    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 90.1k Views 41 Watching
    • deaneauD Offline
      deaneau
      @dtrarch said:
      Hi Deaneau
      Big Boy is being restored to be fully functional as we speak. πŸ‘ πŸ‘
      Check this out
      http://www.latimes.com/travel/deals/la-trb-big-boy-steam-locomotive-las-vegas-salt-lake-city-20140127-story.html
      What a scene to see this one run.
      dtr
      is a fictional city. the building looks like bavarian (southern germany).
      • deaneauD Offline
        deaneau
        @dtrarch said:
        youtube of Big Boy #3985 rolling. πŸ‘ πŸ‘
        http://www.youtube.com/watch?v=ZVcOPIaekOU πŸ˜„
        dtr
        yes this look so marvelous. the horn sound a little bit hoarse.
        • eneroth3E Offline
          eneroth3
          You can all make models of these locomotives and share here πŸ˜„ . Remember that they might need to be quite low detailed to avoid lag, you can check out how the rolling stocks shipped with the plugin are drawn πŸ˜„ .
          My website: http://julia-christina-eneroth.se/
          • eneroth3E Offline
            eneroth3
            Ok About the Pop UP Menu πŸ˜‰
            I will just add that to the Documentation πŸ˜‰
            About the number of lines : no problem I have them! (mΓͺme les lignes vides sont numΓ©rotΓ©es! πŸ˜‰
            About the Cancel : that is made πŸ˜„ (But synonym πŸ˜‰
            I really don't understand how you manage to get it wrong all the time. It's not a synonym. It's a translation of the word in another context. Another, faulty, word doesn't make sense. If the translation doesn't make sense it' to no help at all. It's only harming the plugin.
            Also Apply seems to be translated to Appliquer in this context. Can you please explain how you managed to get completely different words? I really want to know because I just can't understand it. Have you never seen a dialog box like the one above?
              Sorry but in French It's strictely the same thing!
              "Abandonner" = I close this dialog box and continue my way! πŸ˜„
              But don't worry that is not matter because i put your version for your pleasure! πŸ˜„
              • eneroth3E Offline
                eneroth3
                It's not just about these 2 phrases. It's about everyone in the whole plugin (230 of them) and every sentence in the whole so called translation of the documentation.
                If you run this in the console, what does it return?
                UI.messagebox "TEXT", MB_YESNOCANCEL
                It's not "strictly" the same. Different words are used in different contexts. It's strictly wrong with other inconsistent words.
                I have no idea how you do it when you so called translate. When you see strings such as "OK", "Cancel" and "Apply" under the header "Web dialog buttons" in the dictionary file, how can you not recognize those words from similar dialogs?
                Btw, you've also managed to color the x axis green several times in the so called translation of the documentation. That makes your statement that the so called translation is perfectly understandable to French people a lie.
                • deaneauD Offline
                  deaneau
                  is it possible to change the value m/s about more than 50m/s?
                  this would be great for take offs
                  dean
                  • eneroth3E Offline
                    eneroth3
                    dean
                    I scaled the slider so it would be easier to run at low speeds at rail yards but you can enter much higher values in the text box πŸ˜„ .
                    I don't know if I should re-scale the slider so it can be used for high speed trains or perhaps even make it logarithmic or something so it can be used for both. That could however be less user intuitive when the user for instance want to double the speed and tries to drag the slider twice as far from its start.
                    • deaneauD Offline
                      deaneau
                      dean
                      no no i dont mean the slider him self. ok this is a way when i can insert an other value.
                      no problem
                      dean
                      • BoxB Offline
                        As a side note to this excellent plugin, it is incredibly hard to make accurate translations of technical language. Not only do you need to be fluent in both languages you also need to be fluent in the relivant jargon of the technology involved. I speak 6 languages and can order a beer in several others but I haven't joined any of the foreign language sections because I know how easy it is to get it all screwed up. My wife works as a similtanious translator in 3 languages and she has translated quite a number of help files/user manuals etc and even she has problems to get it right. We often spend hours rereading and discussing the nuances of phrases and words that can have a multitude of meaning and therefore an almost infinite number of possible target words.
                        You must understand what needs to be said in both languages, if you aren't fluent in one it will be wrong!
                        • eneroth3E Offline
                          eneroth3
                          This is very true and one of the reasons I from the start was quite unsure whether I wanted it translated or not. I've tried to explain in my post how important it is to look at the text in its context but I don't know if everyone understood.
                            Innacurate Green x corrected! πŸ˜„
                            • BoxB Offline
                              QED
                                Quod Erat Demonstrandum, synonym of CQFD in French ? πŸ˜‰
                                QED Text Editor ?
                                QED File type of QUEMU ?
                                QED (quantum electrodynamics)
                                QED Egypthian first name ?
                                QED theater's play ?
                                Q.E.D. TV Serial
                                Q.E.D Acid Black Cherry Album?
                                  little test
                                  • eneroth3E Offline
                                    eneroth3
                                    I don't know how to say this.
                                    I don't want you to fix the examples I give you of what is wrong. They are examples to show you that you clearly do not understand what you are trying to translate. You don't seem to understand English. I don't know if you batter the text through Google Translate or what you do with it but it's like you don't even read it. Words mean totally different things in different contexts. Canceling a meeting and canceling a dialog are for instance different things. If you do not even recognize these terms I do dot trust any phrase you have translated. Your translation attempts are only causing me problems. Sorry.
                                    • eneroth3E Offline
                                      eneroth3
                                      You have a simple thing to do! πŸ˜„
                                      Find someone who speaks French around you and ask him to see the REMOVED LINK or French Interface!
                                      Will you never understand? You are incompetent!
                                      There are still loads of errors in the documentation I've told you about that are still not fixed so no, I will not show it to a French person and let them judge because I know for myself that it is shit.
                                        Will be updated when the original will be updated! πŸ˜„
                                        Something that you don't understand
                                        A documentation even insufficient at your point of view, is fully sufficient for take in hand your very cool plugin for someone who is anglophobic! πŸ˜„
                                        I know I am incompetent from more than half a century and hundred of translations! πŸ˜‰
                                        • eneroth3E Offline
                                          eneroth3
                                          Verbal communication has failed. Trying graphic communication.
                                          http://rack.3.mshcdn.com/media/ZgkyMDEzLzA2LzEyL2FhL0NoYXJsaWVNY2RvLmFmOTNkLmdpZgpwCXRodW1iCTEyMDB4OTYwMD4/561e9b54/f87/Charlie-Mcdonnell.gif
                                          • deaneauD Offline
                                            deaneau
                                            pilou i have a french girlfriend and have given your link to the manual.
                                            they have read your manual and have try to do anything. some things go without problems. however when she want go in the deep they must read the english manual.
                                            Please stop the translation. you will nobody help. not your friends and not new french users.
                                            eneroth have spend many time to write this manual. and i must say. i dont need a translation in german.
                                            eneroth spend to many energy about your translation. she need this energy to write the plugin.
                                            you mean this well, however this is completly unnecessary.
                                            try to design any rolling stock or cars or what ever, i think you can show us your ability.
                                            i hope you understand well what i write and what have written by eneroth .
                                            Dean
                                            • 18
                                            • 19
                                            • 5 / 19
