    Webdialog to ruby encoding issue on OSX
    22 Posts 5 Posters 2.0k Views 5 Watching
    • tt_suT
      tt_su
      Ditto on OSX:
      I think we need a full example of the error you get - packaged up as RBZ.
      • tt_suT
        tt_su
        Btw, what is the source for this character?
          driven
          @TT
          the third last post from the other thread has a rbz that shows the issue on a mac...
          http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57074%26amp;start=30#p518959
          returns using 'get_element_value' have bad encoding regardless of html declarations, script encodings, etc...
          something is happening internally in SU that screws things up...
          try the rbz it's harmless...
          • Dan RathbunD
            Dan Rathbun
            Did someone file a bug report ?
            I'm not here much anymore.
              driven
              I was going to but I got distracted by work and it's still on my endless todo list...
              • tt_suT
                tt_su
                So this only happen on OSX, not on Windows?
                  driven
                  as far as I'm aware it's a mac thing...
                  I think it's because the internal bash env locale defaults to "C" if not implicedly set
                  > %x(locale)
                  LANG=
                  LC_COLLATE="C"
                  LC_CTYPE="C"
                  LC_MESSAGES="C"
                  LC_MONETARY="C"
                  LC_NUMERIC="C"
                  LC_TIME="C"
                  LC_ALL=
                  whereas same call in 'Terminal.app'
                  LANG="en_US"
                  LC_COLLATE="en_US.UTF-8"
                  LC_CTYPE="en_US.UTF-8"
                  LC_MESSAGES="en_US.UTF-8"
                  LC_MONETARY="en_US.UTF-8"
                  LC_NUMERIC="en_US.UTF-8"
                  LC_TIME="en_US.UTF-8"
                  LC_ALL="en_US.UTF-8"
                  because it is set...
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    @driven said:
                    post a snippet, and I'll run some checks...
                    Going back to your test here
                    If you add
                    Sketchup.active_model.layers.add param_fix
                    in @dlg2.add_action_callback("trans_L8_fix")
                    The layer name is displayed "élan 勢い Schwung импульс" in Layers Panel, as it is a webdialog.
                    But in Sketchup's layer window, it's displayed "\u00E9lan \u52E2\u3044 Schwung \u0438\u043C\u043F\u0443\u043B\u044C\u0441", just like what's printed in the ruby console.
                    Any thought on that?
                    TT > Yes, everything is set to UTF-8. Encoding, meta-tags
                      slbaumgartner
                      > %x(locale)
                      > LANG=
                      > LC_COLLATE="C"
                      > LC_CTYPE="C"
                      > LC_MESSAGES="C"
                      > LC_MONETARY="C"
                      > LC_NUMERIC="C"
                      > LC_TIME="C"
                      > LC_ALL=
                      LANG="en_US"
                      I think this is because SU does not set ENV["LANG"] when launching the subshell.
                      Steve
                        driven
                        @ Steve
                        do you think the two are unrelated?
                        if I eval it double quoted, I get élan 勢い Schwung импульс
                            puts (eval('"' + param_fix + '"'))
                        works in UI.messagebox that way as well.
                        alternatively I wrote [so it is possible] a simple decode method by reversing the JS function back in ruby, it worked but i can't find it...
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          eval works great, thanks!
                            slbaumgartner
                            @driven said:
                            @ Steve
                            It's possible they have the same cause, but I am not sure how to prove that.
                            The man page for the locale command says:
                             LANG         Used as a substitute for any unset LC_* variable.  If LANG is unset, it will
                                          act as if set to "C".  If any of LANG or LC_* are set to invalid values, locale
                                          acts as if they are all unset.
                            So the behavior you get is consistent with LANG not being set by SU when it launches a subshell. Also, if you set ENV[LANG] to a specific locale such as "en_US.UTF-8" in the Ruby Console before doing the %x, the other variables all follow.
                            So far as I can tell, SU doesn't launch a separate process for a WebDialog (at least I don't see one reported in Activity Monitor). I don't know what environment a WebDialog gets...can it be read from javascript?
                            Steve
                              driven
                              hi TT
                              did you get a chance to run this on your mac?
                              and did it confirm what I state, on your setup?
