    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 345.1k Views 53 Watching
      Anton_S
      SP doesn't have this method, but I created my own.
      https://3dwarehouse.sketchup.com/model.html?id=ua22b41f2-9654-4d70-898b-46d96e687272
      https://googledrive.com/host/0B3qg8f4WrNdHWktZLXN5T2d6Tms/factory_slicer.gif
      • ashscottA
        ashscott
        Anton,
        I am stunned ๐Ÿ˜ฒ
        I have tried so long to get a working function like what you've shown and have failed miserably - this is totally amazing. I hope you don't mind me pillaging your code for ideas?
        Frenchy:
        And also the white cross texture box "transparent" who is drawn
        For some reason "Hidden Geometry" is getting turned on when I run an simulation the first time. Go >View>Hidden Geometry to turn it off.
        Just some stuff I do with Sketchup.
          Cool function! ๐Ÿ‘
          But seems there is a glitch! ๐Ÿ˜‰
          When I use these 2 menus!
          After the Record Animation, replay etc...
          Animation is stopped at the moment of the box must be "exploded" on the inclined plane! ๐Ÿ˜ฒ
          Can you verify this ?
          And also the white cross texture box "transparent" who is drawn! ๐Ÿ˜ฒ
          This is the image of the result wished!
          cut_body_example_glitch.skp
            Thx ๐Ÿ˜„
              Anton_S
              The animation doesn't handle added and removed objects during simulation.
              What happens behind the scenes:
              When the body is about to be split, the body itself doesn't split, but rather two other bodies are added in similar form. The original body becomes hidden and set static, meanwhile the two added bodies take over the scene. When simulation resets the original body is unhidden, and the added split bodies are deleted. The animation tool is not complex. It does not record added and removed bodies during simulation.
                Anton_S
                @ashscott said:
                Anton,
                I am stunned ๐Ÿ˜ฒ
                Thanks! I'd be impressed to see someone use my code ๐Ÿ˜„
                  Ok!
                  So, how do save the result of the normal result if you want to use it for something?
                  For example I want use the brocken rocks for an exposition! ๐Ÿ˜„
                  Now as soon has i want select them (broken rocks) the animation restart at the beginning! ๐Ÿ˜ฒ
                  In the past I was making that without problem! ๐Ÿ˜„
                  http://sketchucation.com/forums/download/file.php?id=123049&t=1
                  http://sketchucation.com/forums/download/file.php?id=123045
                    Anton_S
                    In the past when you selected a different tool SP didn't always deactivate properly, i.e. sometimes objects failed to be placed back to original locations, but now they do. I suppose, you relied on the bug.
                    One way to get all the split bodies is by playing simulation, pausing it at desired frame (i.e when you have broken rocks), and then save as another model. Open the new model, and you have the broken rocks!
                    • G
                      gyrolen
                      *Anton , can you help.?
                      I cant get SP 3.5.2 to install on Windows 7, using Sketchup Pro 2014.
                      Can you advise how to do it.?
                      I have downloaded the .rbz file, but where do you put it SU2014 does not seem to use rbz files anymore.
                      Thanks,
                      Len
                        Anton_S
                        Thanks,
                        Len
                        There are two ways you can do it:
                        Way one:
                        • Download SketchyPhysics_3.5.2.rbz
                        • Open SU2014 and navigate to (Menu) Window > Preferences.
                        • In the preferences window navigate to Extensions tab and select Install Extension... button
                        • From there, find your downloaded compressed file, and select open button, which will install the extension.
                        Way two:
                        Use PluginStore extension. Follow installation steps here: http://sketchucation.com/resources/plugin-store-download
                        • G
                          gyrolen
                          Thanks,
                          Len
                          Way one:
                          Way two:
                          Thanks Anton ,your instructions worked fine, have got it going, now to learn how to use it. Len
                          • T
                            Trobius
                            @anton_s said:
                            Hello, William!
                            Yes, SP doesn't have these methods. The API is quite incomplete.
                            I just added getLifetime, getLifeStart, and getLifeEnd.
                            Is there any other getter or setter functions you think shall be added before I post an update? Sorry, I can't think of any myself.
                            Sorry for taking so long to get back to you. Thank you for the info!
                            • T
                              Trobius
                              Oh, actually I did think of something else that I would like to see:
                              Could you create a function which would allow you to retrieve the "parent" of an emitted object? (eg, toucher.getEmitter?)
                                I must miss something! ๐Ÿ˜ณ
                                So the animation can never play after the beginning of the cutting! ๐Ÿ˜ฎ
                                Try with this example and show me how you can save the broken rocks.
                                (I have the last version 3.52)
                                cut.skp
                                  Anton_S
                                  Pilou, I'm speaking about the simulation tool, not animation tool. Press the Physics Toggle Play button and wait till the body is cut. As soon as it cuts, press the Physics Toggle Play button once again to pause. From there on you can 'save as' the model, but don't press the reset button, until you do say the model as another model, for instance, cut2.skp
                                    Alas it's that I make but when i Reload the "save as" that is again the start of the simulation!!! ๐Ÿ˜ฎ
                                    idem with your Cut2 file !
                                    A very vicious thing! ๐Ÿ˜„
                                      Anton_S
                                      Pilou, I re uploaded the cut2 file.
                                      One thing to remember is that after you save as, unhide all bodies and delete all the temporary hidden split bodies that were part of the original body. I already did this in the new cut2 file.
                                      cut2.skp
                                        Anton_S
                                        • V
                                          vlkster
                                          Ok, i'm having a problem with the control panel/sp inspector. when i name a hinge, using " or ' i don't get a slider bar in the control panel. If i leave off the " or ' than i get a error"script error: undefined local variable or method..."
                                          any help?
                                          thanks
                                            Anton_S
                                            @vlkster, are you saying that you wrote slider("or') in the controller?
                                            If so, then you got it wrong! The quotation marks surrounding the string must be the same!
                                            You may eigher use a double quote (") or a single quote ('), but you cant use a combination of both.
                                            This is what it should look like, slider("or") or slider('or').
                                            • 11
                                            • 3 / 11
