    Create file with accent in the path
    23 Posts 3 Posters 2.2k Views 3 Watching
    • IltisI
      Iltis
      Mhhh, I've got a problem with my test :
      UI.messagebox(filepath)
      		  # Open a file for writing
      		  File.open(filepath, "w"){ |file|
      			selection = Sketchup.active_model.selection
      				# Write the coordinates to the file.
      				file.puts("#{u};#{v}")
      		 UI.messagebox("FileTest")
      		 if FileTest.exists?(filepath)
      			UI.messagebox("The file is there")
      		 else
      			UI.messagebox("The file is not there")
      The first messagebox give me the path : "C:\Users\Tarzan\Documents\aiR-C2\MiniCut2d\Bibliothèque\test.txt"
      But no more messagebox after the "File.open"... do you know why?
      But if I understand this topic (http://sketchucation.com/forums/viewtopic.php?t=20289), the ".exists?" is not the solution.
      • tt_suT
        tt_su
        In the Ruby Console do you see error messages? What I meant was to catch there errors, using begin, rescue.
        • IltisI
          Iltis
          OK, I see the error in the Ruby Console (thank you for the tip) :
          Error: #<Errno::ENOENT: No such file or directory - C:/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
          I will try to catch it.
          • IltisI
            Iltis
            OK, this code works on SU8 :
            		  begin
            		 	UI.messagebox("The file is here ;" + filepath)
            		rescue
            		 	UI.messagebox("Error, the file was not created. Be careful if you are using an older version of SketchUp, the full file path must not contain special or accented characters. The full file path you requested is " + filepath)
            The "è" looks "è" in the messagebox, but the user know how to fix the problem.
            I try to use it in SketchUp 2014, but I've got an error 😞
            Erreur de chargement du fichier faces2xy.rb
            Error; #<SyntaxError; C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ',', expecting ')'
            		  filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
            C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; Can't assign to nil
            C;/Users/Tarzan/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/faces2xy.rb;18; syntax error, unexpected ')', expecting ;; or '[' or '.'
            Do you know how to fix this (in all SU versions...)?
            Thanks,
            Renaud
            • tt_suT
              tt_su
              That's odd - if the string is UTF-8 encoded then it should look fine in SketchUp regardless.
              Have you saved your RB files as UTF-8 without BOM?
              I'm not sure, but I think it could be that space you have between the method name and the parentheses: filepath = UI.savepanel ("Export selected faces",nil,"*.f2xy")
              But the error could be cascading some elsewhere... hard to tell without knowing the source code.
              Btw, it's recommended not to catch all exceptions, but only the ones you expect.
              http://www.skorks.com/2009/09/ruby-exceptions-and-exception-handling/
              • IltisI
                Iltis
                Bingo! 2/2. It works fine now. Is "UTF-8 without BOM" the best to use? (Default value?)
                Thank you for the quick answer!
                I will see how to catch only the file exception.
                • IltisI
                  Iltis
                  Mhh, the error is
                  Error; #<Errno;;ENOENT; No such file or directory - C;/Users/Tarzan/Documents/aiR-C2/MiniCut2d/Bibliothèque/test.f2xy>
                  I don't understand how to only catch this type of exception... (not in the "Ruby Exception Hierarchy"). I'll see this later.
                  • tt_suT
                    tt_su
                    I recommend that because without the BOM you can load the file in Ruby 1.8. With the BOM Ruby 1.8 will not load it.
                    • tt_suT
                      tt_su
                      @iltis said:
                      Mhh, the error is
                      You should be able to catch Errno::ENOENT - it's a class inherited form StandardError.
                      Errno::ENOENT.ancestors [Errno::ENOENT, SystemCallError, StandardError, Exception, Object, PP::ObjectMixin, JSON::Ext::Generator::GeneratorMethods::Object, Kernel, BasicObject]
                      Though, it might be system dependant... Maybe catching SystemCallError is a good one to catch for these types of errors.
                      • IltisI
                        Iltis
                        OK, thank you.
                        • Dan RathbunD
                          Dan Rathbun
                          Like this:
                            begin
                            rescue SystemCallError => e
                              if e.message =~ /(No such file or directory)/
                              else
                                fail() #re-raise the last exception
                          I'm not here much anymore.
                          • IltisI
                            Iltis
                            Nice, thank you Dan!
                            • tt_suT
                              tt_su
                              Never seen that method used before. Is that different from just calling raise?
                              • Dan RathbunD
                                Dan Rathbun
                                raise() is an alias for fail()
                                See the doc on the Kernel module:
                                http://www.ruby-doc.org/core-1.8.6/Kernel.html#method-i-fail
                                The best practices guides I have read, suggest that fail be used instead of raise, for readability, I suppose. But I really did not understand the logic in the guide. (I think it was something like "raise" has more meanings as a verb than "fail" ?)
