    [Plugin] s4u_Align
    45 Posts 16 Posters 33.8k Views 16 Watching
    • hdpvH
      hdpv
      Help me test my plugin on Mac.
      key Ctrl and Tab on Mac do work?
      I have attached the Spanish Language file.
      Suforyou
      http://www.sketchupforyou.com
      • hdpvH
        hdpv
        I have update my plugin:
        -Fix error
        -Hold Ctrl(PC and Mac)for multi-select -> Double click or Enter for finish.
        -Press Tab on PC, Alt on Mac for change align or align+move.
        Help me update the Spanish Language file.
        Suforyou
        • OxerO
          Oxer
          The Ctrl key on Mac is like right click, for this reason the multiselect doesn't work on mac.
          I have done the spanish translation but it is necessary fix the problem with Ctrl key on Mac.
          • hdpvH
            hdpv
            Thanks Oxer!
            I have fix it
            Ctrl on PC,Alt on Mac for multiselect.
            I don't know Tab key on Mac ,so I use Left or Right key for align+move ๐Ÿ˜„
            Suforyou
            • Bob JamesB
              Bob James
              Downloaded V 2.0.2 but the toolbar has only the red icon (the blue one is "missing")
              • hdpvH
                hdpv
                hi Bob!
                new version have only 1 icon for 2 function.
                Suforyou
                • OxerO
                  Oxer
                  I have created the Spanish Language File.
                  Spanish Langauge
                  • hdpvH
                    hdpv
                    Update s4u_AlignTool_v3.0.0
                    Align with axis ,construction line
                    Suforyou
                    • OxerO
                      Oxer
                      Thanks for the update but the Spanish Translation doesn't work.
                      • hdpvH
                        hdpv
                        Thanks,I had fix it.
                        please check again.
                        Suforyou
                        • jojo9J
                          jojo9
                          i downloaded your plugin yesterday and tested it today. Unfortunately, Su13 (Mac) wasnt able to load your plugin and i got following errors in the ruby console:
                          undefined method `instance_variable_defined?' for S4U;Module
                          Error Loading File s4u_aligntool.rb
                          I corrected some errors:
                          • i installed a missing ruby: langhandler.rb
                          • i changed line 4 to:
                          @s4u_menu=UI.menu("Plugins").add_submenu("Suforyou")  if !@s4u_menu #if !S4U.instance_variable_defined?(;@s4u_menu)
                          the same applies also for s4u_material!
                          now everything works. Please review your code, else thank your very much!
                            French Version ๐Ÿ˜‰
                            PS Seems there is no Toolbar! ๐Ÿ˜ฎ
                            Icon is existing aligntool_large.pngin the files ressource but not appear when Enable Menu Display Tools Bar!
                            (works fine for other s4u plugins translated or not)
                            PSS I see that I have not translated Titles for s4u-Make Face and s4u-Components! ๐Ÿ˜ณ
                            And have some more Plugins to translate! A study summer! ๐Ÿ˜„
                            fr.zip
                            • hdpvH
                              hdpv
                              Merci Pilou!
                              I will fix it in next version.
                              Suforyou
                              • C
                                Chelmite
                                Is there any help on how to use this extension? I want to align a number of components. I watched your video, but I have no idea what you are trying to do in each sequence in the video, nor what keys or mouse actions you are taking.
                                Thanks for any help you can give.
                                hdpvH 1 Reply Last reply
                                • hdpvH
                                  hdpv @Chelmite
                                  @Chelmite
                                  You hold the shift key to select more components.
                                  Suforyou
                                  • 2 / 3
