    [solved] a simple UI.inputbox problem
    3 Posts 2 Posters 403 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      just a simple UI.inputbox-problem:
      why does this simple method not work?
      def one_value_input
      get_single_value ["a"],["b"],["c"]
      end#def
      def get_single_value (prompts, defaults, headline)
      puts prompts #>>> puts a
      puts defaults #>>> puts b
      puts headline #>>> puts c
      input = UI.inputbox(prompts,defaults,headline)
      end#def
      the picture shows, what comes from it....no idea, why ! (and the "c" appears in the pulldown ....
      thanx
      stan
        An inputbox takes three OR four arguments.
        promptarray, valuearray, popsarray, titlestring
        The first two arguments must always be arrays.
        The first one contains string elements used as the prompts.
        The second one can contain various elements - string ["cat"], float [1.2], integer [6], length [25.mm]
        There must be a third argument of some kind.
        If you pass the third element as an array you can get a drop-down if you pass a non-empty string.
        If the default value is NOT on the passed list-string then it'll start with a 'blank'.
        If you pass three arguments and the third is a simple string, then that is used as a 'title'.
        I your case with a one item inputbox:
        results = inputbox(["Choose Item: "], ["a"], ["a|b|c|d|e"])
        gives a fixed list to choose from ('a' to 'e', defaulting at 'a') BUT NO 'title' [since you pass NO string].
        Note how the elements of the drop-down list are separated by '|'...
        Whereas:
        results = inputbox(["Type in a String: "], ["?"], "Title")
        gives an inputbox expecting a string to be typed NOT chosen, with the default of '?'
        To complete the permutations and extend the example a little, this example below gives you a two item inputbox, expecting a typed in response AND list to choose from, and a also has a 'title':
        results = inputbox(["Typed: ", "Chosen: "], ["?", "a"], ["", "a|b|c|d|e"], "Title")
        To get the results into two variables ('typed' and 'chosen') use:
        return nil unless results ### in case user Cancels! typed,chosen = results
          artmusicstudio
          hi tig,
          understood and done, works perfect,
          the combi-version is very nice and confortable and i can pass arguments to it from any method.
          you will then see it in the finished ruby!
          thanx a lot for the explanation.
          stan
