    [Plugin] Remove Inner Faces
    23 Posts 15 Posters 33.3k Views 15 Watching
    • PixeroP
      Pixero
      the subdive and smooth plugin set has a tool that does what ur asking for however u cant control how much it extrudes (which is a bit silly really) it just extrudes a bit to give you those extra faces then u have to manually drag it to the legth u want
      Yeah, that tool would be great to have as a standalone script as an alternative to the normal pushpull tool.
      • W
        wikii
        module Wikii
        def Wikii.remove_inner_faces
          fs=[]
          Sketchup.active_model.selection.each{|x|
          if x.typename=="Face"
            to_be_delete=true
            x.outer_loop.edges.each{|y|
            if  y.faces.length<=2
              to_be_delete=nil
              break
            fs << x if to_be_delete
            Sketchup.active_model.start_operation "remove_inner_faces"
            fs.each{|x| x.erase!}
            puts fs.length.to_s+" faces removed !"
            Sketchup.active_model.commit_operation
          #Wikii.remove_inner_faces
          @WiKii
          How use that? With the ruby console? 😳
          I am not ruby expert πŸ˜’
            Matt666
            Hi Pilou !
            1- Copy the code in a a new notepad file.
            2- Copy this code below, in the file
            if not file_loaded?("remove_inner_faces.rb")
            	UI.menu("Plugins").add_item("Remove inner faces"){Wikii.remove_inner_faces}
            file_loaded("remove_inner_faces.rb")
            2- Save it as "remove_inner_faces.rb".
            3- Move the file in plugins folder.
            4- Restart SU.
            πŸ˜‰
            Frenglish at its best !
            My scripts
            • GaieusG
              ... only forgotten to scroll the first code of Wikii so some lines are missing 😳 ...
              There is a "Select all" link on the top of the code snipplet - if you use that, you can make sure not to leave anything out in the future (or click in the code field and hit Ctrl+A then Ctrl+C)
                Yes for the next time it will be more easy! πŸ˜„
                  Ok I have made the steps above 1 2, 2(?) 3 4
                  but "syntax error line 16" (last line) ❓
                  Error Loading File remove_inner_faces.rb
                  C:/Program Files/Google/Google SketchUp 6/Plugins/remove_inner_faces.rb:16: syntax error
                  Edit 😳 :
                  I only forgotten to scroll the first code of Wikii so some lines are missing 😳
                  All works fine! πŸ‘
                  You are genious!!! β˜€
                  Ruby linked by Wiiki
                  remove_inner_faces.zip
                  • E
                    EA-d
                    Does exist a ruby script for kill the internal surfaces but not the edges of these surfaces (after a Pushpull + Ctrl for example)?
                    [/attachment]
                    How about one for killing external surfaces, after an intersection of multiple groups, when forming internal models only (eg for export for light or acoustic modelling)? I'd like to place a marker (or the camera) inside my room and have a plugin automatically trim and delete any surfaces not reachable from that point. Sort of like doing a blow-mould!
                    Would be very handy!
                    • irwanwrI
                      irwanwr
                      merci monsieur Pilou πŸ‘
                      and wikii of course πŸ˜„
                      • L
                        Lain Iwakura
                        wikii, thank u very much. Great tool for retop.
                          Seems you have this result with a blender of normal selections (right to left, left to right), Inverse Selection by Tig, Selection Toys by Thomthom...
                            j_forrester
                            Hi Guys,
                            Just a quick one.
                            Does this still work for Skecthup 2016? I have re-named the zip folder extension to ".rbz" hoping this would install it correctly. I says it did install but i cant seem to see it anywhere in the menus? Any help would be very much appreciated.
                            • G
                              glro
                              @j_forrester said:
                              Hi Guys,
                              Just a quick one.
                              just put this file in your plugins folder
                              remove inner faces
                                j_forrester
                                @glro said:
                                @j_forrester said:
                                Hi Guys,
                                Just a quick one.
                                Thank you very much, worked perfectly!
                                • PixeroP
                                  Pixero
                                  Just a side note.
                                  Sdmitch made a script for me that works like ctrl+pushpull without creating inner faces.
                                  It seems he hasn't released it publicly but you could perhaps ask him to release it if interested.
                                  • B
                                    blusben11
                                    I get this:
                                    Error: #<NoMethodError: undefined method file_loaded?' for main:Object> D:/Program Files/SketchUp/SketchUp 2015/Tools/remove_inner_faces.rb:23:in <top (required)>'
                                    Thanks in advance
                                    • iichiversiiI
                                      iichiversii
                                      This plugin hasn't worked for sometime, its a shame as it really helped me out a lot, is there any plans in updating this or is there any alternative plugin that does the same?
                                      Bring on the Rain...
                                      • T
                                        TBoy
                                        Solid Inspectorby thomthom will do the job.
                                        F 1 Reply Last reply
                                        • F
                                          FelipiFalcao @TBoy
                                          Perfect!
