    How did the great Alex Hogrefe do it ?
    Scheduled Pinned Locked Moved Post Processing
    39 Posts 3 Posters 23.2k Views 3 Watching
    • alexjoA Offline
      alexjo
      Yeah, I checked the sun's color before I saw your post and it was white by default.
      It is definitely the preset then. Thanks tons, I think it's working now. Is this decent ?
      http://i.minus.com/jI2M7hv6aSIpN.jpg
      & I have one little issue now. I do not like how unrealistic the shadows look, no matter how much I move the model around the sun. Do you change the location/time like 3dsMax Mental Ray, or do you just keep testing different radius values ?
      • massimoM Offline
        massimo Moderator
        πŸ‘
        If with "unrealistic" you mean "hard" then yes, tick "soft shadow" in the scene settings panel and play with sun's radius and multiplier.
        • massimoM Offline
          massimo Moderator
          If you want to change the sun's position then..
          • alexjoA Offline
            alexjo
            Ugh, thanks. That last tip was needed.
            Btw, the 4 Clay presets differ in quality and render time, right ?
            have you changed the gamma correction for your render sample ?
            • massimoM Offline
              massimo Moderator
              Right.
              No. I didn't change anything.
              • alexjoA Offline
                alexjo
                Hmm, best so far.
                http://i5.minus.com/jX0c9NPKRbu0D.jpg
                • massimoM Offline
                  massimo Moderator
                  Well if you want to try to match the look of the pic you posted in your first post you have to use softer shadows I guess.
                  • alexjoA Offline
                    alexjo
                    Oh oh, did my post get deleted lol
                    • massimoM Offline
                      massimo Moderator
                      No post was deleted. You sent a PM to me. πŸ˜‰
                      Here is what I replied: have you tried what I suggested? Tick "soft shadow" and increase the sun's radius?
                      • alexjoA Offline
                        alexjo
                        Lmao, that was confusing.My bad.
                        I actually did that right off the bat. But saw no difference. The radius changes the position of the sun, and it takes me a couple of minutes to get it back where i want it to be.
                        • massimoM Offline
                          massimo Moderator
                          Odd, that should not happen. Would you mind to post the scene?
                          • olisheaO Offline
                            olishea
                            larger radius does not change the sun position. Large radius = softer shadows. Small radius = sharper shadows. You must have soft shadows checked to see the effect of changing the sun's radius.
                            I really love how this project is going, I find plan shadow studies very pleasing on the eye.
                            oli
                            • alexjoA Offline
                              alexjo
                              Sure.
                              Scene3.rar
                              • massimoM Offline
                                massimo Moderator
                                Ok, here is a try. Raw KT output.
                                Of course, as I said before, you can change the softness of the shadows by changing the radius of the sun.
                                scene_3.zip
                                • alexjoA Offline
                                  alexjo
                                  Legit amazing.
                                  • alexjoA Offline
                                    alexjo
                                    Could you pleas tell me how you managed to achieve that clear white look ?
                                    & I see you have arranged the file, and added other elements.
                                    • massimoM Offline
                                      massimo Moderator
                                      Well I've posted the scene, have a look at it. The render is a raw output of that scene, so just pick a clay render preset (I think I've used the 22 if I remember well, but more or less any clay preset will work) and render it. I added nothing, just tuned sun's multiplier and radius.
                                      • massimoM Offline
                                        massimo Moderator
                                        Oh and, if i remember well, also reduced the gamma from 1.5 to 1.2. Anyway you have the scene to look at.
                                        • alexjoA Offline
                                          alexjo
                                          Much appreciated, sir.
                                          Have a nice day.
                                          • massimoM Offline
                                            massimo Moderator
                                            My pleasure. πŸ˜„
