    Testing Ruby VALUES in C-extension.
    69 Posts 6 Posters 6.1k Views 6 Watching
    • tt_suT Offline
      tt_su
      @jolran said:
      Thomthom, you said one should alter the Ruby headers.
      Can I have some more info on that? I assume we are talking about ruby.h file included in external dependancies ? Or do you mean doing changes in the project properties.
      In any case I'm a bit lost..
      Yes, ruby.h and/or config.h. I don't recall exactly right now. But if I recall, one of the things where that Ruby define a "inline" macro that conflicts with VS2013.
      @jolran said:
      Sorry about the noob questions 😳
      No worries! I just learned this stuff myself and it's only due to my great colleagues helping me along. I'm still learning.
      I'll try to go through the upgrade process again and make notes to what I had to change.
      • tt_suT Offline
        tt_su
        Check out the VS2013 branch in my private fork:
        https://github.com/thomthom/ruby-c-extension-examples/tree/VS2013
        I just checked in a commit with some changes that should make it compile.
        https://github.com/thomthom/ruby-c-extension-examples/commit/0d4090d47fc563754b57efcc003114e3973cabc7
        There might be other changes required as you pull in more libraries though.
        • jolranJ Offline
          jolran
          Exellent!!
          Yeah, that's exactly what's happening. That also leads to hundreds of other sub-error messages.
          I give it a try and report back!
          Thanks again. πŸ‘
          • jolranJ Offline
            jolran
            It worked! 😍 To make it simple for myself, I just launched your version..
            I can now launch the debugger and Sketchup's correct version launch, all good to go.
            Just some rookie notes: (things that may be taken for granted by proffesionals πŸ˜‰ )
            • Working with the ruby console in debugg-mode, theres no need to require the module. Just call the C-extension functions.
            * To switch release-version go into Configuration Manager (See pic below). One might think changing Release from 2.0 to 1.8 in the dropdown meny changes the project settings, But it don't(?). Not for me it diden't..
            EDIT: Scratch that. It worked after a project clean.
            Thanks a million Thomthom!! Now it's only the small detail of adding code, left to do.
            • tt_suT Offline
              tt_su
              That's due to how the project is set up to launch SketchUp with the loading-helper that loads the extension. It's not automatic unless you configured the project to do so.
              We need to add more info for the project. Please fill out issues on the GitHub bug tracker to help us keep track of this.
              @jolran said:
              • To switch release-version go into Configuration Manager (See pic below). One might think changing Release from 2.0 to 1.8 in the dropdown meny changes the project settings, But it don't(?). Not for me it diden't..
              When you change from the drop down menu that will change what is built. In order to build multiple go BUILT > Batch Build
              • tt_suT Offline
                tt_su
                Ah, post edited... πŸ˜„
                • jolranJ Offline
                  jolran
                  Yeah, sorry about that.
                  I was to exited. πŸ˜„
                  • tt_suT Offline
                    tt_su
                    I might have mucked up the debug config with that VS2013 branch... Just looked at the diff of changes and something looks amiss. Just so you are aware.
                    I'm not sure I have time until next week to look into that.
                    • jolranJ Offline
                      jolran
                      Ok, thanks for telling.
                      I havent tested it much yet. Will dig in more intensly after the weekend.
                      Anyway it seams to be working correctly when just calling functions from the C module in the Ruby console.
                      • jolranJ Offline
                        jolran
                        So I finally managed to bring in 100 000 points convert them to C++ class and then convert back to Sketchup Point3d objects.
                        Timing the response back in Alex S-Ruby console clocks ~ 0.50 which is amazingly fast.
                        Did some other tests, bloody hell it's blitz.. πŸ˜„
                        However if I clock a new "puts time" in the row after the C -callback. it gets increasingly
                        slower for each C-functioncall. πŸ˜•
                        C-callback response still clocks about the same each time..
                        Is it the Ruby garbage collector running ? Adding this amount of points aught to slow Sketchup down, I know..
                        So I take it one cannot rely on C-response when things are "ready" to go forth in Ruby ?
                        For ex if I expect an array as responce will there be an error in following code.
                        Or does not following code execute until the array is ready ?
                        (havent tested stuff on so many points yet)
                        I don't think I'm creating a memory leak in C++ since I have seen the destructor activate during some tests. And this test is done within 1 function so.. Points in points out..
                        Note: I did this in debug-mode(SU 2013), so maybe that affects threading or something.
                        • tt_suT Offline
                          tt_su
                          Debug builds are a lot slower than release as it execute a lot more debug code and doesn't have any optimizations enabled.
                          Hm... not sure. Might be. When I run performance tests in Ruby I tend to call GC.start at the beginning of my profiling to ensure the GC is reset before each test. Otherwise you have no idea when it will trigger.
                          Your tests, does it only create Point3ds, or are you also creating and erasing geometry?
                          • jolranJ Offline
                            jolran
                            Hi Thomas.
                            For that test I was sending in Ruby array with Sketchup Point3d's to a C++ function.
                            That function converted Ruby points to a simple C++ class representing Point3d.
                            That same function also converted back the C++ points to Sketchup Points.
                            So the return VALUE was a Ruby array of those points.
                            Not very useful, but interesting. Got to start somewhere...
                            I use vectors as containers in C++, don't know if that is the way to go with Ruby C++-extensions. Vectors seam to be quite used though..
                            Do you use maps with Ruby hashes ? I havent tested yet. Vectors seams more flexible.
                            What you say about Debug builds seams to hold true.
                            I managed to create an implementation for the points-indexing-triangulation I was talking about earlier, and ran that in my plugin compiled. Really fast compared to the Ruby version πŸ˜„
                            It still has some quirks and needs refinements, but it was good enough to make a realistic comparison.
                            Ahhh yes. That's smart. Will try that, thanks.
                            Edit: Ehh duh! I wasent aware one could create breakpoints and step into the code while debugging in Sketchup. Most useful πŸ’š
                            • tt_suT Offline
                              tt_su
                              Yes, vectors are your usual go-to container.
                              map and unordered_map is what one use instead of Ruby Hash. Unordered map is usually a little bit faster, but a C++11 feature.
                              set and unordered_set is similar to - surprise - Ruby Set. πŸ˜„
                              πŸ˜„ One thing that cought me off guard is the breakpoints doesn't always work in Release due to compiler optimization. Visual Studio 2013 even has a nice profiler which let you get detailed profiling info of your C++ code. (Should do a quick tutorial on that once.)
                              Speaking of debuggers, you know taht from SU2014 you can hook up Ruby debuggers for Ruby code in SketchUp?
                              https://github.com/SketchUp/sketchup-ruby-debugger
                              It's so much nice to be able to set breakpoints and step than litter the code with puts.
                              • tt_suT Offline
                                tt_su
                                Btw, when you create a vector where you know the final number of item, call reserve to allocate enough memory in advance as you then avoid expensive memory reallocation as you populate the array. Even if you have only a rough estimate it's ok.
                                You can do something similar C++ std::vector<>.reserve with the Ruby C API by calling rb_ary_new2. You provide the number of final elements and it will allocate enough memory of the object up front.
                                • jolranJ Offline
                                  jolran
                                  Yes that would off course be very nice.
                                  Realized this thread is staring to get really packed of usefull information. Unfortunately in some time it will be burried in the forum.
                                  Maybe a C-extension sticky-thread or something similar wouldent hurt. Or maybe this old topic is being used for that purpose ?
                                  http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=41077%26amp;p=363978
                                  One might not feel inclined to post silly C++ questions in that old thread.
                                  Something like "Ruby C extensions for dummies" would be more approprioate. πŸ˜„
                                  • jolranJ Offline
                                    jolran
                                    Well this keeps gets better and better. I did not know that.
                                    Have been sending puts to ruby console from C++ but that wont work when stepping over code, so this sounds great.
                                    Handy! I do a lot of conversions so that will help. I'm not in a mode of optimizing code yet, but suppose best practices are worth picking up at an early stage. πŸ˜„
                                    I'm experiencing some problems in a loop here. Don't know if you can spot whats going on..
                                    Have just included the important parts for brevity.
                                    I have a nested ruby array of points curves. The points are coming from a getter-method-call in a Ruby-class. The @points can be of vary length.
                                    The problem is that RARRAY(curve_rbPoints)->len always gives the same length, so the code fails..
                                    Is it because I'm hoisting the variable ?
                                    I just found this bug so havent tested much yet..
                                    NOTE: I should mention it get's the correct length 1st time round.
                                    edit: nope.
                                    // VALUE curves = [ curve, curve, etc ] // @points = [point3d, point3d, etc]
                                    	const VALUE get_points = rb_intern("get_points"); //getter method for @points
                                    	int curves_size = RARRAY(curves)->len;
                                    	VALUE curve, curve_rbPoints;
                                    	int rCrv_len, i;
                                    	// Inside a loop
                                    	for (i = 0; i < curves_size; i++) {
                                    		curve = rb_ary_entry(curves, i); //My class Ec-curve instance"
                                    		curve_rbPoints = rb_funcall(curve, get_points, 0); //Gets @points in current curves[index]
                                    		rCrv_len = RARRAY(curve_rbPoints)->len; //WRONG LENGTH!
                                    //Nested for loop is coming based on rCrv_len length
                                    • tt_suT Offline
                                      tt_su
                                      edit: nope.
                                      That only works with older Ruby I think, 1.8.6 or earlier. After that they changed the data structure so you should use the RARRAY_LEN macro. That macro doesn't exist on early Ruby so I conditionally define it:
                                      #ifndef RARRAY_LEN
                                      #define RARRAY_LEN(x) (RARRAY(x)->len)
                                      #endif
                                      https://bitbucket.org/thomthom/tt-library-2/src/24f6daa97b4ed67836d67ad4ac2f2c2806ca2a6e/Ruby%20C%20Extensions/Bezier/TT_Geom_Bezier.c?at=Version%202.9#cl-14
                                      When you look up info on Ruby C Extension programming make sure you check the date of the source. And refer to a recent version of README.EXT.
                                      I also find a lot of clues in "Ruby MRI identifier search": http://rxr.whitequark.org/mri/ident
                                      • jolranJ Offline
                                        jolran
                                        Ahhh. A solution perhaps πŸ˜„
                                        I'm running Sketchup 2013 in debug mode. So it should be running Ruby 1.8.6 though ?
                                        This has been a very annoying problem to solve. I'm clueless.
                                        There's no error but irratic behavior with wrong values which makes it hard to track.
                                        I was thinking it had something to do with me calling instance method from a class
                                        sort of thing. The "curve" is an instance from a class I created and not a Sketchup curve, but I assume you got that part.
                                        I suppose I could make the Ruby array an accessor and then use instance var get, but I rather not.
                                        Will try your code when I get to my workstation later.
                                        • tt_suT Offline
                                          tt_su
                                          I don't see anything immediately wrong. But have you checked and validated the input data?
                                          Feels like there's some issue not located to that small snippet you have. If a complex case fails, try to reproduce in a small standalone case.
                                          Btw, rb_intern returns ID, not VALUE. At least in Ruby 1.8 they are typedef of the same, but you cannot be sure of that and should make sure when a function use ID vs VALUE.
                                          • tt_suT Offline
                                            tt_su
                                            Also, you're using out C++ example? Then you don't have to declare all variables in advance. That's very old C syntax. Even newer C syntax allow you to declare variables when you need them.
                                            • 2 / 4
