โ ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
Exporting from Sketchup to 3ds Max - Issues
I have Sketchup Pro 2014. I am trying to export my model to 3ds max 2010. The problem is that the smoothing groups don't import (no big deal) but I can't get the smoothing groups under the poly editor to take in 3ds Max, not even the turbosmooth modifier will work. Several google searches later I am still at a loss for what is going on.
I have tried exporting 3ds, dwg, and dxf formats so far.
Is this is common problem that has an easy solution? I hope!
Thanks for your help.
i think you have to weld vertices
