    Create file with accent in the path
    23 Posts 3 Posters 2.0k Views 3 Watching
    • tt_suT Offline
      tt_su
      I'd think there would be Ruby exceptions raised so you could try to catch these and present a failure message. You could also explicitly see if the file exist after you have tried to create it: File.exist?()
      • IltisI Offline
        Iltis
        File.exist? doesn't work, for same reasons... 😞
        • tt_suT Offline
          tt_su
          Doesn't work, as in it raises an error? Then you can rescue from that error and provide your message to the user.
          • IltisI Offline
            Iltis
            Mhhh, I've got a problem with my test :
            UI.messagebox(filepath)
            		  # Open a file for writing
            		  File.open(filepath, "w"){ |file|
            			selection = Sketchup.active_model.selection
            				# Write the coordinates to the file.
            				file.puts("#{u};#{v}")
            		 UI.messagebox("FileTest")
            		 if FileTest.exists?(filepath)
            			UI.messagebox("The file is there")
            		 else
            			UI.messagebox("The file is not there")
            The first messagebox give me the path : "C:\Users\Tarzan\Documents\aiR-C2\MiniCut2d\Bibliothèque\test.txt"
            But no more messagebox after the "File.open"... do you know why?
            But if I understand this topic (http://sketchucation.com/forums/viewtopic.php?t=20289), the ".exists?" is not the solution.
            • tt_suT Offline
              tt_su
              In the Ruby Console do you see error messages? What I meant was to catch there errors, using begin, rescue.
              • IltisI Offline
                Iltis
                OK, I see the error in the Ruby Console (thank you for the tip) :
                Error: #<Errno::ENOENT: No such file or directory - C:/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
                I will try to catch it.
                • IltisI Offline
                  Iltis
                  OK, this code works on SU8 :
                  		  begin
                  		 	UI.messagebox("The file is here ;" + filepath)
                  		rescue
                  		 	UI.messagebox("Error, the file was not created. Be careful if you are using an older version of SketchUp, the full file path must not contain special or accented characters. The full file path you requested is " + filepath)
                  The "è" looks "è" in the messagebox, but the user know how to fix the problem.
                  I try to use it in SketchUp 2014, but I've got an error 😞
                  Erreur de chargement du fichier faces2xy.rb
                  Error; #<SyntaxError; C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ',', expecting ')'
                  		  filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
                  C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; Can't assign to nil
                  C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ')', expecting ;; or '[' or '.'
                  Do you know how to fix this (in all SU versions...)?
                  Thanks,
                  Renaud
                  • tt_suT Offline
                    tt_su
                    That's odd - if the string is UTF-8 encoded then it should look fine in SketchUp regardless.
                    Have you saved your RB files as UTF-8 without BOM?
                    I'm not sure, but I think it could be that space you have between the method name and the parentheses: filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
                    But the error could be cascading some elsewhere... hard to tell without knowing the source code.
                    Btw, it's recommended not to catch all exceptions, but only the ones you expect.
                    http://www.skorks.com/2009/09/ruby-exceptions-and-exception-handling/
                    • IltisI Offline
                      Iltis
                      Bingo! 2/2. It works fine now. Is "UTF-8 without BOM" the best to use? (Default value?)
                      Thank you for the quick answer!
                      I will see how to catch only the file exception.
                      • IltisI Offline
                        Iltis
                        Mhh, the error is
                        Error; #<Errno;;ENOENT; No such file or directory - C;/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
                        I don't understand how to only catch this type of exception... (not in the "Ruby Exception Hierarchy"). I'll see this later.
                        • tt_suT Offline
                          tt_su
                          I recommend that because without the BOM you can load the file in Ruby 1.8. With the BOM Ruby 1.8 will not load it.
                          • tt_suT Offline
                            tt_su
                            @iltis said:
                            Mhh, the error is
                            You should be able to catch Errno::ENOENT - it's a class inherited form StandardError.
                            Errno::ENOENT.ancestors [Errno::ENOENT, SystemCallError, StandardError, Exception, Object, PP::ObjectMixin, JSON::Ext::Generator::GeneratorMethods::Object, Kernel, BasicObject]
                            Though, it might be system dependant... Maybe catching SystemCallError is a good one to catch for these types of errors.
                            • IltisI Offline
                              Iltis
                              OK, thank you.
                              • Dan RathbunD Offline
                                Dan Rathbun
                                Like this:
                                  begin
                                  rescue SystemCallError => e
                                    if e.message =~ /(No such file or directory)/
                                    else
                                      fail() #re-raise the last exception
                                I'm not here much anymore.
                                • IltisI Offline
                                  Iltis
                                  Nice, thank you Dan!
                                  • tt_suT Offline
                                    tt_su
                                    Never seen that method used before. Is that different from just calling raise?
                                      Dan Rathbun
                                      raise() is an alias for fail()
                                      See the doc on the Kernel module:
                                      http://www.ruby-doc.org/core-1.8.6/Kernel.html#method-i-fail
                                      The best practices guides I have read, suggest that fail be used instead of raise, for readability, I suppose. But I really did not understand the logic in the guide. (I think it was something like "raise" has more meanings as a verb than "fail" ?)
