    House wall
    13 Posts 4 Posters 1.0k Views 4 Watching
    • cottyC Offline
      cotty
      A part of the wall of my house...
      my SketchUp gallery
        kaas
        Do you really need the OSB between the two insulation layers?
        • cottyC Offline
          cotty
          The outer part was prefabricated and the inner installation layer was added by me. Additionionally it forms the air tightness plane.
          my SketchUp gallery
          • pbacotP Offline
            impressive 👍 👍
            • mitcorbM Offline
              mitcorb
              Hi, cotty:
              I am wondering, did you need additional thermal protection, or acoustic insulation?
              • cottyC Offline
                cotty
                The wall is 43 cm thick, so there is no need for further insulation and it is very quite inside (if the children are not in the house).
                @pbacot: thank you!
                my SketchUp gallery
                • mitcorbM Offline
                  mitcorb
                  So, then, is humidity and dew point an issue in your region?
                  • cottyC Offline
                    cotty
                    We have a ventilation system and the walls are open to diffusion.
                    my SketchUp gallery
                    • mitcorbM Offline
                      mitcorb
                      Ok that's good 😄
                      • pbacotP Offline
                        With solid foam like that, isn't the dewpoint pushed to the exterior anyway?
                        My parents built a cottage all of SIP panels roof and walls and it's functioned really well for many years in an area that does freeze (though not as much as northern Europe)
                        • cottyC Offline
                          cotty
                          There's only rock wool and wood fiber board in it, but yes.
                          my SketchUp gallery
                          • pbacotP Offline
                            I thought it was foam. You need the foam tight or adhered to the outside face at least to keep the dewpoint outside the structure (AFAIK). P
                            • cottyC Offline
                              cotty
                              I'm not an expert, but this construction is a very common one for energy saving houses. It it important that there is a good air tightness leve so that no humidity gets into the wall.
                              my SketchUp gallery
