    Create file with accent in the path
    23 Posts 3 Posters 1.8k Views 3 Watching
    • IltisI Offline
      Iltis
      Hello,
      I'm working on a plugin and have this encoding problem : if there is "è" in the path, the file is not created :
      # Open a file for writing
      	  File.open(filepath, "w"){ |file|
      		  file.puts("Blabla")
      Do you know how to fix it?
      (Test mith Sk7 on Windows7).
      Thanks and regards,
      Renaud.
      • IltisI Offline
        Iltis
        Thank you very much.
        I will try with the last version of SketchUp.
        The link is dead.
        • Dan RathbunD Offline
          Dan Rathbun
          Unicode support in Ruby comes only in v1.9 and higher.
          So, with SketchUp Ruby, only in versions 2014 and higher.
          SketchUp 2013 and earlier versions can only run Ruby 1.8.x, which does not have unicode support.
          TIG wrote a library that can be used for rudimentary unicode characters in path strings.
          [Code] PCFileTools
          I'm not here much anymore.
            Dan Rathbun
            @iltis said:
            The link is dead.
            Sorry.. I fixed it: [Code] PCFileTools
            • tt_suT Offline
              tt_su
              If you really need to handle Unicode filenames in Ruby 1.8 you would need to write a Ruby C Extension that makes calls to the Windows Unicode version of its file functions.
              • IltisI Offline
                Iltis
                Thank you for your answer, but it's too high for me, ruby's newbie.
                Actually, if the file is not created, nothing happen, the user can't know that a problem occured.
                Is it possible to know if there is a problem?
                => If the file "filepath" is not created then Messagebox "You're using SketchUp 2013 or earlier version, the path of your file name can't use accented characters like é,e,è. The file will not be created. If you want to use accented characters in the path, you must use SketchUp 2014 minimum".
                Sorry for my "frenglish".
                Regards,
                Renaud.
                • tt_suT Offline
                  tt_su
                  I'd think there would be Ruby exceptions raised so you could try to catch these and present a failure message. You could also explicitly see if the file exist after you have tried to create it: File.exist?()
                  • IltisI Offline
                    Iltis
                    File.exist? doesn't work, for same reasons... 😞
                    • tt_suT Offline
                      tt_su
                      Doesn't work, as in it raises an error? Then you can rescue from that error and provide your message to the user.
                      • IltisI Offline
                        Iltis
                        Mhhh, I've got a problem with my test :
                        UI.messagebox(filepath)
                        			selection = Sketchup.active_model.selection
                        				# Write the coordinates to the file.
                        				file.puts("#{u};#{v}")
                        		 UI.messagebox("FileTest")
                        		 if FileTest.exists?(filepath)
                        			UI.messagebox("The file is there")
                        		 else
                        			UI.messagebox("The file is not there")
                        The first messagebox give me the path : "C:\Users\Tarzan\Documents\aiR-C2\MiniCut2d\Bibliothèque\test.txt"
                        But no more messagebox after the "File.open"... do you know why?
                        But if I understand this topic (http://sketchucation.com/forums/viewtopic.php?t=20289), the ".exists?" is not the solution.
                        • tt_suT Offline
                          tt_su
                          In the Ruby Console do you see error messages? What I meant was to catch there errors, using begin, rescue.
                          • IltisI Offline
                            Iltis
                            OK, I see the error in the Ruby Console (thank you for the tip) :
                            Error: #<Errno::ENOENT: No such file or directory - C:/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
                            I will try to catch it.
                            • IltisI Offline
                              Iltis
                              OK, this code works on SU8 :
                              		  begin
                              		 	UI.messagebox("The file is here ;" + filepath)
                              		rescue
                              		 	UI.messagebox("Error, the file was not created. Be careful if you are using an older version of SketchUp, the full file path must not contain special or accented characters. The full file path you requested is " + filepath)
                              The "è" looks "è" in the messagebox, but the user know how to fix the problem.
                              I try to use it in SketchUp 2014, but I've got an error 😞
                              Erreur de chargement du fichier faces2xy.rb
                              Error; #<SyntaxError; C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ',', expecting ')'
                              		  filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
                              C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; Can't assign to nil
                              C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ')', expecting ;; or '[' or '.'
                              Do you know how to fix this (in all SU versions...)?
                              Thanks,
                              Renaud
                              • tt_suT Offline
                                tt_su
                                That's odd - if the string is UTF-8 encoded then it should look fine in SketchUp regardless.
                                Have you saved your RB files as UTF-8 without BOM?
                                I'm not sure, but I think it could be that space you have between the method name and the parentheses: filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
                                But the error could be cascading some elsewhere... hard to tell without knowing the source code.
                                Btw, it's recommended not to catch all exceptions, but only the ones you expect.
                                http://www.skorks.com/2009/09/ruby-exceptions-and-exception-handling/
                                • IltisI Offline
                                  Iltis
                                  Bingo! 2/2. It works fine now. Is "UTF-8 without BOM" the best to use? (Default value?)
                                  Thank you for the quick answer!
                                  I will see how to catch only the file exception.
                                  • IltisI Offline
                                    Iltis
                                    Mhh, the error is
                                    Error; #<Errno;;ENOENT; No such file or directory - C;/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
                                    I don't understand how to only catch this type of exception... (not in the "Ruby Exception Hierarchy"). I'll see this later.
                                    • tt_suT Offline
                                      tt_su
                                      I recommend that because without the BOM you can load the file in Ruby 1.8. With the BOM Ruby 1.8 will not load it.
                                      • tt_suT Offline
                                        tt_su
                                        @iltis said:
                                        Mhh, the error is
                                        You should be able to catch Errno::ENOENT - it's a class inherited form StandardError.
                                        Errno::ENOENT.ancestors [Errno::ENOENT, SystemCallError, StandardError, Exception, Object, PP::ObjectMixin, JSON::Ext::Generator::GeneratorMethods::Object, Kernel, BasicObject]
                                        Though, it might be system dependant... Maybe catching SystemCallError is a good one to catch for these types of errors.
                                        • IltisI Offline
                                          Iltis
                                          OK, thank you.
                                            Dan Rathbun
                                            Like this:
                                              begin
                                              rescue SystemCallError => e
                                                if e.message =~ /(No such file or directory)/
                                                else
                                                  fail() #re-raise the last exception
