Export Options
When I export my SKP file to a 2d .dwg file, all the linework gets scaled up about 125%. But when I do so as a 3d .dwg, it comes in scaled to the exact SKP file measurements.
I noticed that the 2d export window shows a Drawing Scale and Size input, but they are greyed out, not accessible for input. Is this the culprit?
Thanks.
Figured it out. It helps to read the manual
Scaling inputs can only be done when the camera is in Parallel Projection.
