    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 351.1k Views 53 Watching
      Anton_S
      Thanks, Ash.
      Lately, I haven't created any SP either. I suppose, that is because I kinda lost passion in it.
      Phoenix is a good SP modeler. He's sharing some great stuff! ๐Ÿ‘
      Mr.K made some amazing things too. For instance, take a look at the Blue vs Red. You control the bot to get across the puzzle. It may appear mind boggling at first, but you'll get it mastered after some experience.
      • ashscottA
        ashscott
        Have you had any interaction with Phonic? I couldn't get a response when I tried some years ago - I wondered if he was only mandarin speaking.
        Just some stuff I do with Sketchup.
          Anton_S
          Nope, I haven't. I doubt that Phoenix even reads the comments. Usually people respond to their comments by updating the model description with responses, but I never seen him do that.
          • ashscottA
            ashscott
            One thing with Sketchyphysics I did wonder about - and I have no idea how to execute it - would be a "Cut" function. I have modeled saw milling machinery with SP in the past but always had to do some variation of a breakable joint to simulate cutting - due to the physical reactions in breaking a joint, you can understand that it wasn't pretty.
            Any idea how to cut an object so that it becomes two?
              Anton_S
              Piece of cake!
              Copy this piece of code into the scripted field of the body that you want to be cut:
              onTouch {
                split(self, 2)
              What happens is that it splits when it is touched by another body. Increasing the value will create more cuts.
              Of course, the code may be changed to have the body be split in another occasion, for instance when it touches a particular body, or at specified frame... If you provide some instructions I could easily write you a code.
              ๐Ÿ’š
              Here is a little example:cut_body_example.skp
              • ashscottA
                ashscott
                Very cool!
                I think I've seen some reference to this before.
                How would I control the cut so it occurs in a specific place?
                For example, on a piece of wood - to only be cut where the saw touches it?
                Ash
                  Anton_S
                  SP doesn't have this method, but I created my own.
                  https://3dwarehouse.sketchup.com/model.html?id=ua22b41f2-9654-4d70-898b-46d96e687272
                  https://googledrive.com/host/0B3qg8f4WrNdHWktZLXN5T2d6Tms/factory_slicer.gif
                  • ashscottA
                    ashscott
                    Anton,
                    I am stunned ๐Ÿ˜ฒ
                    I have tried so long to get a working function like what you've shown and have failed miserably - this is totally amazing. I hope you don't mind me pillaging your code for ideas?
                    Frenchy:
                    And also the white cross texture box "transparent" who is drawn
                    For some reason "Hidden Geometry" is getting turned on when I run an simulation the first time. Go >View>Hidden Geometry to turn it off.
                      Cool function! ๐Ÿ‘
                      But seems there is a glitch! ๐Ÿ˜‰
                      When I use these 2 menus!
                      After the Record Animation, replay etc...
                      Animation is stopped at the moment of the box must be "exploded" on the inclined plane! ๐Ÿ˜ฒ
                      Can you verify this ?
                      And also the white cross texture box "transparent" who is drawn! ๐Ÿ˜ฒ
                      This is the image of the result wished!
                      cut_body_example_glitch.skp
                        Thx ๐Ÿ˜„
                          Anton_S
                          The animation doesn't handle added and removed objects during simulation.
                          What happens behind the scenes:
                          When the body is about to be split, the body itself doesn't split, but rather two other bodies are added in similar form. The original body becomes hidden and set static, meanwhile the two added bodies take over the scene. When simulation resets the original body is unhidden, and the added split bodies are deleted. The animation tool is not complex. It does not record added and removed bodies during simulation.
                            Anton_S
                            @ashscott said:
                            Anton,
                            I am stunned ๐Ÿ˜ฒ
                            Thanks! I'd be impressed to see someone use my code ๐Ÿ˜„
                              Ok!
                              So, how do save the result of the normal result if you want to use it for something?
                              For example I want use the brocken rocks for an exposition! ๐Ÿ˜„
                              Now as soon has i want select them (broken rocks) the animation restart at the beginning! ๐Ÿ˜ฒ
                              In the past I was making that without problem! ๐Ÿ˜„
                              http://sketchucation.com/forums/download/file.php?id=123049&t=1
                              http://sketchucation.com/forums/download/file.php?id=123045
                                Anton_S
                                In the past when you selected a different tool SP didn't always deactivate properly, i.e. sometimes objects failed to be placed back to original locations, but now they do. I suppose, you relied on the bug.
                                One way to get all the split bodies is by playing simulation, pausing it at desired frame (i.e when you have broken rocks), and then save as another model. Open the new model, and you have the broken rocks!
                                • G
                                  gyrolen
                                  *Anton , can you help.?
                                  I cant get SP 3.5.2 to install on Windows 7, using Sketchup Pro 2014.
                                  Can you advise how to do it.?
                                  I have downloaded the .rbz file, but where do you put it SU2014 does not seem to use rbz files anymore.
                                  Thanks,
                                  Len
                                    Anton_S
                                    Thanks,
                                    Len
                                    There are two ways you can do it:
                                    Way one:
                                    • Download SketchyPhysics_3.5.2.rbz
                                    • Open SU2014 and navigate to (Menu) Window > Preferences.
                                    • In the preferences window navigate to Extensions tab and select Install Extension... button
                                    • From there, find your downloaded compressed file, and select open button, which will install the extension.
                                    Way two:
                                    Use PluginStore extension. Follow installation steps here: http://sketchucation.com/resources/plugin-store-download
                                    • G
                                      gyrolen
                                      Thanks,
                                      Len
                                      Way one:
                                      Way two:
                                      Thanks Anton ,your instructions worked fine, have got it going, now to learn how to use it. Len
                                      • T
                                        Trobius
                                        @anton_s said:
                                        Hello, William!
                                        Yes, SP doesn't have these methods. The API is quite incomplete.
                                        I just added getLifetime, getLifeStart, and getLifeEnd.
                                        Is there any other getter or setter functions you think shall be added before I post an update? Sorry, I can't think of any myself.
                                        Sorry for taking so long to get back to you. Thank you for the info!
                                        • T
                                          Trobius
                                          Oh, actually I did think of something else that I would like to see:
                                          Could you create a function which would allow you to retrieve the "parent" of an emitted object? (eg, toucher.getEmitter?)
                                            I must miss something! ๐Ÿ˜ณ
                                            So the animation can never play after the beginning of the cutting! ๐Ÿ˜ฎ
                                            Try with this example and show me how you can save the broken rocks.
                                            (I have the last version 3.52)
                                            cut.skp
                                            • 11
                                            • 3 / 11
