    [Plugin] s4u_Align
    45 Posts 16 Posters 31.2k Views 16 Watching
    • hdpvH Offline
      hdpv
      hi JBJDesigns!
      You can see status bar for instruction,
      -select target edge(face)
      -then press Ctrl if you want multiselect
      -select aligned edge(face)
      -press again Ctrl for finish select.
      press Tab for change "align" or "align and move"
      Suforyou
      http://www.sketchupforyou.com
      • hdpvH Offline
        hdpv
        press Ctrl,not hold
        1-select target edge(face)
        2-then press Ctrl if you want multiselect
        3-select aligned edge(face)
        4-press again Ctrl for finish select.
        Suforyou
        • unclebimU Offline
          unclebim
          Wonderful plugin! Thanks! I use the Q JS Align plugin all the time but it works only along the three axes and I believe your plugin will go on top of the most used list now.
          • hdpvH Offline
            hdpv
            Update s4u_AlignTool_v1.1.0 (25 April 2014)
            -Press UP, DOWN or Right Mouse for Mirror after align face
            Suforyou
            • hdpvH Offline
              hdpv
              s4u-AlignTool 2.0.0 (10 June 2014)
              • align OUT group,multi-align with press hold Ctrl key.
                http://sketchucation.com/pluginstore?pln=s4u_aligntool_v1.0.4
              Suforyou
              • OxerO Offline
                Oxer
                Thanks for the plugin, I created the Spanish Language File. I changed in the translation:
                Ctrl --> Ctrl(Pc)/Alt(Mac)
                The Ctrl key doesn't work on Mac.
                Spanish Language
                • hdpvH Offline
                  hdpv
                  Thanks Oxer!
                  I haven't checked for Mac yet.
                  I will update later.
                  Suforyou
                  • kenK Offline
                    ken
                    Installed the last version from the store, receive this error message now.
                    Error Loading File C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb
                    Error: #<NameError: uninitialized constant S4U::S4u_AlignTool::S4u_aligntoolStrings>
                    C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:11:in <module:S4u_AlignTool>' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:6:in module:S4U'
                    C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_aligntool/s4u_aligntool_menu.rb:3:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:14:in register_extension'
                    C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:14:in <module:S4u_AlignTool>' C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:4:in module:S4U'
                    C:/Users/Ken/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/57-s4u_aligntool.rb:3:in `<top (required)>'
                    Note: Re-installed from store. Not sure what happen, but all my toolbar were displaced.
                    I see that no one else seems to be having this problem.
                    Thanks for you replies.
                    Ken
                    • hdpvH Offline
                      hdpv
                      Hi Ken!
                      Delete files:
                      and folder
                      Don't rename file and folder plugin.
                      Suforyou
                      • kenK Offline
                        ken
                        @hdpv said:
                        Hi Ken!
                        Delete files:
                        and folder
                        Oops! my bad, that file was from your Version 1.0.5. I believe you did not have a toolbar with that version, so I added a toolbar. Note, it didn't crash until this version. So why would I rename a file when adding a toolbar. Because I name the icon with the number, and add the number to the tool text. This way I have a reference on what the icon's plugin is, and what the is the name of the icon. On some plugins, it is almost impossible to associate the toolbar icon with the actual RB file. So I guess it caught up to me.
                        So thank you. Will now be more careful.
                        Ken
                        • OxerO Offline
                          Oxer
                          Hi, I tested the plugin on mac OSX 10.9.3 & SU and it works fine. πŸ‘
                          • hdpvH Offline
                            hdpv
                            Thanks Oxer!
                            I will publish it.
                            Suforyou
                            • OxerO Offline
                              Oxer
                              See the folder "es" there is another folder called "es" into it too. Fix this little problem.
                              • hdpvH Offline
                                hdpv
                                Help me test my plugin on Mac.
                                key Ctrl and Tab on Mac do work?
                                I have attached the Spanish Language file.
                                Suforyou
                                • hdpvH Offline
                                  hdpv
                                  I have update my plugin:
                                  -Fix error
                                  -Hold Ctrl(PC and Mac)for multi-select -> Double click or Enter for finish.
                                  -Press Tab on PC, Alt on Mac for change align or align+move.
                                  Help me update the Spanish Language file.
                                  Suforyou
                                  • OxerO Offline
                                    Oxer
                                    The Ctrl key on Mac is like right click, for this reason the multiselect doesn't work on mac.
                                    I have done the spanish translation but it is necessary fix the problem with Ctrl key on Mac.
                                    • hdpvH Offline
                                      hdpv
                                      Thanks Oxer!
                                      I have fix it
                                      Ctrl on PC,Alt on Mac for multiselect.
                                      I don't know Tab key on Mac ,so I use Left or Right key for align+move πŸ˜„
                                      Suforyou
                                      • Bob JamesB Offline
                                        Bob James
                                        Downloaded V 2.0.2 but the toolbar has only the red icon (the blue one is "missing")
                                        • hdpvH Offline
                                          hdpv
                                          hi Bob!
                                          new version have only 1 icon for 2 function.
                                          Suforyou
                                          • OxerO Offline
                                            Oxer
                                            I have created the Spanish Language File.
                                            Spanish Langauge
                                            • 2 / 3
