    Looking for two functions
    13 Posts 4 Posters 916 Views 4 Watching
      juliee
      Hi! Thank you so so much for a reply!!! I did ok with my second issue:) But here's the picture of the other one, my footbrigde is now flat as you can see and I want to make it quickly one floor up - to the red line, so only left end needs pushing up. I hope that it's one click to make it because I really can't think of drawing a raising path from my projection...There's this tutorial https://www.youtube.com/watch?v=PpvPl6Kis1s I'd love to do this that way, but it doesn't work with my complicated object 😞 Please help me! Thanks again for such a long answer!
      • mitcorbM Offline
        mitcorb
        Ok, so you want that bridge to incline gracefully up to the second level.
        Now, seeing the whole megillah(sp?), you could make a cross section of your deck, construct a followme path, but use a different plugin called Follow Me and Keep (FAK)by Wikii, also found in the PluginStore. This plugin keeps the proper orientation of the cross section as it extrudes by eliminating the "twisting effect" common in looping paths.
        You will need to figure out at what point the bridge begins its ascent, determine a slope suitable.
        Wait. I just viewed the tutorial. You may wish to try Follow Me Helix by Sam D Mitch. In the PluginStore. Read the information. I have not viewed it for a while.
        • BoxB Offline
          Fredo's Curvishear is the easiest way to create the slope.
          • cottyC Offline
            cotty
            Here's an animated version of Box great suggestion...
            (used plugins: CurviShear and UprightExtruder)
            [screenr:2u5gk1vc]v9gN[/screenr:2u5gk1vc]
            my SketchUp gallery
            • mitcorbM Offline
              mitcorb
              Thanks, guys:
              I thought of Curvishear, and was going to mention it, but I didn't check for current version.
                juliee
                Thanks guys! You're great!! 😄))
                  juliee
                  cotty- what tool did you use to draw this curved line that is mine(:D)footbridge? I've imported the cad file - my curved line and I want to use plugin that you're using - Curvishear but it doesn't work with my line:( I see the difference here - when you click on yours it's already highlighted - the whole line and mine is in million segments, maybe that's why it's not working. Only a little piece is going up..
                  • cottyC Offline
                    cotty
                    You can weld all the little lines and explode the group so that you have one line to follow...
                    Edit: I`ve used the arc tool and bezier spline and Tigs weld to create the line.
                    my SketchUp gallery
                      juliee
                      Ok, thank you 😄 What I needed was Weld, I've made it all but there's this last problem that the foot-bridge has holes, like on the picture..😞
                      • cottyC Offline
                        cotty
                        How long were your little lines? Maybe you have to "repair" the line with Curvizard to avoid to small faces...
                        my SketchUp gallery
                          juliee
                          My line was too complicated (too many segments)I drew it again in SU and used Weld and it's ok now. Thank you very much !!!:)
