    [Plugin] s4u_Delete Instances Overlap_v2.0.0
    7 Posts 4 Posters 5.0k Views 4 Watching
    • hdpvH Offline
      hdpv
      The plugin delete all instances which is overlap its position(in selection or all).
      http://sketchucation.com/pluginstore?pln=s4u_delete_overlap
      http://extensions.sketchup.com/en/content/s4u-delete-instances-overlap
      Thank ThomThom's help...πŸ˜„
      Suforyou
      http://www.sketchupforyou.com
        Hi there
        I looked at the source code and I still don't fully understand what it does.
        But I noticed it added global methods and didn't wrap the operation in a model.start_operation and model.commit_operation.
        Here's a couple of tips for creating SketchUp plugins that plays nice with other plugins as well:
        http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
        http://www.thomthom.net/thoughts/2013/02/sketchup-plugin-checklist/
        • hdpvH Offline
          hdpv
          ok,thank you for your links.i'm trying.
          the plugin delete the instances on 1 position
          Suforyou
            chib
            doesnt quite work.. nothing happens.
            any updates?
              stuartmitch
              What does it do?
              • hdpvH Offline
                hdpv
                if you have many instances insert 1 position,it delete all and keep 1 instance/1 position.
                Suforyou
                  stuartmitch
                  Thank you!! Makes sense now.
                  Cheers....Scotty
