    Mac read_defaults?
    20 Posts 4 Posters 1.5k Views 4 Watching
      driven
      @slbaumgartner said:
      ...I tried using "Root" as the section, but that didn't work either.
      been there, done that, got the post card... [ as we say ]
      It seems that the API methods have no way to write or read a Root-level non-dict entry (whether by design or oversight I don't know...).
      not sure either, but in the past I have written lots of pref's I couldn't retrieve, although they were written, possibly at root level, honestly can't remember...
      it's been bugging me for years...
      • Dan RathbunD
        Dan Rathbun
        Well humor me, and try the Plist Gem here:
        http://rubygems.org/gems/plist
        .. and you no longer have to use %x strings.
        Doc: http://plist.rubyforge.org
        I'm not here much anymore.
          driven
          @dan,
          result = Plist;;parse_xml("/Users/johns_iMac/Library/Preferences/com.sketchup.SketchUp.2014.plist")
          Error; #<ArgumentError; invalid byte sequence in UTF-8>
          /Users/johns_iMac/Library/Application Support/SketchUp 2014/SketchUp/Gems/gems/plist-3.1.0/lib/plist/parser.rb;91;in `scan'
          I don't think its been updated for Ruby 2...
          • Dan RathbunD
            Dan Rathbun
            Well if you search Rubygems.org, you'll see quite a few plist reader gems.
            • Dan RathbunD
              Dan Rathbun
              @driven said:
              @dan,
              It was supposed to be 1.9.x compatible (since it's v3.0.0)
              Try on a simpler plist. Perhaps SketchUp corrupted it's file ?
                driven
                I think it's actually failing on the binary image chunks stored in some of the keys...
                the thing is there are many built in plist tools that can be used in any plugin, on any mac...
                Gem support from SU Ruby is broken for many things, so I'd favour %x() over failure...
                result = %x( plutil -p "/Users/johns_iMac/Library/Preferences/com.sketchup.SketchUp.2014.plist") returns a human readable string...
                point is I only want the one item and it should be available from Sketchup.read_defaults
                • tt_suT
                  tt_su
                  @driven said:
                  but every concievable version of
                  Sketchup.read_default("NSWindow Frame SketchUpDoc", "")
                  returns nothing...
                  Sketchup.read_default is not a generic method to read anything from a plist. It's a simple method to read simple values for an extension.
                  What you try to do I have done using a shell command (backticks I think). (Don't have the sample snippet on my home machine right now.)
                  • Dan RathbunD
                    Dan Rathbun
                    Well it's Doc did say it would choke on data elements.
                      driven
                      I haven't ever suggested it reads random plist's, I think the API should be able to read SketchUp's own plist items...
                      It will be similar to my first, working example, it works with `` or %x(), I just find %x() more obvious when reading the code...
                        slbaumgartner
                        The property you sought looks like this in XCode on my Mac:
                        It's a string key and value, So I don't think the issue is with binary chunks, it is as TT says simply that read_defaults wasn't designed to read values that weren't written by write_defaults.
                        Steve
                          driven
                          So I don't think the issue is with binary chunks, ...
                          @steve...
                          that comment was referring to the plist gem, it appears to fail on the "BigBrowser" image buttons values that are stored in binary... [but what is BigBrowser??]
                          Now I know it only reads what it can write, I'll continue using defaults for anything else...
                          • Dan RathbunD
                            Dan Rathbun
                            Well on the PC, we have been in the same boat. The API can read only string registry values. Many things are DWORD binary values. Often holding only 1 or 0 for true/false, on/off, etc. Such a simple thing that can not be read.
                            A long time ago, I thought I filed a Feature Request for an application level options hash interface.
