    Pocket Park
    54 Posts 9 Posters 8.6k Views 9 Watching
    • Bryan KB Offline
      Inside view again, without vegetation.
      • mitcorbM Offline
        mitcorb
        Hi, Bryan:
        Looking really good. I am still watching.
        I like the waterfall wall idea. May create the illusion that the adjacent building is melting 😆
        • Bryan KB Offline
          It's dead. The foliage has made the model too large and I can no longer work with it.
          Any suggestions?
          • mitcorbM Offline
            mitcorb
            The only suggestion that immediately came to mind was possibly using face me type foliage components set up for predetermined scenes.
            I assume you have "purged unused", and so forth?
            • pbacotP Offline
              Coming along nicely. I would try some face me plants. The shadows and all the monochrome is a eerie mix. I would look at scenes without shadowss--or blend shadows in lightly or in Post pro.
              • Bryan KB Offline
                Found a low poly tree in warehouse. More vegetation to add.
                • Bryan KB Offline
                  Yes. Purge is part of everyday workflow now.
                  I wanted to use 3D foliage in order to stay with the monochrome style. Faceme plants doesn't work with textures turned off. 😉
                  Or does it?
                  But I did find the people in faceme. Maybe I can find some monochrome faceme plants as well.
                  Hmmm.
                  • pbacotP Offline
                    • mitcorbM Offline
                      mitcorb
                      Now that you are back at it-- and it is looking great, it would be neat to see those concession structures complementing the gate and fence styling. On the other hand, it might come off as too uniform, or repetitive.
                      I like the plant material's appearance. It looks a lot like Japanese rice paper plants in the leaf.
                      Also, I like your transparent figures.
                      • Bryan KB Offline
                        Almost done.
                        I forgot the streetlights! 😆
                        Click on the last image for larger view.
                        Good suggestion mitcorb. I'm not real happy with the concession stands either.
                        • Bryan KB Offline
                          Good suggestion for the concession stands.
                          Thanks, but I have no idea why those people are transparent. I got them from the warehouse and didn't see they were transparent until I went full texture. 😆 (no credit shown in the warehouse for them)
                          Don't know how to change them either. 😆
                          But I kind of like it.
                          • Bryan KB Offline
                            Street lights and signage added. Water wall updated.
                            Concession stands still need work.
                            Bigger pictures.
                            • mitcorbM Offline
                              mitcorb
                              These are looking great. You have come a long way.
                              I don't know for sure, but there may be a way to opaque your figures if you actually wanted to do it. Might be a little bit of work, because you may have to reassign colors/transparency while retaining outlines, or something like that.
                              I like that you are using the color pallettes from the Sketchup application itself- or it appears that way.
                              • Bryan KB Offline
                                Thanks mitcorb. It was hard regaining the momentum and motivation.
                                Yes, it's pure SketchUp. Ver 8 at that.
                                I think I will leave the people as they are. It's kind of fun.
                                I'll try and finish the concession stands tomorrow and after that will be the final environment placement, but it will only a monochrome, low detail surrounding environment with the park in full color.
                                I'll try and tweak the water wall as well. It's not working for me right now.
                                I really want to finish this one. I'm getting impatient to take a crack at Artisan. I think it's going to be either a robot or a car.
                                • Bryan KB Offline
                                  Minor tweaks.
                                  Water wall. Bridge support thickness. "Floating" trees. Added more benches near concession stands.
                                  • pbacotP Offline
                                    Nice progress. How are those trees treating you. That's looks a little like a project I did a good while ago and turning the trees on, especially with shadows was a killer on performance. I had a layer setup that hid most of the tree parts so I could move them around.
                                    • Bryan KB Offline
                                      The trees are working incredibly well!
                                      It is from the warehouse and credit goes to Mr. Planet.
                                      I have 70 of them in this model and while I do have to wait for moves and shadows off/on, the wait time is less than 10 secs for the initial recalculations, but once SU is ready it stays stable in low poly mode until the move is complete. I can live with that.
                                      • Bryan KB Offline
                                        Park complete.
                                        Next post will be site setting.
                                        • pbacotP Offline
                                          I see you allow skateboarding in your park. Why not, it's not a crime!
                                          • Bryan KB Offline
                                            Of course I do! This isn't an old folks park!
                                            My quick and dirty city.
                                            • 2 / 3
