    3D Visuals for Grand Designs Live in London/Bulbgate
    53 Posts 12 Posters 3.6k Views 12 Watching
    • cottyC Offline
      cotty
      If you save your images in PS, you can "save for web..." (I don't know the English name, it's in the file menu) and choose to delete meta data to reduce filesize (or to improve image quality at maximum filesize allowed).
      my SketchUp gallery
      • neetsN Offline
        neets
        Alright guys, I've taken on board pretty much all of Massimo's feedback (this thread will forever be known as 'bulbgate'!). I studied countless bulbs, and their reflections etc. to try and get a similar photo-real look in my render. Interestingly, these bulbs in real life, have a reflection of the filament. They look like little flames. I wasn't able to get this look with my original render but when I tweaked the material settings I DID get this effect. A testament to the accuracy of unbiased rendering engines? Absolutely!
        This is the original render, pre-bulbgate.
        I'm not sure why this happens, but every single time I upload images onto this forum the image quality reduces. No matter what method I use to save it. If anyone can shed any light (pardon the pun), on this for me. I'd be very grateful.
        After changing the angle, cleaning up image to reduce noise, improving the bulb material settings and adding 'dirt' and inconsistencies to the brass fitting, this is how it looks now. I guess you need to click on it to get a better look. As I said, I'm having weird upload problems. What's annoying me though, is that the image is blown up way too big for the original resolution too (when you click on it).
        Anyway, I'm feeling much better about the new and improved image. Thanks for your input, Massimo.
        Anita
        Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
        • RichardR Offline
          Richard
          Oh Bugger! The critique argument again! Seriously critique is THE BEST THING IN THE WORLD!!
          There is always too much back patting and we need to be encouraged to speak up to help others improve. I wish Massimo would be just as constructive with my posts, he's one of my heroes and his comments are always considered and to be considered!
          BUILTBRAND.COM.AU
          • neetsN Offline
            neets
            Lol, the critique argument is old news! I think we discussed that more than enough. My last post is most definitely illustrative of the benefits of taking feedback on board πŸ˜‰
            • RichardR Offline
              Richard
              Anita, that bulb is looking AWESOME!
              If you want it to cast more light but not effect the over bightness of the filament in the final image, you can rap the light in a "hidden from camera" cube with emitter planes.
              Great job!!!!
              BUILTBRAND.COM.AU
              • neetsN Offline
                neets
                Haha, I'm not entirely sure if you're trying to humour me!! Either way, thanks!
                Thanks re: emitter tip. I know what you mean about placing a hidden emitter - I did that with the one in the background (you can see a slight glow on the wall). All of my scenes have hidden emitters all over the place! You can't have enough. What I have found though, is that trying to cast more general light onto an object using a hidden emitter (like a photographer would do) doesn't really have the desired effect. I've seen tutorials on it and I've tried placing planes (quite small) in directional areas and the light they emit is pants. Am I doing something wrong?
                • RichardR Offline
                  Richard
                  If you want to diffuse the light more you could try an IBL - use a circular gradient filled image (light cream centered | black rim) you can create a HDRI in PS or open the image in Maxwell Render (the actual render app not the studio. Then save as MXI.
                  Obviously paint the emitter with the JPG version of the image for scaling then link this to the MXI file.
                  Also if you want a diffused directional light make sure the light has blinkers, use matt black on these. You can put baffles in it for more direction.
                  BUILTBRAND.COM.AU
                  • massimoM Offline
                    massimo Moderator
                    Couldn't agree more. I've learned a lot, and I'm still learning, from Richard's criticisms and suggestions and from the lucidity and quality of his work.
                    Nice improvement on the bulb Anita. πŸ‘
                    • neetsN Offline
                      neets
                      Massimo, I think when it comes to 3D modelling and rendering, the path of discovery is a continual one. Which is extremely frustrating! But at least you can always see the gradual improvements you are making. Thank you, I honestly hope that you like it. I could have probably spent a little more time on the brass fitting but I'm getting to the stage where I'm sick of looking at the bulb (and I used to love them!).
                      • neetsN Offline
                        neets
                        Richard, thanks for your tips. I'm going to have to discuss this with you in more detail!!
                        • neetsN Offline
                          neets
                          Dudes! I uploaded my render on Twitter and copied SketchUp and Maxwell Render into it and was contacted by someone from Maxwell Render asking if they could use my render in their online gallery and/or promotional material!!!! How flippin' awesome is that??!!
                          I'm going to check their website on the hour, EVERY hour to see when they upload it!
                          • olisheaO Offline
                            olishea
                            I hope they paid you. If it benefits them, it should benefit you. πŸ˜‰
                            oli
                            • neetsN Offline
                              neets
                              Oli, if only! Nope, no payment but to be honest the accolade is more important than any financial gain πŸ˜„
                              • pbacotP Offline
                                Good job. The I Ching has a saying that keeps recurring: "Perseverance Furthers".
                                • neetsN Offline
                                  neets
                                  Thanks Peter. You're so right about perseverance but it can be a drag!
                                  • RichardR Offline
                                    Richard
                                    That is AWESOME! That puts you with some VERY talented CG artists! I'm impressed!
                                    BUILTBRAND.COM.AU
                                    • neetsN Offline
                                      neets
                                      Thanks Richard! I had to 'clean up' the artefacts in my original image (I didn't notice that there was noise or something on the left-hand side of the brass fitting), it must have happened during post-processing. So I sent them an adjusted version, completed a permission form and I'm good to go! They said they'd let me know when they were going to upload it. Then they asked if I'd do a 'Making of' case study for them!! How cool is that?! Would it be frowned upon if I said my workflow involved putting my laptop in a headlock, drinking copious amounts of wine and munching on Cheetos??!
                                      I really have to thank Massimo for making me look at my initial upload from an objective point of view. If it wasn't for his critique, I would never have pushed myself further to try and get a much more realistic render.
                                      • RichardR Offline
                                        Richard
                                        Seriously you aren't alone with battling emitters, you certainly picked a hard one! BTW is your glass to the bulb AGS or real glass?
                                        I put a george nelson shade in a client render the other day - spent SO LONG to get it almost right and then they didn't like the fitting so luckily I didn't have to pull hair to get it absolutely right!
                                        I congratulate you for taking Massimo's critique on board - Sometimes we have battled SO hard to get something we are so proud of, yet as often so attached that critique is hard to swallow. The truth is that we had our heads stuck where they shouldn't be. When we extract it and be strong with an "f*** you!" attitude to "I'll show you!", we nail things that without that encouragement, we'd have sat thinking my best, when the truth is we have another dimension to our best!
                                        Well done!
                                        BUILTBRAND.COM.AU
                                        • RichardR Offline
                                          Richard
                                          BTW could you please post to the original post, the first image! I think late comers may comment negatively too, if like me they hadn't got to page 2 of the post before commenting!
                                          BUILTBRAND.COM.AU
                                          • tademaT Offline
                                            tadema
                                            πŸ˜†
                                            • 3 / 3
