    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.2k Views 41 Watching
      French Interface Updated ๐Ÿ˜„
      is missing Pop UP menu "Type or track", "Type of Signal" ...
      I must refind the original file if existing multi language?
      fr1.zip
        I don't find these texts...
        And new update linked!
        fr2.zip
        • eneroth3E
          eneroth3
          [attachment=1:6fu5hukj]<!-- ia1 -->train11.jpg<!-- ia1 -->[/attachment:6fu5hukj]
          I've said a long long time ago that those wouldn't be updated since it's a part of the content that may be user created, not a part of the system. That was one of the reason I said there probably wouldn't be translation support ๐Ÿ˜’ .
          Also after spending quite some time searching (thatI could have spend coding) it seems like the correct translation (the one consistent to how the word is used in this context) of Cancel is Annuler, not Abandonner. Please make sure the translation is correct. Otherwise it's more harm than help.
          Edit: the quote from page 4
          @eneroth3 said:
          The work of manually translating would be lost in some week or so. Unless the text strings are separated from the code there's not really any idea doing it. %(red)[However I'm not really sure of what to do since user created content (including track types shipped with the extension) would just be in the user's language unless the user translates it themselves to all languages.
          Randomly mixed languages is just annoying and one of the reasons I really hate it when websites and softwares tries to make Swedish translations.]
          My website: http://julia-christina-eneroth.se/
          • deaneauD
            deaneau
            [attachment=1:1h84akcy]<!-- ia1 -->train11.jpg<!-- ia1 -->[/attachment:1h84akcy]
            pilou the entries in the drop down menue you canยดt change, this is a entries written by the user.
            this will be the best idea, that all name of the objects, bridges, tunnel etc. is in english.
            what do you want do if a russian or japanese people write all entries in the own language. nobody will understand this.
            "..Type or track", "Type of Signal" ...
            Type of Track. of not or
            the best way is to download a notepad++
            http://notepad-plus-plus.org/
            and than ask for the line number to find text. other way is to search text.
            nice night "mon vieux pote !" ๐Ÿ˜‰
            Dean
            • eneroth3E
              eneroth3
              That's how it works with rolling stocks but I'm afraid track types are more complicated. Besides predefined strings such as bridge, tunnel etc the user must be able to add new words like arc, beam, low polygon or whatever describes that track type. I can't think of all possible terms and there can't be translations for them all because they are just too many.
              However I can write in the documentation that this info should be in English so track types can be shared but it will still, as I've said long ago, be mixed languages.
              • deaneauD
                deaneau
                @eneroth3 said:
                Btw, nice truck Dean!
                this is not my own i have downloaded in the 3dwarehouse for test only.
                rotation problem. yes when the wheel is rounding. however i will learn to rotate the wheel. ๐Ÿ˜›
                do you have this in your making off movie?
                i hope so.
                i hate mixed language, too. i dont need german translation. ok i have now written the translation file, however i donยดt use this.
                why? if i publish a screenshot all other can read this text of windows and dialogues.
                if i have an error and i publish this error in a german translation, nobody will understand this.
                least common denominator (LCD) is english.
                this would be difficult when pilou asking in french and eneroth answer in swedish ๐Ÿ˜„
                Dean
                • deaneauD
                  deaneau
                  @ Pilou
                  if the english text begin with uppercase you must translate this in uppercase, too. look at your picture. i know in german is that the same. some words will written in lowercase. thats look better.
                  example:
                  Il fait mauvais temps.
                  It's foul weather today.
                  when the english text look like this
                  It's Foul Weather Today.
                  you must write
                  Il Fait Mauvais Temps.
                  Dean
                  p.s. i know this look terrible,
                  let eneroth smile and write this again
                    Ok About the Pop UP Menu ๐Ÿ˜‰
                    I will just add that to the Documentation ๐Ÿ˜‰
                    About the number of lines : no problem I have them! (mรชme les lignes vides sont numรฉrotรฉes! ๐Ÿ˜‰
                    About the Cancel : that is made ๐Ÿ˜„ (But synonym ๐Ÿ˜‰
                    fr3.zip
                    • deaneauD
                      deaneau
                      even empty lines are numbered! <> mรชme les lignes vides sont numรฉrotรฉes
                      yes you can translate the empty lines ,too ๐Ÿ˜„
                        dtrarch
                        Hi Eneroth
                        Thanks so very much for your Railroad System for all to play with.
                        I have just loved trains since I can remember.
                        Here is one of the really great American Locomotives.
                        Pulled freight in Colorado USA
                        My model at home and C.B & Q. photo 1930.
                        Owner: Chicago Burlington & Quincy
                        Model: BLW 4-8-4 Built As:CBQ 5601 (4-8-4)
                        Serial Number:61444
                        Built: 9/1930
                        Notes: blt 9/30, retired 5/61 sold for scrap
                        Note:My model has a later boiler than in the photo.
                        ๐Ÿ˜ž
                        How sad to loose such an awesome machine.
                        dtr
                        • deaneauD
                          deaneau
                          mother of all steam locos
                          3D Warehouse
                          (3dwarehouse.sketchup.com)
                          https://3dwarehouse.sketchup.com/3dw/getpubliccontent?contentId=a83b837b-28b2-4487-a27e-2d585bfbf2fb
                          • deaneauD
                            deaneau
                            @dtrarch said:
                            Hi Eneroth
                            Serial Number:61444
                            Built: 9/1930
                            ๐Ÿ˜ž
                            dtr
                            wow cool steamlooco.
                            could be if you setup this for eneroth railroad, this will be very high poly.
                            EDIT: oops this is a model in HO gauge.
                            my favorite american steamloco is the "BIG BOY"
                            http://www.american-rails.com/images/Big_Boy_JP_Litho_Sm.jpg
                            http://www.railart.co.uk/gallery/images/williamson7.jpg
                            regards dean
                            • ElibjrE
                              Elibjr
                              Wow! After reading these posts, this is one of the most promising productive plugins I have seen for Sketchup since I started using the software in 2009. Keep up the good work and someone will complete a whole Hollywood movie using your plug-in (with many others). I won't be able to do anything with it for the next few weeks but, this could be packaged with Vali Architects Instant Site Grader Nui and Plusspec to do a complete city. Awesome! ๐Ÿ‘
                                Mine is this one! ๐Ÿ˜„
                                La Douce
                                By franรงois Schuiten
                                http://www.bd-best.com/bgfiles/la-douce.jpg
                                And anoter last version...(I had some re readers โ˜€
                                fr4.zip
                                • deaneauD
                                  deaneau
                                  La Douce
                                  look like this one
                                  EDIT: oops not really
                                  http://upload.wikimedia.org/wikipedia/commons/d/dc/520_class_loco-South_Australia-1984.jpg
                                  my favorite dieselloco is this one.
                                  http://www.romecon-expert.de/bluetiger.jpg
                                  and here a german steam loco
                                  http://bahnamateurbilder.startbilder.de/1024/uebernommene-stromlinienlok-aufarbeitung-geplant--51088.jpg
                                  • deaneauD
                                    deaneau
                                    look here: eneroth have design a table top in sketchup
                                    http://eneroth.port0.org/models/trains/
                                    http://eneroth.port0.org/models/groBendorf/ <---
                                      dtrarch
                                      Hi Deaneau
                                      Big Boy is being restored to be fully functional as we speak. ๐Ÿ‘ ๐Ÿ‘
                                      Check this out
                                      http://www.latimes.com/travel/deals/la-trb-big-boy-steam-locomotive-las-vegas-salt-lake-city-20140127-story.html
                                      What a scene to see this one run.
                                      dtr
                                        dtrarch
                                        youtube of Big Boy #3985 rolling. ๐Ÿ‘ ๐Ÿ‘
                                        http://www.youtube.com/watch?v=ZVcOPIaekOU ๐Ÿ˜„
                                        dtr
                                        • deaneauD
                                          deaneau
                                          @dtrarch said:
                                          Hi Deaneau
                                          Check this out
                                          dtr
                                          is a fictional city. the building looks like bavarian (southern germany).
                                          • deaneauD
                                            deaneau
                                            dtr
                                            yes this look so marvelous. the horn sound a little bit hoarse.
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
