    Encode in 2014 again.
    12 Posts 4 Posters 973 Views 4 Watching
    • Q Offline
      qiucx
      My function reads the string from csv file with utf-8 without BOM and all rb file, html files are utf-8 too.
      Now, i using "File.open pathAttrFile, "r:utf-8"" to read the string file csv file having simple chinese encode content, my problem is that the function can not work when using "split" method directly for the read utf-8 string. "fileline.force_encoding("ISO-8859-1").split "," " should be used and it works. I do not know the reason, can anyone explain it? thanks.
                  fileAttr = File.open pathAttrFile, "r;utf-8"
                  arrayFileLines = fileAttr.readlines
                  arrayFileLines.each do |fileline|
                      attrs = fileline.force_encoding("ISO-8859-1").split ","
      And if i need to pass the iso8859-1 string to html, the string should be encoded to utf-8 using .encode("UTF-8") if defined?(Encoding).
      These convert is not very convenient, does anyone have simple method to address the issue?
      thanks
      • Dan RathbunD Offline
        Dan Rathbun
        Try setting Encoding::default_internal= "UTF-8"
        It has not been set (it's nil on startup,) because it makes no difference on PC, which is a Ruby Core bug.
        I still think it should be set just as external is:
        Encoding::default_external %(#004000)[#<Encoding:UTF-8>]
        Also make sure you have a meta tag in the head of your HTML file that sets encoding ("charset=".)
        I'm not here much anymore.
        • Q Offline
          qiucx
          thanks for your reply. Encoding::default_internal= "UTF-8" and Encoding::default_external= "UTF-8" are set in my entry main.rb and it works. the simple chinese character can be put correctly. However, when the split method can not work as expected. Following is the log and what is the problem with split method? thanks
          def getUsersInfoFromFile(fileName, path)
                  arrayAttributes = Array.new
                  pathAttrFile = Sketchup.find_support_file fileName, path
                  if (pathAttrFile)
                      fileAttr = File.open pathAttrFile,"r;utf-8"
                      arrayFileLines.each do|fileline|
                          arrayFileLine = fileline.split ","
                          arrayAttributes << arrayFileLine
                      fileAttr.close
                  return arrayAttributes
          also, when arrayFileLines = fileAttr.readlines is changed to arrayFileLines = fileAttr.encode("UTF-8").readlines, the problem remains and split error can be fixed when fileAttr.encode("ISO-8859-1").readlinesis used. can you explain? thanks again.
          Error:
          #<ArgumentError: invalid byte sequence in UTF-8>
          C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:130:in split' C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:130:in readLines'
          C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:138:in getUsersInfoFromFile' C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:27:in checkLogin'
          C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:97:in block in login' C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:106:in call'
          C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:106:in show_modal' C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:106:in login'
          C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/Main.rb:7:in <top (required)>' C:/remove/remove_SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
          C:/remove/remove_SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD.rb:1:in <top (required)>'
          • Q Offline
            qiucx
            i find the solution but can not know the reason.
            fileline.force_encoding("ISO-8859-1").encode("utf-8", replace: nil)
            can anyone explain it? And does anyone have better solution?
            thanks.
            • tt_suT Offline
              tt_su
              Can you share your file? The error indicates you are opening a file in UTF-8 mode without the file actually being UTF-8. Are you sure it's UTF-8 encoded?
              • Q Offline
                qiucx
                the files attached.
                userAttributes.csv
                UserManager.rb
                Login.zip
                • TIGT Online
                  It's not the RB that is wrongly encoded - that is properly encoded as UTF8-without-BOM anyway.
                  BUT related files like the CSV [and HTML?] are also best when similarly encoded - but they are not.
                  By changing the v2014 read in string back and forth it makes it acceptable.
                  Note that the encoding change will break earlier SketchUp version users so you need to check if it's defined before using it.
                  Also writing/reading a file to the main folders could have issues with permissions with earlier versions <v2014 AND break if the user has a custom folder setup πŸ˜•
                  • Q Offline
                    qiucx
                    I have used the notepad++ to change the files encoding to UTF-8 without BOM.
                    "also best when similarly encoded - but they are not" how can i to do this similarly encoded?
                    • TIGT Online
                      Sorry, you misunderstand me.
                      'Similarly encoded' simply means encoded as UTF8-without-BOM - which you say you have now done ?
                      • Q Offline
                        qiucx
                        I have set all files to UTF-8 without BOM.
                        but the error remain:
                        Error: #<ArgumentError: invalid byte sequence in UTF-8>
                        C:/Users/tc/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/CRSD/RequireFiles/UserManager/UserManager.rb:24:in `split'
                        Can anyone have it? thanks.
                        • TIGT Online
                          Try this version...
                          I have marked changes with a final ###
                          Also try replacing the Chinese with some Western text in case of issues there ?
                          UserManager.rb
                          • Q Offline
                            qiucx
                            Thanks for all. The problem is done.
                            The solution is to use ultraedit convert function(convert ascii to utf-8(unicode edition)). Originally, i use the notepad++ to convert utf-8 without BOM, and it seems not work as expected.
                            Now, the split function can work correctly without any force_encoding, but the input from html should be converted using force_encoding("UTF-8").
                            Thanks again for TIG.
