    Fast, clean physical model making
    11 Posts 5 Posters 1.2k Views 5 Watching
      andyc
      Richard: that is a fantastic approach, and one that I may have to borrow! Those sketchy wraps really work well too. One question: what are those clips you are using for the corner- joints?
      Brilliant work πŸ˜„
      A.
      • KrisidiousK Offline
        Krisidious
        That's kool Richard. I don't ever have use to make physicals. Here's one I saw today though.
        Facebook
        (www.facebook.com)
        By: Kristoff Rand
        • RichardR Offline
          Richard
          Brilliant work πŸ˜„
          A.
          Chicks hair clip thingys (hair pins?) They are perfect! Getting the right approach to cutting the sheets and the little flanges off is the trick. Work with a sharp blade box knife and don't rush! That little joint is the trick, all else was a nightmare!
          BTW you only need to clip from the bottom, it's a really rigid connection! Use a floor internally so it can keep all in tension and it's rock solid! Also you can pull it to pieces again and again, doesn't really wear anything out!
          BUILTBRAND.COM.AU
          • RichardR Offline
            Richard
            Facebook
            (www.facebook.com)
            [attachment=0:2zjgg252]<!-- ia0 -->10300807_858012340882401_2647670567344721659_n.jpg<!-- ia0 -->[/attachment:2zjgg252]
            Mate that is AWESOME!!!!!!!!!!! Some people are way beyond creative!
            BUILTBRAND.COM.AU
              andyc
              πŸ˜„ I thought they looked like hair-clips.... but didn't want to say in case they turned out to be some specialist fitting and I looked like an idiot πŸ˜„ Yep, that joint is a very neat solution. And I love the idea of slotting windows into the flutes. I occassionally need to make quick mock-ups not dissimilar to this. I'll definitely be trying your method next time. Thanks for sharing.
              A
              • GarethG Offline
                Gareth
                I love the hand drawn bits on the 3rd image....it reminds if the stuff we did in the 70's
                Whilst I still have to occasionally pinch myself when I think of the 3D modelling and rendering we do now, there is still something very 'honest' about a raw and tactile hand made physical model.
                It won't be long before we all have a 3D printer on our desks....and, just like Architectural Illustrators, the professional Model Makers will slowly be forced into retirement.
                • RichardR Offline
                  Richard
                  The final models for the exhibition. Ended up pinning all, the black v white coreflute made then rather striking!
                  BUILTBRAND.COM.AU
                    Krisidious
                    Looks great Richard.
                    By: Kristoff Rand
                    • RichardR Offline
                      Richard
                      Thanks mate! The two models and plaque are block mounted on 8mm boards to sit on a 1200 x 500mm plinth.
                      BUILTBRAND.COM.AU
                      • U Offline
                        unearthed
                        Thank you Richard, another great idea to put in the toolbox, and you've invented the flatpack model too! I'm starting to travel my ideas around and this should be useful
                        Growplan - People ∩ Plants ∩ Place
                        windows 7 64b, 4GB RAM, SU 8.0.16846
                        Gimp, QGIS, Vectorworks 12, Bricscad 11
