    Noob seeks advice - starting point re: Text Tables in Grids
    9 Posts 3 Posters 642 Views 3 Watching
      jrandell
      I am doing a series of training videos on the subject of data structure and am looking at using Sketchup.
      I am overwhelmed by how much is out there in the way of templates, plugins, etc. I am concerned that what I want to do has already been thoroughly fleshed out, and that maybe documentation and examples are already out there (but flying under my radar).
      I am specifically interested in showing data tables, pulling apart rows and columns, and showing intersections and joins.
      I think just stacking cubes should be easy enough, but I would like to have the cubes (data cells) display data. Typing text into 3d boxes, for dozens (or hundreds) of rows and columns seems daunting, and I wounder if data can be imported into a 3d grid.
      well, I think you get the idea.
      I am not looking for any free consulting, but wondering if anyone knows of any resources (documentation, plugins, templates, etc) which I might want to check out before starting from scratch.
      with great appreciation for any info you might offer,
      -Jim
      http://www.linkedin.com/in/jimrandell
      [mod=:rdvq0pie]edited to remove phone number.[/mod:rdvq0pie]
      • pbacotP
        Do you have an example of what your end product will be? I wonder if SketchUp is the correct software.
          jrandell
          Thank for you help. Here is a QuickTime which crudely demonstrates what I'm getting after, using the Firefox Inspect Element: 3d Feature.
          http://jimrandell.com/screenshots/3d_data_table_720p.mov
          (this is arbitrarily created data, this is not a list of real people)
            driven
            first thought,
            create an image from your date file and use it as a texture...
              jrandell
              thanks John, but if I did that would I be able to pull apart columns and/or lines, as if they were legos? Thats what I want to do, to demo how data is structured.
                driven
                this is what I was thinking,
                text as paint...quick test
                  driven
                  here's the skp...
                  here's the skp as well
                  if your not seeing the attachment let me know here...
                    jrandell
                    @driven said:
                    here's the skp...
                    [attachment=0:jdgfsdyo]<!-- ia0 -->cvs_model.skp<!-- ia0 -->[/attachment:jdgfsdyo]
                    WOW, THANKS!
                    I opened it in sketchup and it sure looks like what I want.
                    I am so grateful, I almost hate to ask this, but can tell me the name of the feature(s), techniques, and anything else I can search on. so I can read up on it.
                    If I can find my way to the right documentation, I think I'm good to go from here.
                    Thanks Again (!!!)
                    -Jim
                      driven
                      post a representative sample of your csv file and I'll make a short tutorial...
                      basic are:
                      create an image from your data - open your data >> Print >> save as PDF >> open in Preview >> export Tiff .
                      in SU - draw a rectangle same digits as your image pixels [ i.e. 430, 660 in Measurements box ] >> 'push/pull' a little
                      open Materials >> Color >> New Texture and import your Tiff >> Paint the face
                      use 'line tool' to divide your face [ you can use others as well ]
                      push/pull your amounts...
