    Compound angle Tool
    14 Posts 4 Posters 3.0k Views 4 Watching
      slbaumgartner
      @davidheim1 said:
      For Mac users like me, who don't download a lot from the PlugIn Store, could you post some instructions on how to install your plug-in?
      Many thanks,
      dh
      If you install the Plugin Store Tool in your SketchUp, it will handle all the details for you automatically. There are instructions on sketchUcation on how to obtain the Plugin Store Tool. Then you just need to select the plugin (there is a search facility) and click "Autoinstall".
      If you don't have or don't want to use the PS Tool, you can download directly from this link:
      404 Not Found
      (sketchucation.com)
      Keep track of where the rake_and_splay.rbz file downloads to. Then run SketchUp and open SketchUp->Preferences->Extensions. At the bottom of the dialog there is button labeled "Install Extension...". Click this button and using the Finder-like UI, select the file you downloaded and click OK. The extension should be installed and available immediately.
      Hope that helps
      Steve
        slbaumgartner
        TIG beat me to the punch, and he is correct: so long as you don't try to install completely manually, there is nothing special about Mac vs Windows.
        Steve
          Steve, this looks like a handy tool but I wonder if a modification could be made. The value entered for "Scale" gives the length of the splayed and raked line. The name of the value isn't very intuitive. Maybe it could be changed to height? In the case of things like table and chair legs, the height of the table top or seat is typically known and the length of the legs is made to suit. Would it be possible to enter the height to the bottom of the table top or seat and calculate the length of the splayed/raked line? Thanks.
            slbaumgartner
            Dave,
            Thanks for the feedback! That should be an easy change. I'll look at it when I get home on Monday.
            Steve
              Thank you. Have a great weekend. Hopefully you're away and relaxing at a lake or something.
                slbaumgartner
                Version 0.2 implementing Dave's suggestion is now available on the sketchUcation plugins store.
                Steve
                  Thanks Steve. I'll give it a whirl.
                    slbaumgartner
                    You're welcome. Please note that I didn't provide explicit output of the slanted leg length as it can easily be measured using the Tape Measure Tool.
                    Steve
                      I saw that. For my work I don't really care what the length is until I'm ready for the cutlist. As with most parts in a piece of furniture, their length is what it takes to span distance.
                      Thank you for the changes.
                        slbaumgartner
                        Version 0.3 now available on the sketchUcation Plugin Store adds leg vs box type to allow planes to be located more usefully for compound miter joints vs legs.
