    A Style Experiment
    24 Posts 12 Posters 4.7k Views 12 Watching
      Thank you, gentlemen.
      Jan, there are two tricks to get the arcs and curves to display as I show them. First, the style needs to have the shortest line segments available. The other is to make sure all curves are welded. The arm rests on the Adirondack chairs and a number of separate curves. I made sure to weld them before applying the style. If the curves aren't welded, each short line segment gets treated independently of its neighbors. And if the segments are shorter than the shortest line in the style, it doesn't get displayed at all.
      When I create my sketchy styles now I make 10 lines of each of the 7 different lengths available so there's a lot of variability in the lines. 16 is the shortest available length but I would like to have the option for 8. I'd also like to have a couple of even longer lengths available as well as the ability to include more than 10 of each length.
      • PixeroP Offline
        Pixero
        Thanks for the info. Didnt know about weld. πŸ‘
          db11
          @dave r said:
          I'll have to write a short instruction sheet and package it up.
          Would love to know how you create a style like this / how much work it is.
          I'm sure I'm not the only one that will appreciate your instruction.
            It really isn't much work to get the images as I show them. I'll make up an instruction sheet and put the package together this evening.
              • cottyC Offline
                cotty
                Looks VERY nice!
                my SketchUp gallery
                  It's now available in the Shop.
                  • boofredlayB Offline
                    boofredlay
                    I really enjoy seeing all your new styles.
                      Thank you, Eric.
                      • RichardR Offline
                        Richard
                        You are without doubt the style MASTER dave!!
                        That said the marker pen style doesn't require the dirty background ie pencil rub!
                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                          Thank you Richard. I agree with you. Fortunately that's not really part of the style. πŸ˜‰
                          • olisheaO Offline
                            olishea
                            This one's my favourite. πŸ˜„
                            oli
                            • 2 / 2
