    [Plugin] V-Ray Tools
    238 Posts 80 Posters 301.7k Views 80 Watching
      @jjoklong said:
      Hi TT.
      I search this error on GG and this is the topic have same problem with me.
      I close Sketchup after render done and when come back,this error happened.
      Dont know how to fix this.It's only my artwork but I'm afraid this error will happen later.
      Did you use V-Ray Tools in any way?
      • P
        pipinek
        Greetings,
        I am unable to get 'Load V-ray' option activated neither via toolbar nor the plugin menu.
        Both of them are grayed out.
        I was wondering whether the current release of Vray Tools (2.2.1 - ?) is compatible with Vray 2,0 on Su 2014.
        I will I appreciate any elucidation on the above.
        Thank you in advance.
          It should be. However, if the button is disabled it probably means that V-Ray is loaded.
          Make sure that V-Ray for SketchUp is disabled under Preferences > Extensions.
          • P
            pipinek
            I thank you very much.
            It did work once.
            Once deactivating Vray via Preferences - Extensions the two Vray toolbars were loaded.
            A Load Button within Vray Tools became grayed and it remained thus after I closed (clicking on red close button)them. The Load Button (Vray Tools) remained desactivated-grayed.
            In order to recall Vray toolbars I had to do it manually (View - Toolbars, etc).
            I find that there is no possibility to switch an appearance of the Vray toolbar using Load Button of Vray Tools. Once they become activated the mentioned button keeps remaining gray - disabled.
            Is this a 'normal' case or is there something here, between a chair and a screen?
              Once V-Ray is loaded you cannot unload it during that session.
              Once you have disabled VfSU in Preferences it should not load when you start SketchUp.
              Then you can use V-Ray Tools to load SketchUp on demand and it will remain loaded for the duration of that session.
              Are you seeing that VfSU is disabled along with the Load V-Ray button in V-Ray Tools?
              • P
                pipinek
                Thank you for your response.
                In that case all function as programed. I thought that pressing a Load Button could load and UNLOAD the VfSU.
                Indeed, the Load Button is active after starting SU, before loading VfSU and become gray/inactive once the Vray toolbars are loaded.
                I have simply expected the Load Button to unload VfSU.
                My best regards.
                  Aklydian
                  Hi Thomas,
                  I'm trying to use your V-Ray Tools plugin to match Sketchup's viewport resolution and aspect ratio to v-ray's so that I can export a linework image and composite it with my v-ray render. I take the resolution and aspect ratio numbers from the v-ray output screen and put them into their appropriate spots on the v-ray tools plugin safe export menus.
                  The image exports, but it doesn't match the V-ray render.
                  Any help you could provide would be much appreciated.
                  Thank you in advance,
                  • Richard
                    jpmorla
                    Hello Thomas,
                    When I try to use the camera tool to set up the aspect ratio, I loose my 2 point perspective that I have set up for my scene. Am I missing something?
                    • tt_suT
                      tt_su
                      hm... I'm not sure is aspect ratio is compatible with 2pt perspective... I'd have to check.
                      • josephkim626J
                        josephkim626
                        Been Loving this plugin!
                          arch12pi
                          hi thomtom, can you fix my problem
                          i cant see vray in windows/preferences/extensions or view/toolbars 😐
                          please check my error , thanks you thomthom
                            arch12pi
                            please check my problem πŸ˜„
                              staedler1822000
                              hi thom, i cant get the tt vray tool to work on my sketchup 8 installed on windows 7 64bit.. i tried to install it in sketch up 8 on my 32bit windows 7 computer(all thesame setup like on my 64bit computer) and it all goes fine..i cant figure it out what seems to be the problem. i need your help please.here are some attachment of the tt vray tool windows on sketchup
                              https://drive.google.com/?tab=wo&authuser=0#my-drive
                                rudii
                                THANK YOU SO MUCH! You don't even know how much your work helped me. Wish you all good for the New Year πŸ˜„
                                • kaluK
                                  kalu
                                  Hi ThomThom:
                                  I make the renders in vray for sketchup already I need the lines export from sketchup to blend in photoshop.I save all the viewports for the renders but I don't want to render again, how the plugin works and what I have to do? I appreciate any help.
                                  Gonzalo. 😎
                                  THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                  • L
                                    Lummoxcz
                                    Hi all,
                                    I have a question - how can I see correct view in SU when I change "Physical Camera setting / Override focal lenght /set to 17? Is there some way how to see in viewport the same aspect which will match with the render?
                                    Thank you very much for an advice!
                                    M.
                                      If you override the SU camera in VfSU then SU won't reflect that. If you want them to match you need to set the focal length in SU.
                                      • L
                                        Lummoxcz
                                        Thank you!
                                          rudii
                                          Dear thomthom, could you tell me please where I can find a tutorial how to use your plugin? I've got vray 2.00.25244 and can't make my viewport match the render. I would appreciate it a lot (it is just killing me...)
                                          M.
                                            skavan
                                            Odd but hopefully related question:
                                            I have a large SKP file with loads of both v-ray and non-vray materials in it.
                                            I note, when I do a distributed render, that it grabs relevant bitmaps from the Network share that the material was loaded from.
                                            Now, I want to use this file on another network. I (at least I think I) need to:
                                            1. Find those materials within the project that are v-ray materials.
                                            2. Copy these materials to a location in my new Network environment.
                                            3. Replace the impacted materials with those copied in #2.
                                            Obviously #2 is easy...but how do I do #1 and #3? I can write basic ruby if that helps...your plugin obviously could be the engine, but doesn't offer #1 or #3 as far as I can tell!
                                            Thanks.
                                            • 11
                                            • 12
                                            • 11 / 12
