    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 332.5k Views 53 Watching
      Anton_S
      @ashscott said:
      Anton,
      I am stunned ๐Ÿ˜ฒ
      I have tried so long to get a working function like what you've shown and have failed miserably - this is totally amazing. I hope you don't mind me pillaging your code for ideas?
      Thanks! I'd be impressed to see someone use my code ๐Ÿ˜„
        It does not record added and removed bodies during simulation.
        Ok!
        So, how do save the result of the normal result if you want to use it for something?
        For example I want use the brocken rocks for an exposition! ๐Ÿ˜„
        Now as soon has i want select them (broken rocks) the animation restart at the beginning! ๐Ÿ˜ฒ
        In the past I was making that without problem! ๐Ÿ˜„
        http://sketchucation.com/forums/download/file.php?id=123049&t=1
        http://sketchucation.com/forums/download/file.php?id=123045
          Anton_S
          In the past when you selected a different tool SP didn't always deactivate properly, i.e. sometimes objects failed to be placed back to original locations, but now they do. I suppose, you relied on the bug.
          One way to get all the split bodies is by playing simulation, pausing it at desired frame (i.e when you have broken rocks), and then save as another model. Open the new model, and you have the broken rocks!
            gyrolen
            *Anton , can you help.?
            I cant get SP 3.5.2 to install on Windows 7, using Sketchup Pro 2014.
            Can you advise how to do it.?
            I have downloaded the .rbz file, but where do you put it SU2014 does not seem to use rbz files anymore.
            Thanks,
            Len
              Anton_S
              Thanks,
              Len
              There are two ways you can do it:
              Way one:
              • Download SketchyPhysics_3.5.2.rbz
              • Open SU2014 and navigate to (Menu) Window > Preferences.
              • In the preferences window navigate to Extensions tab and select Install Extension... button
              • From there, find your downloaded compressed file, and select open button, which will install the extension.
              Way two:
              Use PluginStore extension. Follow installation steps here: http://sketchucation.com/resources/plugin-store-download
                gyrolen
                Thanks,
                Len
                Way one:
                Way two:
                Thanks Anton ,your instructions worked fine, have got it going, now to learn how to use it. Len
                  Trobius
                  @anton_s said:
                  Hello, William!
                  Yes, SP doesn't have these methods. The API is quite incomplete.
                  I just added getLifetime, getLifeStart, and getLifeEnd.
                  Is there any other getter or setter functions you think shall be added before I post an update? Sorry, I can't think of any myself.
                  Sorry for taking so long to get back to you. Thank you for the info!
                    Trobius
                    Oh, actually I did think of something else that I would like to see:
                    Could you create a function which would allow you to retrieve the "parent" of an emitted object? (eg, toucher.getEmitter?)
                      I must miss something! ๐Ÿ˜ณ
                      The animation doesn't handle added and removed objects during simulation.
                      So the animation can never play after the beginning of the cutting! ๐Ÿ˜ฎ
                      Try with this example and show me how you can save the broken rocks.
                      (I have the last version 3.52)
                      cut.skp
                        Anton_S
                        Pilou, I'm speaking about the simulation tool, not animation tool. Press the Physics Toggle Play button and wait till the body is cut. As soon as it cuts, press the Physics Toggle Play button once again to pause. From there on you can 'save as' the model, but don't press the reset button, until you do say the model as another model, for instance, cut2.skp
                          Alas it's that I make but when i Reload the "save as" that is again the start of the simulation!!! ๐Ÿ˜ฎ
                          idem with your Cut2 file !
                          A very vicious thing! ๐Ÿ˜„
                            Anton_S
                            Pilou, I re uploaded the cut2 file.
                            One thing to remember is that after you save as, unhide all bodies and delete all the temporary hidden split bodies that were part of the original body. I already did this in the new cut2 file.
                            cut2.skp
                              Anton_S
                              • V Offline
                                vlkster
                                Ok, i'm having a problem with the control panel/sp inspector. when i name a hinge, using " or ' i don't get a slider bar in the control panel. If i leave off the " or ' than i get a error"script error: undefined local variable or method..."
                                any help?
                                thanks
                                  Anton_S
                                  @vlkster, are you saying that you wrote slider("or') in the controller?
                                  If so, then you got it wrong! The quotation marks surrounding the string must be the same!
                                  You may eigher use a double quote (") or a single quote ('), but you cant use a combination of both.
                                  This is what it should look like, slider("or") or slider('or').
                                  • V Offline
                                    vlkster
                                    No i did the way that you have shown.
                                    so i don't know
                                      Anton_S
                                      @vlkster said:
                                      so i don't know
                                      Is your hinge connected to the object ? Can you upload the model so I could investigate?
                                        Anton_S
                                        I added $sketchyPhysicsToolInstnace.getEmitter(grp). This will return the group from which the body group was emitted, or nil if grp wasn't emitted.
                                        Once I post an update, use this technique to get body emitter:
                                        onTouch { |toucher, speed, pos|
                                          emit_grp = sp_tool_instance.getEmitter(toucher.group)
                                          emit_body = simulation.findBody(emit_grp)
                                        • V Offline
                                          vlkster
                                          [/quote][quote="Anton_S":1owgtx3w]
                                          Is your hinge connected to the object ? Can you upload the model so I could investigate?[/quote:1owgtx3w]
                                          https://drive.google.com/file/d/0B3sm21-D2kf1VnJkUnFqZGFjaDQ/view?usp=sharing
                                          Don't make to much fun of my model, just messing around to get a feel for SketchyPhysics.
                                          • F Offline
                                            faust07
                                            Hi Anton, thanks for resolving the significant errors in Sketchy Physics! A dream has come true. I tested an older large Model (was running but regularly crashed in version 3.2) with animated vehicles and animated camera and it runs almost flawlessly. To change I had only connected mirrored groups or components, whose collision geometry the new Physics (3.5) misinterpreted. The import of Replay Data into Twilight 1.5 and 2.0 seems to be working very well too. My goal is to simulate a futuristic urban space (WIP) with animated vehicles, aircraft, ships, people and cameras, which seems possible now. There is only the problem of time (leisure and rendering speed) ... Once again Thank you! ๐Ÿ‘
                                            • 11
                                            • 3 / 11
