    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.1k Views 41 Watching
    • eneroth3E
      eneroth3
      I've been working on an update to the plugin so the inner side of the road can be hidden when automatically drawn. This means each "track" doesn't need to be manually edited to hide these edges and the parametric functionally is much better.
      I've made some videos showing how fast it is/will be to edit the intersections.
      Change angle and remove outgoing street
      Draw road (and how to make sure curves can be arcs)
      Drawing a bridge
      You can try this already with the new intersections attached but with the current version of the plugin edges will appear in the middle of the street. I'll publish a new version of the plugin when there are some more features added.
      intersection2.skp
      My website: http://julia-christina-eneroth.se/
        What a system! 😎
        • deaneauD
          deaneau
          here now the download
          INTERSECTION GB_EU_PED_TL_FENCE.rar
          • eneroth3E
            eneroth3
            deaneau: Instead of manually modelling the fence you could add it as a track type and be able to use it in all sorts of curves without ever having to remodel it! The plugin adds parametric behavior for just this.
            • deaneauD
              deaneau
              oh realy? could you guide me with a movie?
              that will be interesting for other ,too.
              thank you Dean
                Are you interested by a French translation of the documentation ? πŸ˜„
                If someone don't yet made it! πŸ˜’
                Started πŸ˜„
                http://railroadsystem.weebly.com/
                • eneroth3E
                  eneroth3
                  thank you Dean
                  It's all in the documentation. So far placing objects along the track is written in the Tie/Sleeper section but it's done in the same way even no matter what kind of objects there are. Also the existing tracks are great to understand how track types work. The truss bridge in particular shows how to place objects along the track.
                  Started πŸ˜„
                  So far the plugin is under quite heavy development and the docs are changing. For instance I might rewrite the Tie/Sleepers section to make it more clear that it can be used to place any objects along the track. Perhaps it's better to wait with the translation until the plugin doesn't change as much.
                    No problem, i can change anything at any time! πŸ˜„
                    And the advantage for me of this actual translation is that I learn it in the same time! πŸ˜‰
                    • eneroth3E
                      eneroth3
                      Then it sounds like a good idea πŸ‘ πŸ‘
                      • OxerO
                        Oxer
                        I have translated the plugin to Spanish Language but I'll wait to the final version to translate the documentation.
                        Eneroth, has you had time to investigate the problem with the ""Add Rolling Stock" window on Mac?
                          About the translation of the plugin itself, does exist a system multi language?
                          • eneroth3E
                            eneroth3
                            I've looked into the web dialog and tested it with the desktop version of Safari for windows. The problem with the unresponsive library was due to Safari's way of interpreting z-index (I used it to make the tabs appear on top of the content but now I've applied the z-index to the tabs instead). The problem with the Create guide was that Safari thought of line breaks as elements and changed their properties instead of the images/text when trying to show a specific step.
                            Hopefully this will work in Sketchup too πŸ‘
                            There is a system made by the Sketchup team to put all text strings in separate files that can be loaded in different languages. However since it's a Sketchup API feature I can't find any documentation for it. I guess I could look through some other plugins to better understand it but I think it still would be difficult to dynamically add these text strings to web dialogs.
                            • deaneauD
                              deaneau
                              lightup for sketchup have a language handler . however lightup is in a separat folder named Tools.
                              • eneroth3E
                                eneroth3
                                Version 0.1.11 is now published! Hopefully it should work better on Mac now (feedback greatly appreciated as usual!!) and some updates have been made to make streets work better.
                                Plugin download: http://sketchucation.com/pluginstore?pln=ene_railroad
                                An example of streets and intersections, and some videos showing how to alter them, is posted on the previous page.
                                • eneroth3E
                                  eneroth3
                                  Any feedback how the new version works on Mac?
                                    What append of the previous version?
                                    We must kill it ? Or the new version overwrite the previous automatically ?
                                      Aerilius
                                      The LanguageHandler has been published too early with an unfinished design and without considering the feedback that ruby developers gave. Since it's now part of the API, I'm not sure if there will ever be changes. It might certainly be "just enough" for new plugins, but it was too limited to make older plugins use it in place of our own translation libraries and many other plugins have also not switched to this new API.
                                      If you are curious how one can translate a webdialog with one single method call, take a look into my Translate.rb (like in AttributeInspector or ToolbarEditor).
                                      • eneroth3E
                                        eneroth3
                                        You should be able to just install it over the old version. However you may need to restart Sketchup. Otherwise you could first delete the old version's files but then make sure you haven't made any custom track types or rolling stocks you want to keep.
                                        That's too bad πŸ˜• . I'll look into your code but I'm not sure what I'll eventually do. Even if all text in the plugin itself is translated titles and description of track types and other content will be in just one language, unless I ask the user for one string in each language.
                                          For languages to translate a cool easy thing is put a "*" before the first word of the original!
                                          So with an text editor it's very easy to got to this * then translate! β˜€
                                          Beacause for a no Rby maker it's very hard to go to the good place! 😳
                                          No few old folders/files/ will persist if they have not the same names ?
                                            Aerilius
                                            Pilou, it's right that for non-ruby makers it is difficult to find the right place. The same is true even for ruby developers!!!
                                            Marking strings with a '*' only works around the source of the problem. You would have to do the same edits again everytime when an update is released. If we want to support more options/languages/etc., we can separate code and data into different files.
                                            • 18
                                            • 19
                                            • 5 / 19
