    Retrieve a value from status bar input box
    5 Posts 3 Posters 425 Views 3 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      in this topic i found the basic code for retrieving an user input.
      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=9828
      but i don't know, which arguments are to be sent to the method
      and which is the return value.
      i would like to implement a numerical input in form
      value 1 , value 2, value 3 (where user puts in 1,5,2 with commas),
      at the position in my code, where one face is selected
      and the input controlls further operations.
      i would liek to use the status bar input instead of the UI.messagebox.
      thanx in advance for ideas!
      stan
      • AdamBA Offline
        AdamB
        its a text string, so do:
        the_input_string.split(',') to get an array of values
        • TIGT Online
          Yes.
          Assuming the input is 'valid' and that it is not triggering any Shortcuts...
          You get "1,2,3" as the 'text'... so split it thus:
          values=text.split(',')
          which gives you:
          ["1", "2", "3"]
          Then to get them as integers
          x=values[0].to_i
          and so on,
          or perhaps .to_f for floats etc...
            artmusicstudio
            hi tig,
            thanx,
            at the moment i have a problem with understanding the tool activation and the activation the VCB
            ( >> http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=52825%26amp;p=480058%26amp;hilit=activate+vcb#p480058)
            in the api the explanantion is still not quite clear to me... t take time
            stan
            • TIGT Online
              You have to make a 'class'.
              SketchUp recognizes it as a 'Tool' from the way it is made into a command...
              Special 'Tool' methods can be used in that class...
              Go to the Extension-Warehouse and find the Examples - the 'draw box' example shows how to set up a Tool...
              https://extensions.sketchup.com/en/content/example-ruby-scripts
