    How to add smt on a sphere pls ?
    8 Posts 2 Posters 714 Views 2 Watching
    • E Offline
      erzane
      I would like to add thoses ''holes'' on a sphere
      sb could help me ?
      thanks
      regards
      • mitcorbM Offline
        mitcorb
        Hi:
        Is the large gray area the surface of the sphere?
        You could create that 2d outline, extrude it to make a ribbed cylinder component.
        Use something like Component Spray or a similar plugin like Components onto Faces to place them.
        Then intersect them with the sphere. Remove the unwanted geometry.
        This is laborious, I admit, and most likely there is another way.
        You did not specify the number or frequency/spacing of the openings.
        No guarantee for radial/axial alignment relative to the centroid of the sphere.
        • E Offline
          erzane
          yes, the large gray area is the surface of the sphere
          for the rest, I didnt understand well what you re trying to explain me
          • mitcorbM Offline
            mitcorb
            I was suggesting that you populate the surface of the sphere with instances of the dentilated solid "cylinder" by using one of the plugins I named.
            Possibly making a cutting component, such as TIG has discussed elsewhere.
            It might be nice if you would give more information in your user profile. What operating system? What version of Sketchup? Free or Pro? These may have a bearing on how someone else may answer your questions.
            • E Offline
              erzane
              ok I see now better
              I am using skp2013 free & win XP
              Components onto Faces seems to be the best for what I would like to do.
              for be more explicite, my sphere should looks like the moon, with all its craters
              perhaps is there an easier way to do..?
              here is a pic for 100% understanding
              p.s. I took the plugin but I dont know how to install it..
              • E Offline
                erzane
                pls sb could help me ?
                • mitcorbM Offline
                  mitcorb
                  Hi, erzane:
                  I was unable to continue on this, but see this image.
                  Not knowing what su version you had, I did it in v8. But this is just an image in the middle of a process. And not necessarily the best approach.
                  • E Offline
                    erzane
                    thanks for your reply
                    yes it should be smt like this
                    pls how did you do it ?
                    in fact I would like to do smt like this
                    I could make it by hand, but with the help of skp, my geometry would be more precise
                    so, I need a sphere, and in his surface, I would like to put a lot of holes, like some craters, but personaly, I need holes only, nothing more complicated
                    thanks guys, I really need your help
