    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 109.1k Views 41 Watching
    • eneroth3E Offline
      eneroth3
      @deaneau said:
      ground level tracks= street track (like for tram) or Tram Track
      Tracks with cantenary etc.
      Edit:
      tracks without ballast.
      you can work with code numbers too. 3 or 4 digits
      numbers will be used by all languages.
      ene_1000_001_00 default with wooden sleepers
      ene_1000_002_00 default with concrete sleepers
      ene_1000_002_01 default with concrete sleepers and catenary
      track with buildings like plateform
      loading ramp
      ene_se_1000_002_01 sweden default with concrete sleepers and catenary
      ene_es_1000_002_01 spain default with concrete sleepers and catenary
      1000=default track
      1001= Tramtrack
      1003= bridge
      1004=tunnel
      streets begin with 1
      2000
      2001
      runway 2
      3000
      3001
      waterway 3
      4000
      4001
      combinations
      track and street
      5000
      track and runway
      6000
      track and waterway
      7000
      Technically that would work and a friend and I used a similar system to store metadata in file names for an early web project before we new about databases. However it would in the end mean the same thing as choosing these values (tunnel, bridge etc) from dropdown lists in the same form as name and description are written and store it in the same file.
      The problem is that the user must be able to add own information that could be just about anything. A track can be made of dancing sharks or purple mushrooms with pink stripes or whatever and I can't make a list of all words and phrases that could theoretically occur. Those examples are quite extreme but what if a user wants to add Lego style tracks, or Märklin M tracks? I don't want to limit users to just make what I originally thought of with something as arbitrary as the user interface when it's actually supported by the rest of the code. If I had added such a limitation from the start there probably wouldn't even be roads now.
      My website: http://julia-christina-eneroth.se/
      • deaneauD Offline
        deaneau
        yes i understand your problem.. than i would say... description if possible in english.
        here one of a railroad dictionary
        Attention Required! | Cloudflare
        (www.csx.com)
        Index of /accounts/raildictionary
        (www.trainweb.com)
        i think if the creator will have a big range of user will understand, that the best way is to do this in english.
        lastly i have had an example for russian or japanese creators that write the description in the own language. only russian or japanese user will understand this.
        no other would be use this content if this is not in english.
        look at other plugins written from chinese developer. english is important to popularize this plugins world wide.
        EDIT:
        i think you need only 4 main categories and than some subcategories
        how many route of transport you know?
        i know railroad, street, water and air. ok space for the future is possible, too 😉
        than you could split this in subcategories.
        remmember you, you can not only design railroad. your plugin can more than this.
        is a good idea to communicate this.
        dean
        • ppoublanP Offline
          ppoublan
          Hi Eneroth,
          First thanks for this amazing plugin. I really appreciate the way animation is done and the "open" features that allows customization of all objects.
          I have a wish and would like to know if this is something you could think of :
          I would like to be able to run custom script at each image change, to be able to render images in external render. I've seen its possible to add points where external script is called, but adding them one by one for each image would be too long.
          Just an idea...
          Yours
          Pascal
          • eneroth3E Offline
            eneroth3
            @ppoublan said:
            Hi Eneroth,
            Just an idea...
            Yours
            Pascal
            This is a great idea! I've been thinking about renderers and if they could be changed to run a script each frame but that's really backward. Letting the plugin run a script each frame and tell the renderer what to do is much better since I don't need to change the renderer.
            edit: Or perhaps both. In case there are renderers that have the feature to run a script between each frame I can add a method to the plugin that can be called with the time difference as argument (this more or less already exists but isn't documented).
            • eneroth3E Offline
              eneroth3
              I've started working on the Advanced Animation Settings which includes running custom code between frames.
              @ppoublan: Is there any specific renderer you where thinking of? I'm quite new to rendering but was thinking about some example code to show in the documentation.
              • ppoublanP Offline
                ppoublan
                Wow,
                Your moving too fast !
                My idea was at least at the beginning to be able to export as obj file the geometry of each image and generate the cmd line to render, and to be able also to export as 2D SU image (but with support of styles, shadows, custom size...) things that are not supported when using integrated make avi file from SU. Code for this exists in many plugins.
                My personal final goal is to call Octane integrated render for SU, that is in beta now, but has in the todo list feature for future version to support calling the render from SU by script.
                here is very simple example of code it could call
                imagewidth = 1280
                imageheight = 720
                imagecompression = 0.7
                imagetransparent = false
                view = Sketchup.active_model.active_view
                view.refresh
                imagefilename=<string to build from model name + index>
                keys = {
                :filename => imagefilename,
                :width => imagewidth,
                :height => imageheight,
                :antialias => true,
                :compression => imagecompression,
                :transparent => imagetransparent
                view.write_image keys
                Example of animation created by own script, would like to make same kind of result but with objects animated by your railroad system
                edit
                just for fun, after printing in 3D, the wheel built and rotated by a lego robot without contact
                • eneroth3E Offline
                  eneroth3
                  My first video exported with the plugin. Also the first time I can see the trains run with shadows, fog and textures without lag 😄 .
                  • ppoublanP Offline
                    ppoublan
                    Yes, yes, yes. Great !!!! Like it.
                    • deaneauD Offline
                      deaneau
                      • eneroth3E Offline
                        eneroth3
                        The latest version of the plugin is now published. Now rolling stocks can be added to the library from their context (rigth click) menu so there's no need to write stuff in the terminal any more! The documentation for custom tracks has been improved with images showing how different parts are drawn. Advanced animation settings now allow users to execute code between each frame. An example how to make a simple animation with Sketchup's own view.write_image has been added to the documentation.
                        (Images from documentation showing what's the extrusion, arrayed parts and endings)
                        • deaneauD Offline
                          deaneau
                          Eneroth busy as a bee!
                          thank you
                          • OxerO Offline
                            Oxer
                            The new feature to export animation images is really fantastic 👍 , here a quick test of video animation created with Quicktime Pro
                            http://youtu.be/khK_p5UaK4g
                            • eneroth3E Offline
                              eneroth3
                              First I couldn't understand how you could move the camera while exporting. Then I realized that it's probably my computer that is so slow Sketchup nearly freezes when exporting. Each frame takes several seconds for me 😕 .
                              • OxerO Offline
                                Oxer
                                On my computer export each frame it's near to real time (milliseconds) with shadows included. I have a iMac i7 3,4GHz 27" (mid 2011) 16GB Ram.
                                • eneroth3E Offline
                                  eneroth3
                                  Hehe, I'm on a 1,8GHz (dual core) with about 3GB ram. I think it's time to replace it 😲 .
                                  • deaneauD Offline
                                    deaneau
                                    • eneroth3E Offline
                                      eneroth3
                                      Cool bridge!
                                      have you created custom track types for street lights and bridge deck?
                                      • deaneauD Offline
                                        deaneau
                                        @eneroth3 said:
                                        Cool bridge!
                                        no not really.
                                        this was a bridge for a simulator and i have try to combine this. i have this design by photos
                                        Just a moment...
                                        (structurae.de)
                                        some parts of the bridge will be possible however the suspender cables ,the tower and pier will not possible.
                                        i can send you the sketchup model and you can try what´s possible.
                                        is a bridge possible with more than 2 "tracks"?
                                        dean
                                        • eneroth3E Offline
                                          eneroth3
                                          I think everything but the cables could be drawn as a track type. if the cables were straight even those could be included but the bridge would be a lot less cool.
                                          You can follow the instructions for double tracks in the docs and just make it wider to fit more tracks of the corresponding track type.
                                          • ppoublanP Offline
                                            ppoublan
                                            Hi Eneroth,
                                            Thanks again for this amazing plugin and the add of custom code at each frame.
                                            I’m playing like a kid with its new toy.
                                            Here are some suggestions/ideas for improvements. Feel free to discard…
                                            I created a custom track (Lego type) with small gauge (0.084m) and scale. Do not know if this is link to this scale but then I got sometime strange behavior when adding new tracks from webdialog:
                                            • Can’t create even straight tracks of less than a length (60cm) without getting ties drawn in the opposite direction of the rails.
                                            • For slips, tracks at each end are drawn over the slip, not externaly
                                            • Do you want a copy of tracks I made to test or this is something you already seen ?
                                            Not sure you can do something with this, but when placing an object (track, train, …) , cant zoom with the mouse wheel until it is pressed one to activate orbit tool. This is not the case with other SU tools.
                                            I replaced default signals. Will wait for the customization doc. One thing is I’m not sure why you need left and right template. Why not to place/rotate within the tool.
                                            When working on complex models, it should be great to be able to change the type of multiple tracks at once. (select many and change the type) in place of doing this one by one.
                                            Would like also a way to force reloading and redrawing tracks when template has been changed.
                                            Regarding camera, maybe a fixed point but with eye following a train would be interesting.
                                            Last, I played a lot with balises. This is the most interesting part. I added 3 instance variables to the balise class to be able to build with the balises a kind of auto-controlled circuit to avoid collisions and add more trains to the same circuit.
                                            These I think may be useful :
                                            • Last train : to be able within a balise code to access to the previous train that passed the balise (and not only the current one)
                                            • Last run : time the balise was last activated. I use this to control spacing/speed between trains
                                            • Custom status : a variable to store a user state for each balise
                                            Yours
                                            Pascal
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
