    A View Through a Window
    9 Posts 7 Posters 897 Views 7 Watching
      garystan
      This was done sort of "at the last minute".
                                               garystan
        I highlighted some things that would help improve the image if you address them.
        There are some other things like a subsurface material for the candles.
        Specular and bump for the table material.
        Some bevels on the geometry would also add to the scene.
        Not sure what render engine you use?
          garystan
          Rich O'Brien :
                Those aren't artifacts, that's the shadow from the curved curtain material.  YOU NEED TO LEARN THINGS ABOUT ART AND ARTWORK.
        garystan
          • andybotA Offline
            andybot
            garystan, I think Rich is referring to the visible changes between the gray areas of similar color in the shadow areas, not to your artistic integrity.
            • BoxB Offline
              There are none so blind as those who will not see.
              • cottyC Offline
                cotty
                @garystan said:
                Rich O'Brien :
        garystan
                If you don't want helpful hints, you shouldn't post in this forum because you will always get them here...
                my SketchUp gallery
                  @garystan
                  I couldn't agree more.
                  • JQLJ Offline
                    JQL
                    @rich o brien said:
                    @garystan
                    There's so much you can learn on a single post! Thanks to everyone!
                    www.casca.pt
                    Visit us on facebook!
                    • FrederikF Offline
                      Frederik
                      @rich o brien said:
                      @garystan
                      Cheers
                      Kim Frederik
