    FROM MAX AND BLENDER TO SKETCHUP
    extensions
    3 Posts 2 Posters 718 Views 2 Watching
    • W Offline
      wakimaya
      HI DEARS
      I AM A NEW TRANSFORMER FROM MAX AND BLENDER TO EKETCHUP 2014 PRO AND I HAVE MODELS IN MAX AND BLENDER WHEN I EXPORT THATS MODELS IN .OBJ OR .3DS FORMATE TO SKETCHUP THE SKETCHUP CAN IMPORT THATS FORMAYS BUT THE PROBLEM IS I CANT EDIT THATS OBJECT AND NOT APPEARE IN RENDRING BY VRAY CAN YOU HELP ME PLEASE THANKS
      • mitcorbM Offline
        mitcorb
        Hi, haithan:
        Welcome.
        Rather than let this post sink into oblivion, I thought to provide some suggestions.
        I do not have Max and Blender at this time. But, I vaguely recall in past discussions in this forum that there may be some setting options you need to select prior to export. If not that, then some setting for import into Sketchup. If not that, then the stuff is arriving as either groups or components, which need to be edited or exploded. But doing this may affect any materials or textures you have established.
        Hopefully, someone with this expertise will notice and help you.
        As a matter of courtesy, it is better to type in standard case, rather than all caps or uppercase.
        Best wishes to you.
        • W Offline
          wakimaya
          i am very thanks to you
          i am trying explode the groupe and appling material after that the objects appeare in render
          thaks to your interesting
