    Testing Ruby VALUES in C-extension.
    69 Posts 6 Posters 9.1k Views 6 Watching
      Anton_S
      Interesting topic guys, keep it up πŸ‘
      Something tells me SU2015 could have support for plugins in C++. Would be awesome.
        Anton_S
        There is a topic that compares the speed of programming languages to πŸ˜„ http://www.unlimitednovelty.com/2012/06/ruby-is-faster-than-python-php-and-perl.html
        Unfortunately Ruby is ~50 times slower than C++. I think no one would disagree with SketchUp API in C++ and plugins that consisting of cpp files.
        • jolranJ
          jolran
          +1
          • jolranJ
            jolran
            Awesome answer man! Very rich post πŸ‘
            I absorb your recommendations, comments are not necessary πŸ˜„
            (nice links btw, now I finally understand Log(n)!).
            Regarding the Hash lookups. Yes they are fast if using the key. But if looking for the key from a value it's a bit worse. And in my case I see no way around avoiding that lookup.
            I'm doing vertex indexing.
            http://www.opengl-tutorial.org/intermediate-tutorials/tutorial-9-vbo-indexing/
            Where I sometimes have to insert new uniq points, and get the index from a point when sorting the indexed arrays by some algoritm.
            If you are diving into Ruby C Extensions I would recommend using our GitHub projects which is in fact a C++ Extension.
            I am using the C++ hello_world tutorial as staring point, and expanding on that.
            How do you debugg BTW ? It's a bit enoying haiving to quit Sketchup when pasting in .so files. Windows don't allow me to copy and paste over so files that are in use by Sketchup 😞 One cannot unload dll's, right ?
            There is a debug and release modes(I'm in VS 2010 Ultimate BTW) but I can't launch debugger with SU8 and debug 1.8.
            The original project seams to be linked to Sketchup 2013(which I don't have) so I tried to link to SU8.exe to no avail.
            What I've seen the recommendation is to use VS 2010 (if windows). Unfortunately VS 2010 lack some of the nice C++11 features, but I guess we can live with that.
            A bit difficult to follow some newer C++ tutorials though.
            Constructors and destructor are your friend
            Yeah, but scary subject. I followed some tutorials here:
            http://www.microsoftvirtualacademy.com/Content/ViewContent.aspx?et=5730%26amp;m=5723%26amp;ct=23224
            recommending RAII with uniq pointers inside try and catch block. So in our case one could use that to ensure longjumps to Ruby if an Exeption ?
            (Way over my head at this stage, but interesting.)
            I havent found much info about dealing with objects in C++ and memory handling in C-extensions yet.
            I presume the Alloc_n -> xfree trick does not apply in this case ?
            Or maybe it's the same in C++ if using a struct and not Class.
            A struct must be perfect choice for Point3d in any case ?
            Once again. Thanks a lot for that post. Very useful.
            • tt_suT
              tt_su
              Why are you looking for a key by value? Sounds inverted.
              Are all your values uniq?
              You could keep a second hash with reversed pairs... but then again, it sounds odd and I don't know the full scope of your task. (And I haven't finished reading the rest of your post. :p)
              • jolranJ
                jolran
                Yeah πŸ˜„ I may very well have a design-flaw on my hands..
                But it is a well-used pattern.
                I'm using a Hash with uniq points. And then building different geometries from those points for rendering Open_Gl Triangles and edges.
                Normally the ordering of points for face-triangles VS face-edges are different.
                So one ends up with 2 arrays of points. 1 for GL_Triangles , 2 for GL_edges.
                NOW, Instead of having 3 Containers filled with points. You have only 1 HASH. And 2 Arrays of integers that act as lookups-key to the Hash.
                In terms of space this is more lightweight. But The greatest advantage is when for ex Transforming all that geometry. I only have to transform the uniq points.
                Using Polygonmesh for this would be better, but one cannot update or purge a polygonmesh.
                And I would need to build the 2 arrays anyway, so I have my own class for this purpose.
                There are some mechanics for sorting and then I have to lookup the key from a value.
                Hope that makes the subject clearer..
                • tt_suT
                  tt_su
                  It is in fact set up to SU2014. When you click run it should launch SketchUp 2014 and a supplementary RB script should load the c extension for you.
                  Indeed. I have VS2013. You can load the project just fine, but if you want to use it as-as you must decline to upgrade it.
                  If you do choose to upgrade you must modify the Ruby headers as they are not configured to VS2013. That's what I do for my projects now because I like C++11 so much with it's lambdas, smart pointers, ranged for loops and other goodnesses. πŸ˜„
                  No, you cannot catch Ruby's long jumping error-raising. However, in my testing, if Ruby long jumps out of a function destructors are called - which is a good thing. With C++11 when you have smart pointers that makes memory management a breeze. But if you use plain ol' naked pointers you must take more care. You must either use rb_rescue or re_ensure (which are horrible constructs) or wrap all your memory allocation into classes (which is a good thing to do anyway.)
                  I recently made a wrapper that converts C++ exceptions into Ruby errors, so I can throw my own custom errors around in my C++ code and have the Ruby layer catch that. Pattern seems to be working quite well, keeps error handling code clean.
                  From what I've read on best practices people recommend using classes over structs - as a general rule. The reason is that you make accessors to the data members which ensures that you don't expose them directly. Why is that good? Because if you later need to change one of the member to be calculated on demand you just change the accessor method and not every piece of code that points to it.
                  Alloc_n and xfree are C ways of dealing with memory - which is might kill small bunnies. With C++ you don't need to deal with that.
                  Exception: if you need to wrap a C data structure in Ruby you need to use xfree to clean up the memory when the Ruby garbage collector collect the object.
                  Happy to help! I'm glad more people are looking into more advanced ways of creating extensions. πŸ˜„
                  • tt_suT
                    tt_su
                    I'd try to wrap that whole calculation in a C extension. C++ extension that is. πŸ˜‰
                    I'm dealing with this right now for my subdivision extension. Working on live update of the mesh when you adjust the creasing. (And any other part of the mesh.) Lots of things to keep in sync - lots of ways to get it wrong.
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      This is all very interesting!
                      • tt_suT
                        tt_su
                        Btw guys, have you heard of DevCamp we're doing in Greece at the end of September?
                        http://forums.sketchup.com/t/sketchup-developer-event-devcamp-2014/255
                        If you are able to come we can probably do a C extension session if there is enough interest.
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          That would be great!
                          I'm looking forward to meet you guys there πŸ˜‰
                          • jolranJ
                            jolran
                            Wooah! You seam to have gotten far into this C++ business. Well done!
                            I should probably have mentioned that these containers are long lived. The may exist during the whole program.
                            I do have some more special methods for dealing with other objects(node-editor project) but for this purpouse it would be most intersting to se an example on how you do things in C++ in an isolated case.
                            In fact, It may be interesting for the whole communitive. (as long as we can use/abuse/expand on it in our projects, that is πŸ˜‰ )
                            Ah ok. Well My brother gave me a seat of VS 2010 ULTIMATE. Can't really afford upgrading that..$$$$ 😲
                            Edit: That doesent happend for me. I get linking errors. I'll look into it more. I wasent aware I could debugg it like that. Sounds a bit more flexible πŸ˜„
                            Ehh. 😳 I don't have 2014 either.. Not Pro anyway. Make will work ?
                            edit: I linked to Sketchup8 which it now seams to find, but I'll keep getting errors.
                            'SketchUp.exe': Loaded 'C:\Windows\SysWOW64\mscms.dll', Cannot find or open the PDB file
                            I think I may have linked the RubyStartup "$(SolutionDir)Ruby$(Configuration).rb" file wrong..
                            For the rest of the information. πŸ‘
                            Very informative post this is turning out to be!
                            • jolranJ
                              jolran
                              Ahhh, Greece. Man, that would have been nice...
                              • tt_suT
                                tt_su
                                Visual Studio Express editions are free. Are you using any features in Ultimate which Express doesn't have? (VS2013 is really nice - I like it so much more than VS2010.)
                                And using the Test Explorer with the Google Runner extensions is also very nice for setting up unit tests. πŸ˜„
                                Make will work. Any version of SketchUp that support the RubyStartup argument. (I don't recall when that was added.)
                                You will get complaints about VS not finding debug symbols for SketchUp. You can ignore that. for mscms.dll, that's a MS component. If you enable the Microsoft Symbols Server it will load most of the PDBs:
                                • tt_suT
                                  tt_su
                                  You can't make it? 😞
                                  • jolranJ
                                    jolran
                                    Ah, dang! I just looked it up, it's allowed to do commersial products with the express-version. Well, that's good to know though in any case.
                                    I'm not bound to any features. This all for Sketchup development.
                                    I might try 2013 later. It took quite a while to install 2010 and not without hassle..
                                    Right. I actually had 2013 and 2014(beta-tester version) installed.
                                    So I can link to those.
                                    Great! 1 step closer. I still get the PDB complaint but later, but VS seams to be loading a lot of symbols in the background now.
                                    Should I locate the project directory in the "symbol pdb locations" ?
                                    I don't know what I doing..
                                    Doubt it. This "programming lifestyle" is limiting my budget.
                                    • jolranJ
                                      jolran
                                      I'm noticing a lot of features lacking in 2010 the more I get into it. So I installed VS 2013.
                                      (It's quite annoying working with the lack of stl initiallizers in 2010 btw)
                                      Indeed I get a conversion promt when starting up Hello_world Project.
                                      So I did convert.
                                      Thomthom, you said one should alter the Ruby headers.
                                      Can I have some more info on that? I assume we are talking about ruby.h file included in external dependancies ? Or do you mean doing changes in the project properties.
                                      In any case I'm a bit lost..
                                      Sorry about the noob questions 😳
                                      • tt_suT
                                        tt_su
                                        Yes, ruby.h and/or config.h. I don't recall exactly right now. But if I recall, one of the things where that Ruby define a "inline" macro that conflicts with VS2013.
                                        No worries! I just learned this stuff myself and it's only due to my great colleagues helping me along. I'm still learning.
                                        I'll try to go through the upgrade process again and make notes to what I had to change.
                                        • tt_suT
                                          tt_su
                                          Check out the VS2013 branch in my private fork:
                                          https://github.com/thomthom/ruby-c-extension-examples/tree/VS2013
                                          I just checked in a commit with some changes that should make it compile.
                                          https://github.com/thomthom/ruby-c-extension-examples/commit/0d4090d47fc563754b57efcc003114e3973cabc7
                                          There might be other changes required as you pull in more libraries though.
                                          • jolranJ
                                            jolran
                                            Exellent!!
                                            Yeah, that's exactly what's happening. That also leads to hundreds of other sub-error messages.
                                            I give it a try and report back!
                                            Thanks again. πŸ‘
                                            • 2 / 4
