    Plugins auf Deutsch
    Scheduled Pinned Locked Moved Deutsch
    15 Posts 9 Posters 14.5k Views 9 Watching
      Several of my Plugins - e.g. 'Manifold', 'CofGravity', 'CymaCurve', '2Dtools set' and the 'Extrusion Tools set' have the capability of being translated into any language with a 'locale' setting, via a Ruby called 'deBabelizer'.
      Inside the '2Dtools' subfolder or the 'TIGtools' subfolder that comes with the tools and goes in the 'Plugins' folder there are 'lingvo' files. The base one are in EN-US [American English], many tools came with premade FR [French] and ES [Spanish] 'lingvo' files, these have been 'improved' by users over time, and reissued with better translations, some users have added 'lingvos' in Chinese, Farsi etc.
      If you want German translations [DE] then you can make your own 'lingvo' files - let's assume the tool is called 'CofGravity' then find and copy the CofGravityEN-US.lingvo version as CofGravityDE.lingvo and add translations for the text for the menu and other prompts as you wish...
      For example the first line of the 'Center of Gravity' [Schwerpunkt] tool's 'lingvo' reads:
      C of G: Sorry, this is Version >= 6 Tool !<==>C of G: Sorry, this is Version >= 6 Tool !
      so to the right of the <==> symbol add your German translation:
      C of G: Sorry, this is Version >= 6 Tool !<==>**Schwerpunkt: Sorry, das ist Version >= 6 Werkzeug!**
      If you publish your DE 'lingvo' files with the tools' threads then others can use them and I can add them to the zip file of files at the next update...
      Mehrere meiner Plugins - zB 'Manifold', 'CofGravity', 'CymaCurve', '2Dtools gesetzt' und die 'Extrusion Tools gesetzt' haben die Möglichkeit des Seins in eine andere Sprache mit einem 'locale', Einstellung über ein Ruby Übersetzer benannt 'deBableizer'.
      Im Inneren des '2Dtools' Unterordner oder die 'TIGtools' Unterordner, mit den Werkzeugen kommt und geht in den 'Plugins' Ordner gibt es 'lingvo'-Dateien.
      Die Basis eins sind in EN-US [Amerikanisches Englisch], kamen viele Werkzeuge die mit vorgefertigten FR [Französisch] und ES [Spanisch] 'lingvo'-Dateien, diese wurden "verbessert" werden von den Benutzern über die Zeit und mit besseren Übersetzungen, einige neu aufgelegt Benutzer hinzugefügt haben "lingvos" in Chinesisch, Persisch, etc.
      Wenn Sie möchten, Deutsche Übersetzungen [DE], dann können Sie Ihre eigenen 'lingvo'-Dateien - Nehmen wir an, das Tool heißt 'CofGravity' dann finden und kopieren Sie die CofGravityEN-US.lingvo Version zu CofGravityDE.lingvo und fügen Übersetzungen für den Text für das Menü und andere Anweisungen, wie Sie wollen ...
      Zum Beispiel die erste Zeile des 'Center of Gravity' [Schwerpunkt] 'lingvo' lautet:
      so auf der rechten Seite des Symbols <==> Schreibe einen deutschen Übersetzung:
      Wenn Sie veröffentlichen Ihre DE 'lingvo'-Dateien mit den Threads dann andere sie nutzen können, und ich kann sie auf die ZIP-Datei von Dateien hinzufügen, um das nächste Update ...
      [I hope my German is at least understandable - Ich hoffe, dass mein Deutsch mindestens verständlich ist]
      • BurkhardB
        Burkhard
        Danke TIG, sieht gut aus!
        Einige der Plugins sind übersetzbar, in dem nur eine Datei mit den Übersetzungen gemacht wird und -wie bei TIG- nur hinzugefügt werden.
        Arbeiten, die ich auch schon gemacht habe. Wäre schön wenn sich auch mehr beteiligen würden.
        Zu Twilight: Es ist bereits in der Software Deutsch wählbar und damit verfügbar.
        Zu LightUp: Ich habe es gerade übersetzt und es wird mit der nächsten Version kommen.
        1001bit Tools sind übersetzt ( letzte Version war 1.7....ein update kommt bald )
        http://www.ia-plus.de
          Arch
          Hallo Burkard,
          danke für die Info.
          ARCH
          • T
            Tatjana
            Auch von mir ein Danke für die Info - ich habe dasselbe Problem mit Plugins auf Englisch - ich verstehe sooo viel falsch - dass es einfach nervt - danke!
            LG
            Tati
            • jo-keJ
              jo-ke
              Schade, das noch keiner das Fur-Plugin auf Deutsch übersetzt hat
              http://www.zz7.de
              • deaneauD
                deaneau
                Hallo, Deuschland, Schweiz und Österreich,
                und alle die native Speaker/Reader (einheimische?) sind.
                gibt es für Lightup4Sketchup schon eine deutsche übersetzung des Handbuches oder deutsche Tutorials die auch etwas in die Tiefe gehen?
                ich experimentiere schon bereits seit v.2.4 mit dem Programm und bekomme einige Sachen einfach nie hin.
                Ursprünglich war ich von den Ergebnissen der Webseite begeistert, aber Ernüchterung kam schon sehr schnell auf, als ich dann die ersten versuche gestartet hatte.
                Der Antwickler Adam Billard, hat ja ach ein paar gute Tutorials erstellt, aber seine Aussprache ist verdammt schwer zu verstehen.
                Vermutlich nutzt er ein Tischmikrofon und der Hall verschluckt dort Wörter die man nicht versteht, die aber wichtig sind um Zusammenhänge zu verstehen.
                hat sich jemand an dieses Thema schon einmal herangewagt oder kennt wirklich gute deutsche Tutorials, die die Thematik Sketchup und Lightup4Sketchup sehr gut beschreiben.
                Mir geht es darum, dass man die Renderergebnisse in ein Game überführt. Die Funktionen sind vorhandn, aber leider sind die erforderlichen Ergebnisse immer Zufall.
                Selbst mit gleichen Einstellungen, bekomme ich unterschiedliche Ergebnisse.
                Für eine Hilfreiche Antwort bin ich sehr dankbar.
                Was mir naturlich sehr missfällt ist die Umstellung des Lizensmodells.
                wenn ich zurückdenke, ging die Version 2 bis zur 2.7 die 3 ging dann plötzlich nur noch bis 3.3 was eine Planung der Kosten natürlich nicht wirklich vereinfacht.
                jetzt haben wir bereits die Version 4 und der breis ist zwar der selbe für ein Update aber die Zeitspanne hat sich nach meinem Gefühl verkürzt.
                Leider ist die Liste der Updates nicht immer aktuell und oft passierte es, dass ein update ein anderes Problem erzeugt hat oder ein positive dinge von der Vorversion, plötzlich nicht mehr funktionierten die dann wieder nachgebessert werden mussten.
                Ich schätze das Programm sehr und den Entwickler auch, aber ich bin mir jetzt unsicher ob ich mir jetzt die 4.x auch noch ans Bein binde.
                ich persönlich mache nichts comerziell bin allerdings auch kein Lehrer oder Student, so dass für mich die Lizenz irgend wann zu teuer wird.
                Bisher habe ich den Weg gescheut alles per bildschirmfotos zu machen und dann auf die objekte aufzutragen aber scheinbar bleibt mir da nichts anderes übrig.
                Leider bin ich zu ungeduldig und das kann natürlich auch nerven. Mein Projekt hätte schon längst fertig sein können, aber ohne Lightup dauert mir das noch länger (workflow).
                Ach ja das Game heisst einmal Trainz und das andere Trainsimulator.
                für Trainz gibt es sogar ein Sketchup-Plugin, was mir den Export sehr erleichtert.
                Die Thematik ist historisch angesiedelt, da man in Trainz und TS auch andere Dinge bewegen kann ausser Loks und Wagen etc.
                Für Trainz musste ich immer Schatten in Textur rendern um halbwegs plastisch darstellen zu können. Licht muss da auch gefaket werden, wo Lightup ins Spiel kam. die Umsetzung war nicht schlecht aber leider auch oft fehlerhaft, dank Lightup 😕
                So jetzt habe ich genug abgefrustet.
                Sorry aber ich bin ein wenig neben der Spur, weil die Ergebnisse nicht meinen Anforderungen und die des Games ensprechen. ich will ausschliessen dass der Fehler bei mir liegt und das geht natürlich nur wenn man das Programm auch wirklich bis in die Tiefe versteht.
                euch erst einmal ein schönes Wochenende.
                Gruss Dean
                • BurkhardB
                  Burkhard
                  Kenne kein einziges.
                  Ich habe Lightup in den Anfängen mal übersetzt, bin aber aktuell nicht auf dem laufenden, sorry
                  • deaneauD
                    deaneau
                    hallo Burkhard, hast du es aufgegeben oder ist der support seits Adam nicht ausreichend?
                    wenn du mir deine übersetzung schicken könntest...
                    bis zu welcher Version bist du denn mit deiner version gegangen?
                    Der Workflow mit sketchup und lightup ist für mich einfacher als der mit 3dMax... von daher würde ich dabei bleiben wollen, aber summierender frust ist auch nicht die lösung. ich bin sicher dass ich das mit lightup hinbekomme ...aber.....
                    lightup hat durchaus potential wenn es um games geht...
                    gruss dean
                    p.s. schöne bilder die du auf deiner seite hast 👍
                    • sketch3d.deS
                      sketch3d.de
                      Erstellung und Pflege fachspezifischer Übersetzungen für Dokumentation und Software ist richtig viel Arbeit und benötigt natürlich auch das entsprechende Know-How bez. der korrekten Begrifflichkeiten... was man an manchem Termini der deutschen SU-Version sehen kann...
                      Bei kommerziellen Produkten sollte das eigentlich der Anbieter leisten, die offiz. SU Video-Tutorials gibt's allerdings auch noch nicht auf Deutsch... 😒
                      Da alle die mal ein freies Plugin übersetzt haben das wissen, ist die Quote derer die sowas 'pro bono' machen eher überschaubar...
                      Norbert
                      • deaneauD
                        deaneau
                        Norbert
                        ja das wird so nie passieren weil der Adam Brite ist.
                        nun ja wenn es nur die Oberfläche berührt ist ja englisch noch ok, aber wenn es tiefer geht, was man in deutsch auch nicht so recht versteht, ist die Muttersprache immer die liebste Sprache.
                        nun ja
                        dann war das wohl die letzte Version von Lightup für mich.
                        nette Restwoche euch allen
                        Dean
                        • sketch3d.deS
                          sketch3d.de
                          hat damit nichts zu tun, dafür gibt es zahllose Dienstleister.. muss man halt bezahlen.
                          Norbert
