    Suggestions to improve Layout
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    33 Posts 12 Posters 25.7k Views 12 Watching
    • KrisidiousK
      Krisidious
      You can put a line style around an inserted instance of an SU model as well. However I agree that free forming is needed. But, you can always make a rectangle or circle and then change it's style properties to be outlined...
      By: Kristoff Rand
      • O
        otb designworks
        That's a good point! If I could draw a circle and then apply a line style of a cloud, that would be great, for sure!
        Cheers, Chuck
        OTB Designworks is on Youtube
        • K
          kaas
          Just noticed something in Layout2014:
          If I zoom to some portion of my paper in Layout, switch (click or alt-tab) to another program and switch back to Layout (alt-tab or click), it reverted to zoom all. Would prefer if Layout wouldn't change zoom. New feature in 2014?
          • O
            otb designworks
            I am not seeing this on a Mac. When I command-tab between softwares, my zoom stays the same in Layout.
            Cheers, Chuck
            • O
              otb designworks
              Working on some detailed shop drawings right now and I have noticed another peculiarity.
              Lets's say I have a 4 dimension string, auto scaling, snapped to sketchup geometry. And then, for whatever reason, I need to moved those dimensions further away from the model so I can add another string, or whatever. If I select all the dimensions and drag them out, it seems that randomly some of the dimensions will revert to paper space dimensions. Only some though, which is really weird to me, and only some of the time? I find myself usually erasing all the dims instead of moving them because I am paranoid that a dim will change when I move it and I won't notice.
              Cheers, Chuck
              • K
                kaas
                @otb designworks said:
                ...I am paranoid that a dim will change when I move it and I won't notice.
                That's why I do all my dimensioning in Sketchup. 'Smart' is a potential disaster for anyone who's responsible for the measurements in construction drawings.
                Smart dimensions are nice but only when adding the dimensions. After that I want them as dumb as a doorknob - until I tell a particular dimension line to update.
                • pbacotP
                  That's why I do all my dimensioning in Sketchup. Potential disaster for anyone who's responsible for the measurements in construction drawings.
                  Second that. In my CAD package it is pretty simple. Still if I change the scale (say for a different part of the file) and make certain adjustments to a line of dimensions, it can trigger an update to the wrong dimension. Caught me sometimes when I didn't see it change. Just really bad news.
                  • KrisidiousK
                    Krisidious
                    third that... just had an entire set come off as 1/8inch instead of 3/16. Good thing the builder caught it.
                    By: Kristoff Rand
                    • K
                      kaas
                      Going to quote myself here because this behavior really could use a fix in Windows.
                      Also, I use a pen tablet in Layout (as well as in Sketchup). Annoying part is, when I draw (or edit) a line and want to zoom out to another point, pressing the shortcut key for zoom breaks the line command while in Sketchup pressing <esc> after shortcut-zooming picks up the line command again. Please make layout behave the same!
                      • idraftnzI
                        idraftnz
                        The ability to scale a object when bringing it into the drawings from scrapbooks would be an AWESOME feature. eg from 1:1 to say 1:10. This would make all the difference to those using details in their projects which require working construction drawings to be to scale. πŸ‘
                        • idraftnzI
                          idraftnz
                          1. A follow me tool like sketchup
                          2. An Offset tool like sketchup!
                          These would allow you to draw walls in layout quicker (if required ofcourse)
                          • O
                            otb designworks
                            @marcdurant said:
                            Don't worry, I haven't forgotten. I actually started hacking around on #10 while riding the bus up to BaseCamp on Monday. It's something I've been wanting to do for about a year but haven't managed to fit it in yet. #2 and #9 are also on my personal list.
                            I'd love to be able to report back that we're addressing every item, but understand that your list represents about a release's worth of effort. Multiply that by every wish-list out there (granted, there's some overlap) and I'll be busy until I retire. Which isn't a bad thing, but does explain why there are a lot of disappointed wish-listers out there.
                            Marc! What happened!? A brand new layout and not even one of my list of suggestions was addressed!?
                            I have to admit that that is pretty disappointing.
                            To be perfectly honest, the entire layout 15 update was pretty anemic, in my opinion, though I do love the 2 segment text tool; that is a nice touch.
                            I read through my list and pretty much everything I wrote then is still a valid suggestion and it would sure make my day if we started to get some developer traction on them.
                            Help, Marc, help!!!
                            Cheers, Chuck
                            • O
                              otb designworks
                              @frederik said:
                              I'm sure the LayOut team won't forget you/us... πŸ˜‰
                              However, please remember that there's app. a year until next release...
                              I wouldn't expect much of these feature requests to make it into a possible maintenance release before SU2015... 😐
                              Guess we shouldn't have expected them at all...😞
                              Cheers, Chuck
                              • O
                                otb designworks
                                It would also be really very helpful if we could import DWG/DXF files
                                Cheers, Chuck
                                • FrederikF
                                  Frederik
                                  To some extend I can agree, that it's a little disappointing that so few feature requests have made it so far... 😐
                                  I assume that it's primary caused by the migration to 64-bit, which I acknowledge have been a huge task...!
                                  I do hope that now where these things are in place, they have the time to work on the feature requests in the future...
                                  No need to double-post...
                                  Cheers
                                  Kim Frederik
                                  • 2 / 2
