    Rename texture image file inside *.skp
    7 Posts 4 Posters 2.0k Views 4 Watching
    • N Offline
      nick9111
      Is there a way to rename texture image file inside *.skp? For example I can get name of such file using
      Sketchup.active_model.materials[0].texture.filename
      and when the result is filename with no path how to rename it and if it is possible keep association with material which using it?
        Aerilius
        The texture is stored inside of the skp file (no matter whether you get a original path, most likely the path does not exist).
        Export it to the new filename (in a temporary folder), import it again to the material ( material.texture=), delete the temporary file.
        You need to restore the material sizes, and the material alpha and color shift and colorization is lost. When you decide to restore the material's color, it will always be used as "colorized" even if it original was only used as color shift.
        • N Offline
          nick9111
          Thank you for a quick answer, but I always do this work manually for many times and wondering if there's a way to rename it just with ruby command/routine 😐
          • TIGT Online
            The API has a SketchUp 'texture writer'.
            http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchup#create_texture_writer
            Make a temporary group = model.active_entities.add_group()
            Assign the textured material to it: group.material = material.
            You make/use a texture writer to export that texture image file into the temp-folder.
            You can specify the image's file name and type if you write individual files:
            e.g. path_to_png = File.join(temp_folder_path, material.display_name+".png").
            Then:
            tw = Sketchup.create_texture_writer tw.load(group)
            Write the file:
            tw.write(group, path_to_png)
            Remember the original texture size in case changing it looses data:
            w = material.texture.width h = material.texture.height
            Now reset the material.texture = path_to_png
            and its sizes:
            material.texture.size = [w, h]
            Then tidy up...
            Erase the temp file: File.delete(path_to_png)
            Delete the temp group: group.erase! - although GC should remove the zero geometry group anyway
            [Do this inside a model.start_operation...model.commit_operation block...]
            Done!
            • tt_suT Offline
              tt_su
              May I query why you want to change the filename property of a Texture object?
              • N Offline
                nick9111
                Thanks TIG, I'll check out this method πŸ‘
                I am working with a 3rd party program which directly imports *.skp files. My skp files have many textures with non-English letters in their file names. Program can't see those textures.
                • N Offline
                  nick9111
                  So there is a ruby plugin I've done (based on TIG's post). It renames all texture files in model with a template.
                  module VNV
                  def VNV.rename_textures
                  UI.messagebox("All texture file names will be changed with a template - mat000")
                  model = Sketchup.active_model
                  model.start_operation('Rename texture files', true)
                  temp_path = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] )
                  temp_folder = File.join( temp_path, 'Sketchup_tmp_mtl' )
                  unless File.exist?( temp_folder )
                          Dir.mkdir( temp_folder )
                  Sketchup.active_model.materials.each_with_index{ |m,i|
                  if m.texture then
                  group.material = m
                  tw.load(group)
                  path_to_png = File.join(temp_folder, "mat#{'%03d' % i}"+".png")
                  w = m.texture.width
                  h = m.texture.height
                  m.texture = path_to_png
                  m.texture.size = [w, h]
                  group.erase!
                  end # def
                  end # module
                  if (!file_loaded?(__FILE__))
                    menu = UI.menu("Plugins")
                    menu.add_item("Rename texture files") { VNV;;rename_textures }
                    # Let Ruby know we have loaded this file
                    file_loaded(__FILE__)
                  RenameTextures.rb
