    Read and Write (update) problem
    12 Posts 3 Posters 1.3k Views 3 Watching
      schizo2000
      hello.
      I have a Ruby code that I want to use to gather data but it is to slow;
      does anybody know why>?
      ContinueReading=0
      def reeed(ContinueReading)
      k=[]
      File.open("C:/TT/temp.txt", "r") do |f|
      f.each_line do |e|
      k<<e
      ContinueReading=k[0].to_i
      puts (k[0])
      return ContinueReading
      while reeed(ContinueReading)==1
      puts ('I am Reading the Source file')
      sleep(3)
      break if reeed(ContinueReading)==0
        schizo2000
        by the way you should replace ContinueReading with continuereading
        the code would be:
        continuereading=0
        def reeed(continuereading)
        k=[]
        File.open("C:/GHConnection/temp.txt", "r") do |f|
        f.each_line do |e|
        k<<e
        continuereading= k[0].to_i
        puts (k[0])
        return continuereading
        while reeed(continuereading)==1
        sleep(3)
        break if reeed(continuereading)==0
          A simple way to read text from a file is this:
          txt = IO.read("C:/TT/temp.txt")
          which return it all as a string.
          To read individual lines use:
          lines = IO.readlines("C:/TT/temp.txt")
          You can then look at each line as needed...
          Remember to strip off the trailing "\n" thus:
          lines.each{|line| p line; line.chomp!; p line }
            schizo2000
            thanks for your quick reply TIG.
            so the code would be sth like this:
            continuereading=0
            lines = IO.readlines("C:/GHConnection/temp.txt")
            return (lines[0]).to_i
            while ((reeed (continuereading)))==1
            sleep(3)
            it works fine but again it is 2 slow; all the characters in my text-file do not add up to 100 yet after iteration 3 the solution is practically worthless.
            • Dan RathbunD Offline
              Dan Rathbun
              NO use:
              lines = IO.readlines("C;/GHConnection/temp.txt").map{|l| l.chomp }
              puts( "Number of lines; #{lines.size}" )
              for line in lines
                puts(line)
                # do whatever else with each line here
              Yes, using the sleep() with a 3 second argument will be slow !
              I'm not here much anymore.
                schizo2000
                well, we can change the sleep time (or we can omit it) but still 3-times reading is the best I can get out of this.
                  Dan Rathbun
                  We are telling you that you should read the file ONCE, in it's ENTIRETY, into an array of lines.
                  THEN read from the array of lines, when ever you need to.
                    schizo2000
                    the problem is that I need the update-data in each cycle and the provider (the one that send the text files) is the one that decides when the reading action should stop. similar to web browsers when we want to get notified when sth changes.
                    I am using the sleep to make the action less frequent in the hope of achieving more/better iterations.
                    does that make sense? is there a better solution?
                      schizo2000
                      Video of the process
                      https://www.youtube.com/watch?v=EKKCQHfAUqk
                        Issue 1:
                        When your code [somehow] updates the model's contents if needs to only affect the relevant instances.
                        How are you getting ALL instances ?
                        How are you identifying your 'linked' instance definitions ?
                        It should be straightforward to separate the two 'types'...
                        Issue 2:
                        Can you not set up a timer to poll the linked data ?
                        So instead of the user clicking on a button and sending an update 'request', you automate it on a click/and stop it on a click...
                        mytimer=UI.start_timer(1, true){ do_'reqeust'_every_second__BUT_when_@stopped_do(UI.stop_timer(mytimer)) }
                        That way it runs all of the time and refreshes the linked data every second...
                          schizo2000
                          special thanks to you TIG, the timer was genius idea .
                            schizo2000
                            Thanks to every one here (and also Thomas Thomassen) the work is now finished!
