    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 79.2k Views 40 Watching
    • T
      titou
      me too, same problem, cannot whrite anything in the text zone
        Jim
        I know it has probably already been thought about, but it would be incredible to have a command repository where we can browse, install, and share commands...
        Maybe a dvcs repo (github) could be used as the repo. What format would be good for command files - json or yaml maybe?
          Aerilius
          I uploaded a workaround for IE 11's bug (ToolbarEditor 1.1.2).
          Currently the plugin writes each snippet to a ruby file (in %APPDATA%) and stores the metadata with the plugin's preferences in the registry.
          A json or yaml format would also not be a bad idea. I chose rb because it contains runnable code and I don't need to extract the code from a part of the file (or deal with escaping etc.). The metadata is also written in the comment of the ruby file, but I haven't decided yet to parse it out of the comment again, because there would be many sources of error (or the comment would have to strictly follow a specific syntax.
            Jim
            Is the numeric part of the filename unique for each user? If so, that makes it difficult to have a way to share commands.
            • G
              glro
              another detail: the toolbar position is not stored when you close sketchup
              so you have to move it everytime you open
              not really important, but would it be possible to dck the created toolbars as the other native toolbars?
                Aerilius
                Plugins can not influence the position of the toolbar (they can only tell SketchUp to show/hide a toolbar, and Sketchup remembers the position). Since these toolbars are created with a timeout (after all other plugins have been loaded), there was initially a problem wher the toolbar didn't remember its position. After report it was improved in SU2013 so that SketchUp should remember the position even after timeout. In which SketchUp version does it happen to you?
                I have reduced the timeout, maybe that caused the problem?
                • G
                  glro
                  i use sketchup 8
                  i shall try version 13 or 14, to check
                  thank you
                  • K
                    keithwins
                    This would be just what I'm looking for... if I could get it working.
                    When I open it up (v. 1.1.2 on SU 2014 on Win7), the list of available commands is very limited.
                    The vast majority of them is from the 1001bits extension I've got installed. Then there are perhaps 20 more. No View menu commands, for example, which is what I wanted.
                    Speaking for myself and as a relative noob, I think I'd prefer the commands listed in menu order: i.e. Tools/Sandbox/Smoove, but I perhaps I'm putting too much stock in the menus, with which I'm faintly familiar. I'd also love an option to list in different formats, i.e. a nice tight text list that would show about twice as much per page.
                    This looks awesome, and I can see it's working for other people. I've tried shutting down & restarting SU. I also just uninstalled and reinstalled TE, and an interesting thing happened: it still had about as many non-1001bits commands, but not the same ones! I only know this b/c I saw smoove on there before, and it's not there now. I tried disabling 1001bits, and interestingly enough there aren't any more non-1001bits tools there than before. 25 to be precise. Then I uninstalled TE, reinstalled, and same thing.
                    SU Pro 2014
                    Win 7
                    There are two kinds of people in the world: those who believe there are two kinds of people, and...
                      Aerilius
                      SketchUp does not make its menus readable, they can not be accessed or included in custom plugin toolbars. This plugin can only make toolbars for plugin commands (sorry, it got missing from the description in the SCF plugins store, it's still mentioned in the SU extension warehouse).
                      SketchUp's native commands need to be replicated one by one. You can install LaunchUp, which comes with a lot of copies of SketchUp's native commands.
                      • K
                        keithwins
                        Thanks Aurelius, I don't think I understand, but now I understand that I don't understand. I haven't really looked at creating commands, my level of sophistication extended only to picking something off a list 😛
                        SU Pro 2014
                        Win 7
                        • BoxB
                          Do you know you can make custom toolbars natively in 2014?
                          • T
                            theviru
                            Hello,
                            Im looking to make a button that will add a custom object that I have made. I am currently running SU8 and some one in my company (no longer here) made a button that did this. But I want to move to sketchup 2014 unfortunately I cant seem to figure out how to add this button. I see the box on your toolbar editor that allows you to add in ruby code but I'm not a programmer. I don't know if any one has made a button like this and would be willing to share there ruby code would help out allot.
                            I dont know if this is important but I also have to be able to move/edit parts of this object once it has been placed.
                              Aerilius
                              The old button must have been a plugin, so it has ruby code. Without that ruby code there won't be a button. Could you look up where that plugin was located (installed) in the old SketchUp version (SU8 had the plugins under Program Files/Google/Google SketchUp 8/Plugins) and then you could just install it in SketchUp 2014 (under <your_user>/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins).
                              This plugin is rather for small code snippets (~1-10 lines). Of course one can make such a script that inserts a component, but that depends on what exactly it should do.
                              • T
                                theviru
                                Thanks there seems to be multiple .rb files that have names of the buttons. So if I run them I should get the button thanks for the help.
                                • KrisidiousK
                                  Krisidious
                                  You can add native plugins and commands if you install Jim's custom toolbars in conjunction with Aerilius' custom toolbars. Jim's makes native commands available inside of Aerilius' customizer. I have both installed for this reason.
                                  By: Kristoff Rand
                                  • dereiD
                                    derei
                                    I think I found a very nasty bug on Toolbar Editor. It acts strange sometimes. Please check the image attached.
                                    Also, a backup function for it would be nice... ideally embedded in warehouse user account somehow, if possible.
                                    But, in the meantime, look at my unintended toolbars:
                                    Is not the first time when it acts randomly. On a previous date I found a separator that I never dragged it in place.
                                    Any possible explanation?
                                    DESIGNER AND ARTIST DEREI.UK
                                      Aerilius
                                      Second note:
                                      When editing an existing toolbar, in edge cases not all changes can be correctly applied (for example buttons can not be removed, and buttons can only be appended at the end), but changes should be completely applied at next restart. The alternative would be that the plugin does not even try updating the toolbar, but requests the user to restart SketchUp.
                                      Anyways, it is clear that wrong icons should not be added. I'll try to find the best compromise for updated toolbars.
                                      First note: Could be a hash collision (although I thought unlikely). I will try to reproduce it (evt. I will ask for a specific registry setting). Can you tell me what plugin the two pencil icons are?
                                      • deaneauD
                                        deaneau
                                        hello,
                                        how look a ruby-snipped to have a plugin with an icon?
                                        some developer have only plugins that's work in menue. ok i could add short-cuts for this, however sometimes i would have a toolbar with all my most used plugins together.
                                          @deaneau said:
                                          hello,
                                          See how plugins that do have a toolbar do it...
                                          Typically the plugin's menu entry is set up using a 'command'.
                                          You can add a line or two of code to that to use that command in a new toolbar.
                                          You'll need an icon png file to be loaded from somewhere.
                                          After all of the scripts have loaded as SketchUp starts, you cannot add items to an existing menu or toolbar.
                                          Several scripts can add items to an existing menu or toolbar if they do so as they load when SketchUp starts, but this is only possible if that menu or toolbar has a 'reference' that they can access - e.g. an @instance_variable or a CONSTANT, which has been set up in a module which they all share, or a $global_variable_with_a_unique_name [not recommended as it is shared by all modules and could clash with other's too]...
                                          An example of the menu making command is:
                                          unless file_loaded?(__FILE__)
                                          	cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
                                          	UI.menu("Plugins").add_item(cmd)
                                          ### START - ADD TOOLBAR HERE...
                                          ### END -   ADD TOOLBAR HERE
                                          	file_loaded(__FILE__)
                                          If it's a 'Tool' the CMD setup is slightly different...
                                          An example to use that within a toolbar is this additional code added between the ### markers:
                                          cmd.tooltip = "SomeCommandName"
                                          cmd.status_bar_text = "SomeText"
                                          cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
                                          cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
                                          toolbar = UI;;Toolbar.new("SomeCommandName")
                                          toolbar.add_item(cmd)
                                          toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                                          Note how addition properties are needed for the cmd to be used in a toolbar.
                                          The path to the button icons and their names is up to you...
                                          Remember to use a plain-text editor like Notepad++ to edit the .rb file.
                                          Encoding must be UTF-8_without_BOM to be compatible with all SketchUp versions...
                                            toolbar.restore does the exact same thing.
                                            • 5 / 7
