    Mac read_defaults?
    20 Posts 4 Posters 1.4k Views 4 Watching
      driven
      @dan
      it's not a problem to read the exposed plist using system calls, it's more the frustration of having a useless API method...
      I shouldn't need system to read an SU stored preference, from SU...
        slbaumgartner
        @driven said:
        @slbaumgartner said:
        Instead, it reads back values stored using Sketchup.write_default. They are actually kept in a plist file specific to SU, and you can only read values from there, not the system defaults.
        so it's a hidden, additional plist?
        when you use SU.write_defaults you can retrieve them using both SU read or System read?
        and if you change the document size the user/lib/plist is instantly updated...
        I can't follow what's occurring...
        I don't think it is hidden, it is in ~/Library/Preferences/
        SU 2014 keeps a couple of plists there. I believe that the one accessed by read/write_defaults is
        com.sketchup.SketchUp.2014.plist.
        It was intended for plugins to remember their settings until another session.
        The thing is that the SU API's read/write_default methods are wired specifically to this file. They can not read or write defaults from plists belonging to other apps or from the system in general.
        Steve
          driven
          Steve
          Steve this is in the com.sketchup.SketchUp.20#{Sketchup.version.to_i} plist; that's why I can't understand not being able to read it...
            slbaumgartner
            Steve
            I looked and found that you are right about this key being there, so I did some poking around and came to the conclusion that the API methods are designed only to deal with two-level entries: (section, variable). If you try to omit one, you get a wrong number of arguments error, and if either is an empty string, you get nothing.
            In the plist file this means there is a dict entry in the Root with the section name, and this dict has a key entry with the variable name. But "NSWindow Frame SketchUpDoc" is a single-level key directly in the Root, with no other enclosing dict. I tried using "Root" as the section, but that didn't work either. It seems that the API methods have no way to write or read a Root-level non-dict entry (whether by design or oversight I don't know...).
              driven
              ...I tried using "Root" as the section, but that didn't work either.
              been there, done that, got the post card... [ as we say ]
              not sure either, but in the past I have written lots of pref's I couldn't retrieve, although they were written, possibly at root level, honestly can't remember...
              it's been bugging me for years...
              • Dan RathbunD Offline
                Dan Rathbun
                Well humor me, and try the Plist Gem here:
                http://rubygems.org/gems/plist
                .. and you no longer have to use %x strings.
                Doc: http://plist.rubyforge.org
                I'm not here much anymore.
                  driven
                  @dan,
                  result = Plist;;parse_xml("/Users/johns_iMac/Library/Preferences/com.sketchup.SketchUp.2014.plist")
                  Error; #<ArgumentError; invalid byte sequence in UTF-8>
                  /Users/johns_iMac/Library/Application Support/SketchUp 2014/SketchUp/Gems/gems/plist-3.1.0/lib/plist/parser.rb;91;in `scan'
                  I don't think its been updated for Ruby 2...
                    Dan Rathbun
                    Well if you search Rubygems.org, you'll see quite a few plist reader gems.
                      Dan Rathbun
                      @driven said:
                      @dan,
                      It was supposed to be 1.9.x compatible (since it's v3.0.0)
                      Try on a simpler plist. Perhaps SketchUp corrupted it's file ?
                        driven
                        I think it's actually failing on the binary image chunks stored in some of the keys...
                        the thing is there are many built in plist tools that can be used in any plugin, on any mac...
                        Gem support from SU Ruby is broken for many things, so I'd favour %x() over failure...
                        result = %x( plutil -p "/Users/johns_iMac/Library/Preferences/com.sketchup.SketchUp.2014.plist") returns a human readable string...
                        point is I only want the one item and it should be available from Sketchup.read_defaults
                        • tt_suT Offline
                          tt_su
                          @driven said:
                          but every concievable version of
                          Sketchup.read_default("NSWindow Frame SketchUpDoc", "")
                          returns nothing...
                          Sketchup.read_default is not a generic method to read anything from a plist. It's a simple method to read simple values for an extension.
                          What you try to do I have done using a shell command (backticks I think). (Don't have the sample snippet on my home machine right now.)
                            Dan Rathbun
                            Well it's Doc did say it would choke on data elements.
                              driven
                              I haven't ever suggested it reads random plist's, I think the API should be able to read SketchUp's own plist items...
                              It will be similar to my first, working example, it works with `` or %x(), I just find %x() more obvious when reading the code...
                                slbaumgartner
                                The property you sought looks like this in XCode on my Mac:
                                It's a string key and value, So I don't think the issue is with binary chunks, it is as TT says simply that read_defaults wasn't designed to read values that weren't written by write_defaults.
                                Steve
                                  driven
                                  So I don't think the issue is with binary chunks, ...
                                  @steve...
                                  that comment was referring to the plist gem, it appears to fail on the "BigBrowser" image buttons values that are stored in binary... [but what is BigBrowser??]
                                  Now I know it only reads what it can write, I'll continue using defaults for anything else...
                                    Dan Rathbun
                                    Well on the PC, we have been in the same boat. The API can read only string registry values. Many things are DWORD binary values. Often holding only 1 or 0 for true/false, on/off, etc. Such a simple thing that can not be read.
                                    A long time ago, I thought I filed a Feature Request for an application level options hash interface.
