    [Talk] Ruby Debugger for SketchUp 14+
    45 Posts 8 Posters 10.0k Views 8 Watching
    • tt_suT
      tt_su
      @slbaumgartner said:
      The Readme on Github says that Mac is not supported yet, but the repository contains project files for Xcode and build succeeded on my Mac. However, there is no discussion of where to put the dylib or how to invoke it.
      Work in progress. I don't recall right now if you will need a new release of SU for OSX before it will work. I'll check in.
        Jim
        Do these IDE's somehow notify SketchUp that the file has been modified and needs to be reloaded by SketchUp?
        • Dan RathbunD
          Dan Rathbun
          Bugra said they implemented the communication protocol that some of the Ruby debugger gems also implement. Documented (somewhat) here:
          Fastly error: unknown domain 151.101.64.204
          (debug-commons.rubyforge.org)
          I'm not here much anymore.
            Jim
            Here is a demo video of a Notepad++ plugin I am working on for SketchUp Debugger communications.
            It is written in Python and requires the PythonScript plugin for Notepad++. The video shows setting a breakpoint, inspecting local variables, and stepping through the script.
            There's no user interface and I use a lot of typed commands, so it is best to watch the video in high quality and full screen.
            Just made it to show possibilities/measure interest/gather feedback.
            • jiminy-billy-bobJ
              jiminy-billy-bob
              Nice! Can't wait to try this
              • Dan RathbunD
                Dan Rathbun
                I'd much rather stay with using NP++.
                Why Python, and perhaps GitHub it ?
                • Dan RathbunD
                  Dan Rathbun
                  I am wondering if this ruby debug ide protocol is based on (or compatible with,)
                  the DBGp protocol: http://www.xdebug.org/docs-dbgp.php#description
                    slbaumgartner
                    Whimper! Bugra (or whoever) please, please! We Mac users are dying of envy....
                    Steve
                    • tt_suT
                      tt_su
                      Soon. πŸ˜„ We need it as well - we share your pain.
                      Btw, have you checked the GitHub repo lately? πŸ˜‰
                      • Dan RathbunD
                        Dan Rathbun
                        Nothing seems to have changed in at least a month (and that seems to be only the readme.)
                        If you have something to announce, come on out and say it.
                          Jim
                          Why Python? Python just seemed like my best chance for success for a proof-of-concept compared to the alternative ways to extend Npp.
                          The Python code is currently posted on this Gist. I'm sure it's ugly as I don't know exactly what I'm doing in Python yet - I am learning as I go about Python, PythonScript, and the Npp environment. I'll put it in a proper Github repo when it's more stable.
                          Maybe there's a Pythonista around who would be willing to help out?
                          This is also a bit complicated to setup - I had to compile my own version of PythonScript.dll from the latest GitHub source to get the margin click callback to return the correct values.
                          One big downside of PythonScript is it appears to have weak support for creating Toolbars in Npp, so creating a good user interface may be a problem.
                          I would love for this to be written in c++ to take advantage of more features of Npp, but that would require learning c++ first and that takes time.
                          the DBGp protocol
                          No, DBGp is incompatible.
                          The commands that the SketchUp Debugging Server accepts can be found by interpreting these regular expressions.
                          • Dan RathbunD
                            Dan Rathbun
                            Yea.. I agree I poked around in the NPP Plugin "How to" today. The C++ stuff is too complex to learn quickly.
                            I did not find any Ruby binding, so Python would be the next best thing. It is similar to ruby (without all the "end"s.)
                            I tried first to install PythonScript in my %AppData% path where all my other NPP plugins are installed, but got an error when trying to open the Python Console. (Something about Python being an ANSI version, and incompatible with the Unicode NPP.)
                            Installing it in the %ProgramFiles% path works (as the doc stated that is where to install it.) So it will require Admin privileges.
                            • Dan RathbunD
                              Dan Rathbun
                              I opened the config dialog, hilited "sudb.py" and clicked on the "Add" button. It was added to the top-level "Python Script" menu.
                              I then made a (quick and dirty) BMP copy of the SU icon, and saved it into "Notepad++/plugins/images/Toolbar" and added the script to the Toolbar list, then hilited it (in the list,) and went thru the file picker after clicking the "Set Icon" button.
                              SketchUp.icon.zip
                              I also set the "Initization" to ATSTARTUP:
                              Restarted Notepad++ and the SketchUp icon appears on the toolbar.
                              πŸ’­
                              • Dan RathbunD
                                Dan Rathbun
                                And doing the above caused a textfile "PythonScriptStartup.cnf" to be created in "%AppData%\Roaming\Notepad++\plugins\config" (UTF-8 no BOM, Dos/Win EOLs)
                                containing:
                                ITEM/C;\Program Files (x86)\Notepad++\plugins\PythonScript\scripts\sudb.py
                                TOOLBAR/C;\Program Files (x86)\Notepad++\plugins\PythonScript\scripts\sudb.py/C;\Program Files (x86)\Notepad++\plugins\images\Toolbar\SketchUp.bmp
                                SETTING/PREFERINSTALLEDPYTHON/1
                                SETTING/STARTUP/ATSTARTUP
                                  Jim
                                  Oh cool, this means a Toolbar with icons can be created from the plugin. Thanks.
                                  Too bad Tooltips on the icons do not seem to be supported...
                                    Jim
                                    I went ahead and made a github repo for this.
                                    http://github.com/jimfoltz/npp-sketchup-debugger
                                    Dan, would you prefer a new topic for discussing issues specifically related to this project?
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Yes that would be good ... and can also log issues on the repo site.
                                        avariant
                                        I haven't had a chance to look at the debugger yet but the first thing I thought when I read about was, is this a backdoor that can be used to defeat the .rbs encrypted rubies? Does the debugger reveal anything about the current line of execution, or does it just deliver line numbers? When displaying data about a variable, does it volunteer variable names or does it just respond with a value?
                                        I would be very disappointed to find out it did. πŸ˜•
                                          Jim
                                          The debugger shows the filename and line number of .rbs files. It will not show the contents of the file.
                                          It can, however list variable names and values in .rbs files.
                                          I have not tried to set a breakpoint on a .rbs, so I am not sure if it is allowed. But i found the debugger will follow observers into .rbs files.
                                            slbaumgartner
                                            You raise some very interesting questions.
                                            If, as I suspect, the rbs unscrambler is an SU facility that decodes the rbs before handing it to a standard Ruby interpreter, then the plaintext source and all other aspects of your plugin would indeed be visible to the debugger. Exploiting this hole isn't as easy as it might sound, since you have to somehow stop Ruby at a breakpoint before the ide commands will work - a bit like shooting in the dark - but I can see that some clever person may find a way.
                                            I think this may come down to how SU implements the debugger ide library. That is, the ide could detect that the source file is rbs and refuse to debug it. This is possible because the SU debugger library implements the ide protocol itself, it does not use the standard debug interface or Gem.
                                            Steve
                                            • 2 / 3
