    Intersecting lines with faces
    2 Posts 2 Posters 1.8k Views 2 Watching
    • ANBenderA
      ANBender
      Hello Friends at Sketchucation,
      Thanks so much for your help with my last question! Another question; I often have a very difficult time intersecting lines with a face that they are supposed to be in contact with. If the lines do not intersect you cannot cut it out or pull the shape off of the face. It gets very frustrating with Sketchup when things do not intersect. Is there a plug-in that would automatically place lines on the face if for some reason they happen to be slightly off of the face. The plug-in would check for all lines within so close to a face and automatically move them to the face. Hopefully they then would intersect with the face. Or is there anything that would help with the intersecting problem?
      Thanks in advance.
      Amos Bender β˜€
        You can "extrude" the selected lines with the fabulous "Projections" plugin by Didier Bur 😎
        Then Intersections with anything will be more easy! β˜€
        Last icon πŸ€“
        http://sketchucation.com/forums/download/file.php?id=30105
