    [Plugin] LaunchUp – A Quick Launcher for SketchUp
    108 Posts 33 Posters 103.1k Views 33 Watching
    • E
      ephi
      cool tool
      • bsintzelB
        bsintzel
        Thanks for the tip. I'll give it a go. I suspect what I'm asking for would really require a GUI redesign.
        I've taken obfuscating to a whole new level!
        • masterpaulM
          masterpaul
          For some reason launchup fails to find any plugin.
          Edit: Problem fixed after I gave sketchup full administrative powers.
          • V
            vicxp0518
            I've figured out that this plugin will cause a major slow down with selecting, component editing, layer visibility switching, and something else.
            I hope I was wrong but when I suffer with the annoying problem, there seems no way out, but when I disable this plugin, everything gets back to fine normal. I don't know why this would happen, but it really occurs on my larger models.
              Aerilius
              I will look into it. Though I don't know what could cause this (the plugin does not use observers, and should not be triggered when you change a layer etc.). Can you tell me how many plugins you have and how components and layers in the model?
              • T
                tommy.jhd
                Thanks so much for this plugin.
                The options dialog for version 0.15 seems to be broken though. None of the options affect the main Launchup dialog. I've checked this in 2013pro and 8free.
                This issue doesn't happen with version 0.08 (I'd kept this from an old installation). The options dialog works great here.
                Separately - when the Launchup dialog overlaps the main Sketchup window its size keeps resetting to fit 'Type to search...' I've checked this on 2013pro and 8free.
                I'm going to revert back to version 0.08 as that works really well for me.
                • panixiaP
                  panixia
                  i've got the same exact problem how can i download version .08 to try solve it?
                    Aerilius
                    I cannot reproduce such an issue in a clean install of SketchUp and with either plugin version 1.0.15 or 1.0.8. That means I need more precise info, namely when you open the Ruby console, is there any output?
                    It's a very old version and I'm much further, about to release 1.1.0 (which is supposed to be reviewed by EWH, but there is nothing happening over a weeks…). I'd rather give you that to test.
                    What you see is that the dialog continuously reduces its width, which I've seen under rare circumstances on some Windows 7. After re-opening the dialog it's often gone. It is because the SketchUp API has been unhandily designed to set the width including the window border, which requires unstable work-arounds. I don't see anything I can improve, but version 1.1.0 could be better.
                    By the way, what is your UI scaling factor (or dpi)?
                    • OxerO
                      Oxer
                      I installed the plugin v1.0.15 and it appears a Load Errors when SU runs:
                      %(#BF0040)[Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/LaunchUp.rb
                      Error: #<SyntaxError: /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/commands/Commands.rb:366: syntax error, unexpected modifier_rescue, expecting ')'
                      if not (Sketchup.send_action(21083) rescue false)
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/commands/Commands.rb:375: syntax error, unexpected keyword_end, expecting '}'>
                      /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in `require'
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/LaunchUp.rb:99:in `module:LaunchUp'
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/LaunchUp.rb:82:in `module:AE'
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp/LaunchUp.rb:78:in `<top (required)>'
                      /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
                      /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp.rb:15:in `register_extension'
                      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/!ae_LaunchUp.rb:15:in `<top (required)>']
                      I work on Mac OSX Mavericks & SU2014
                        Aerilius
                        Surprise! I said, 1.0.15 is not supported. It will be updated soon. Also nowhere does it say that it supports SketchUp 2014.
                        • OxerO
                          Oxer
                          Excuse me, I didn't read all the post. 😳
                          I'll wait the new version compatible with SU2014. 😒
                            Aerilius
                            I finished the update!
                            • G
                              glro
                              i am experiencing slowdown of sketchup also, with the last version
                              Have to desinstal it because i cannot use anymore my other plugins...
                              • G
                                glro
                                Maybe launchup is not responsible for the slowdown
                                i have increased a lot the size of my components folder, recently; one folder is 129 MB and another 102
                                And i use launchup together with "CLibrairies_loader.rb", to call components as well as plugins
                                I understand now that "CLibrairies_loader.rb" must be the one slowing down sketchup, because it has so many components to load.
                                  Aerilius
                                  Thank you!
                                  I didn't find any further hint what could cause slowdowns, but if CLibraries creates menu items for components (for all components?) it could be related.
                                  LaunchUp uses an index of all menu items. I would expect a larger index could eventually slow down the startup and the search inside LaunchUp but shouln't affect SketchUp when LaunchUp is not used.
                                  More components could also slowdown the components browser. But as long as components are not added into the model, they shouldn't affect SketchUp's general performance when the components browser is not used.
                                  Could you check how many plugin-created menu items there are?
                                  c=0; ObjectSpace.each_object(UI::Command){ c+=1 }; c
                                  • G
                                    glro
                                    @aerilius said:
                                    Thank you!
                                    i typed
                                    i got
                                    70
                                    • deaneauD
                                      deaneau
                                      @Aerilius is it possible to update your awesome plugin to sketchup 2017?
                                      thank you
                                      • OxerO
                                        Oxer
                                        +1 👍
                                        • dereiD
                                          derei
                                          I'm wondering if this plugin is being maintained, as it seems to have some connections with Toolbar Editor plugin (perhaps a reason for both acting weird in the latest SU versions?).
                                          DESIGNER AND ARTIST DEREI.UK
                                          • designerbursaD
                                            designerbursa
                                            I am using sketchup 2021. After running the plugin, all other plugins give an error.
                                            Error in C:/Users/samib/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/!ae_LaunchUp/interception.rb:126 for add_item
                                            break from proc-closure
                                            C:/Users/samib/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/!ae_LaunchUp/index.rb:138:in block in load_menus' (eval):5:in block in observe_instance_method'
                                            C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/context_menu:10:in block in init' Error in C:/Users/samib/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/!ae_LaunchUp/interception.rb:126 for add_item break from proc-closure C:/Users/samib/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/!ae_LaunchUp/index.rb:138:in block in load_menus'
                                            • 5 / 6
