this, but wondered if someone who knows the tech better would have an idea. I simply couldn't end up eyeballing each elevation each time I have to scale it to produce a drawing.
          Probably this is too much work for multiple use. 😒
          • srxS Offline
            srx
            I found supersection plugin very useful for this. It makes scenes with the same scale...I think..
            www.saurus.rs
            • DareDevilD Offline
              DareDevil
              If I understand (my english is not so good...), I think I had the same problem... and I found a solution :
              I make a big bounding cube for all the scene, without faces, only edges. When I want to render, I make an Extended Zoom and all is always the same, scale and ground level height in the view.
              Hope that helps you.
              • JQLJ Offline
                JQL
                It zooms extents in every scene. The same scale comes from there.
                I use to select something on the model, maybe the project I'm working on, and zoom selection on it. If it's about the proportion of my monitor it works. If not, you have to use the method Daredevil uses but it would be best with a vertical line and zoom selection.
                I have a shortcut for zoom selection though it's in context menu (right click)
                www.casca.pt
                Visit us on facebook!
