    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Animation Options
    5 Posts 3 Posters 280 Views 3 Watching
    • O Offline
      oo7ml
      Hi, i plan on spending the weekend learning various different animation methods in SU.
      I was wondering if someone could point out what options there are, when it comes to animation.
      So far i have seen two different types of animation:
      01 - Walkthrough - using various scenes to showcase you model
      02 - Sequencing - use the section plane to show your model coming together in different phases
      I'd like to explore what options there are for sequence animation. I'd like to be able to show / animate each part / phase of my model from the start, right through to the end.
      Is the section plane method, the only way to demonstrate the construction sequence of your model?
      Thanks in advance for your help.
      • cottyC Offline
        cotty
        One possibility to start: type "animation" in the search box (top right corner) ...
        my SketchUp gallery
        • O Offline
          oo7ml
          Thank you, i've tried your suggestion.
          I see a lot of different plugins etc for animation and not much other information that is really of any use.
          Can anyone suggest researching any other methods, other than the Section Plane, or is that really the only way to carry out sequence animation, without using a plugin... thanks in advance for your help.
            You can't except use some plugins!
            Mover and the new SketchyPhysics are good for that! ๐Ÿ˜„Rt!
            Or use special programs like Lumion or Lumen RT
            • O Offline
              oo7ml
              Ok great, thanks for your help.
