    [REQ] / Question if exists: Stamp Watermark Plugin
    21 Posts 7 Posters 1.9k Views 7 Watching
      My opinion is that the watermark image is not going to look very professional so if you don't mind, stick with the watermark. If you want a crisp, clean professional looking display, maybe it's time you spring for the pro version of SketchUp.
      By the way, complete your profile with SU version and operating system.
        I can't load...
        It's not because you are not a premium member, it's just because you are on the French Users Group and not yet registered! πŸ’š (icon "Settings" top left page)
        Anyway, if its not possible to be done inside Sketchup it's not really practical.
        If you don't want use Layout
        Why do you not make a simple Component with your editable "cartouche" ?
        Like this you can put it anywhere you want, with any text you want! πŸ˜„
        I have made that for a Print as any Scale πŸ˜‰
        So I don't see any problem to put any text and drawings as cartouche on the right bottom rectangle! Or anywhere you want! πŸ˜„
        http://www.polyloop.net/attachment.php?attachmentid=31119&d=1253957112
          driven
          lets not forget watermarks can be very elaborate, and a text element could be updated from a ruby webdialog...
          Remember this watermark?
          • H Offline
            harnstein
            Yes,
            as the sketchup api is meant to be very broad and flexible for developers I do think that it should be possible to access data, edit data in and out and even display that in certain ways. I just cant do it, my programming skills end at "if else then do "" ".
            Thanks to all of you for your input and opinions.
            @Pilou: that's something I will keep in mind, definitely of use for certain circumstances.
            I dont know how many of you are in the field of architecture but I guess quite a few - from my experience through some years such stamps are common and that for a good reason: to keep track of project's process, always visible, digitally or printed.
            Some would be thankful for something alike I think.
            Maybe there will be some one day, would be a project for me to get a little into programming, too.. πŸ˜‰
            still sketchin'
              glro
              something similar to what you ask is
              404 Not Found
              (sketchucation.com)
              maybe
                driven
                there are a number of inconveniences if you try using ruby...
                I created an editable title-block, and it makes an image to use as a watermark...
                In runs inside an SU webdialog, so it 'could' add model title and dates automagicly...
                but you need to add the resulting watermark image manually...
                also, it can't do transparency so, I'm not that happy with it...
                in this result, I can change ant text in a new webdialog, and then add the new watermark...
                why doesn't the forum allow .tiff files???
                export without transparency
                sort of works, should I pursue it?
                • KrisidiousK Offline
                  Krisidious
                  Another issue with the title-block in SU "Make" is that SketchUp Make (Free version) is no longer supposed to be used for professional (commercial) work. A title-block insinuates professional work. I'm not saying I agree with their business model, I think it's wholly unenforceable and rather self destructive as a marketing plan. However, one should be warned that this is part of the user agreement of SketchUp Make.
                  http://www.sketchup.com/license/b/sketchup-make
                  By: Kristoff Rand
                    Krisidious
                    I might add that someone using SketchUp 8 is held to the user agreement of that release and I'm fairly certain that professional work is allowed within it.
                    By: Kristoff Rand
                    • BoxB Offline
                      Inteloide's plugin Comment might be useful as a related sort of thing.
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56899
                      • H Offline
                        harnstein
                        @driven said:
                        should I pursue it?john
                        Wohoo.
                        5.times {thumb}
                        => πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                        still sketchin'
                        • H Offline
                          harnstein
                          @driven: Hmm, you have to plug it into the style as watermark again and manually from.the start at every change? Where does SU store that image then, no way to access that file and just resave it internally?
                          The plugin cant be made to set up a style (create new from existing with maybe various options about the watermark) automatically when started?
                          A webdialog with several text fields, manually and automatically filled, sounds good.
                          Saving a file with transparency (tif, png, tga) is not possible so far? Maybe with some workaround? Thomthoms vray tools export images with alpha whereas native su doesnt.. With the help of.some.code snippet maybe?
                          still sketchin'
                            driven
                            yes, you can open the directory to the new image, but you can't insert it with code...
                            I think you can also open the 'Styles' dialog with code on a PC, but I'm on a mac
                            The watermark is stored in the .skp file, when you export it you can see where it came from originally, but there's no re-load capability...
                            I know the one in your skp came from C/\Users\Standard\Desktop\1000px-Title_block_EN_ISO_7200_de.svg, so I can't update it...
                            not that I know of, I could possibly switch it in the binary file on a mac, but it would then need a restart and take longer then doing manually...
                            If you have a decent version of IE then you can use more modern approach, I have made a few like things like this for mac's, but the older IE just made a mess of them...
                            there are two versions, view.save_image and webdialog.save_image, view can save transparency...
                            probably the simplest is to open the new image in the default image editor using code, make transparent and save...
                            I'll look a little deeper, but no promises.
                            may send you some really basic bits to test, if that's ok
                            • H Offline
                              harnstein
                              Sure, send me some, I'd be happy to peek.
                              I'm on a crappy iPad now, I'll answer more indepth next week.
                              still sketchin'
